Question about Ecg Medical
Burdick eclipse 800 wont load paper - Ecg Medical
Burdick ekg machine repair
ekg paper for brdick le donot move?
Apr 03, 2013 | BURDICK ECLIPSE LE EKG
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
My printer keeps saying out of paper when there is alot of paper loaded. The printer will not take the paper unless it is feeded in by hand Why does it do that?
hi there!
the rollers may be dirty thats why it wont feed the paper unless you push it in. you can check out this link for quick view and fixes for your printer, including how to clean the rollers. if you are in the USA, you can call 800 HP invent for technical support:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3944758
Apr 07, 2011 | HEWLETT-PACKARD F4580 All-In-One InkJet...
We have following errors on Siemens BURDICK E350 ECG apparatus: ECG machine not write properly on lead V2 Paper jam accurred skipped 2 ECG paper instead of 1 case. Please help how solve the errors on...
we have a burdick e 350 ekg machine i can put the patient info with no problem
but when it comes to doing the ekg i get an error across the screen that says u1 or uI please help thanks
Jan 24, 2011 | Medical
On my 2000 Mitsubishi eclipse, the driver side window wont roll up, and it can't be the motor, cause the passenger window will roll up, and when I try and roll up the driver side it'll make a noise like it...
It could still be the motor.. a small internal short in the motor will let it run but not under a heavier load like pushing the window up. If you can get to the window motor connector by removing the door panel and have a good volt meter you can back prob that connect with small paper clips as just and example. key on engine off, and run the window.. if you get a reading of 12V Then it's most likely an internal short of some kind in the window motor.
Just my thoughts.. Hope it's helpful
Oct 28, 2010 | 2000 Mitsubishi Eclipse
I can't figure out how to load the paper into the Sharp EL1701v!!
Well depending on the model ther is often a small slot on the back of the calculator where the paper would feed through, you would push the paper in then press the feed key, which is often on the top left corner of the key pad. If you still cannot get the paper to load then call us at 1-800-BESHARP. or 1-800-237-4277.
Jun 30, 2009 | Sharp Office Equipment & Supplies
Eclipse cd 3403
cuand lo conecto me apee en la pantalla call 800 y no hace nada despues como lo puedo poner a funcionar bien
Oct 15, 2008 | Eclipse CD3422 CD Player
Medical Logo
53 people viewed this question
Top Ecg Medical Experts
ray gallant
Electro Med Services...
Are you an Ecg Medical Expert? Answer questions, earn points and help others
