Question about Onkyo HT-RC460
No audio on ht-rc460, but has clear video - Onkyo HT-RC460
Reciever has no sound
Check the rear fuses.
May 25, 2014 | Onkyo HT-RC460
No power
  1. TURN OFF THE DEVICE AND POWER SWITCH FROM SWITCH BOARD UNPLUG THE MACHINE SAFELY
  2. check for cable going from switch to the machine for any wear and tear
  3. WARNING DO IT AT YOUR OWN RISK BECAUSE IT WILL BE SERIOUS HAZARD AND YOU CAN GET SHOCKED PLEASE LEAVE THE HT ALONE FOR 5 MINS AND THEN DO THE PROCEDURE
Apr 05, 2014 | Onkyo HT-RC460
I have a Onlyo HT-RC460 about 6 month. The HDMI got a lot of problems. Every time turn on the Receiver only had video no sound. after switch the out put to different one it works. It is last 2-3 month in...
can i suggest you go to there site and see if there's a firmware upgrade, if you have not done this then also try changing the leads if.... connected to tv from box, most common is the firmware not upgraded good luck.
Nov 14, 2017 | Onkyo HT-RC460
Protect mode constant
doubtful, protect on a sony receiver usually means there is a short in the amp section
Feb 03, 2013 | Sony Ht-6600dp Home Theater In A Box
Sound from Onkyo CD player well and fine. Then connected the Samsung DVD HT-Z310 to Video3 (L/R audio in, V-in from L/R Audio out and V-out of Samsung) but no sound or nor video on TV? Tried to fix it...
What am I missing here?
There are a lot of models mentioned in this post. What are WE discussing?
* A Samsung HT-Z310 is a Home Theater System.
* An Onkyo TX-DS777 is higher-end AV Receiver that DOES have a Video 3 input which accepts composite video and analog audio.
* An Onkyo CD player is irrelevant to the TV sound in any scenario.
* Unnamed TV.
I don't see any path in your narrative that would carry audio TO the TV. Is there an unmentioned HDMI cable in here somewhere? I see no other audio outputs on the HTZ.
Are you running the HT-Z310 through an Onkyo receiver to somewhere (?) else?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-Z310-Home-Theater-Systems-manual/id/23122dj393/t/2/
The fewer hops and inteconnects a given signal experiences between its source and your senses, the better. I always run the BEST video from any source to the TV first; the best Audio to the BEST audio electronics. If that helps.
Apr 03, 2011 | Onkyo TX-DS777
No sound with ps3, connected to a 7.1 av receiver & projection tv
Hi...the HT-R800 Home Theater system has the HT-R550 receiver which could only carry Video via HDMI. you would need to connect a separate audio cale(Optical Audio Cable) to be able to get audio out of the PS3 to the receiver. Once you have hooked up an Optical Audio Cable you would need to go in the PS3 setup and putin Bitstream and Optical in the Audio Setup menu.
Jan 10, 2009 | Onkyo HT-SR800 System
Wiring problems
Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
For video:
All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
  • Video out from cable, HT, and combo player.
  • Video in to TV. Your choice of inputs.
For audio:
Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
  • Audio out from cable box and combo player.
  • Audio in to HT.
The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
Jan 01, 2009 | Sony BRAVIA DAVHDX275 Theater System
Samsung ht ds1000 audio problem
I had the same issue 6 months after I purchased the unit. Worked with tech support several times. Finally they sent new woofer and that fixed it.
Jun 12, 2008 | Samsung HT-DS1000 System
Onkyo HT-RC460 Logo
52 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
