Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
1990 polaris indy trail deluxe replaced pistons rings gasgets bottom seals and bearing still wont start
Torque specs
PDF]Engines - Vintage Snow
www.vintagesnow.com/Polaris_files/85%20engines.pdf
ENGINES. Engine Specifications. 1985 . .... Torque Specifications . .... Indy Sport. EC34-2PM-03. 339. 62. Indy Trail (All). EC50PM-01/02. 488. 72 .... 1989 Models ......Polaris snowmobiles are equipped with dependable, high-performance two.
Jan 13, 2016 | Winter Sports
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ...
www.hardcoresledder.com > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from www.hardcoresledder.com
1995 Indy 500 EFI - won't start - Polaris Files
www.polarisfiles.com > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
Polaris Indy 340 has barely any power
check your compression to see where you are. if it is too low you may need new rings or even bore your cylinder and new piston and rings.
that is where i would start
Mar 30, 2014 | Winter Sports
Engine wont start on my polaris big boss 500 6x6 after the piston and rings was replaced
First - Did you find ALL the pieces of the broken piston...if not...STOP and FIND them.. they are in the bottom of the crankcase...you engine WILL NOT live long if you have not gotten ALL the pieces--even the TINIEST ones out!! You mat have more damage than just a broken piston.. something caused it to break.. you may have cracked the crankcases...may have damaged the main bearing(YES) and/or damaged the crank bearing.. see if gas in leaking into the transmission oil.
There is an arrow on the piston that faces toward the EXHAUST port. If there are hole(s) in the piston, they go towards the INTAKE.
Do some more searching and repost the results for review!
May 22, 2017 | Polaris 2012 Sportsman Big Boss 6x6 800
I have a 97 polaris indy 500 snowmobile. The spark
Wait, it just wont turn over, like the engine won't rotate?, that is either a broken crank, which not unusual for those 500's or you seized it, (welded the piston to the jugs). if this isn't what you mean, and it will turn over but not on its own power, then either your jets in the carbs are clogged, fuel may get to it, but not through it, or your rings are stuck closed and giving you low compression, check this by pulling it over slowly, you should feel each piston completing the revolution with a prominent glug glug. grab your primary clutch and rotate it back and forth, it should have a bit of play, but if it clanks and has alot of play, your crank is busted
Feb 16, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 1992 polaris indy 500 efi snowmobile and I just put a new piston cylinder head on it and got ot to run but however it will run and take off accept when the throttle is wide open it dies and I have...
hi ,i have a small and big project ,just busted a piston in my 500 piolaris indy snowmobile & to it apart & forgot about the presstone and it's all at the bottom of my engine ,where do i go from here &&&& another thing i had to drive awhile with the busted piston so what would be the damge ,what should i do with the whole thing
Jan 17, 2010 | Polaris New Genuine Polaris Snowmobile...
Mikuni Carbs on Polaris Suppersport choke assembly view chokes are stuck open and floods itself out,
I have a 1991 polaris indy 500 put new pistons in it and now it runs bad wont idle right.
Jan 11, 2010 | Polaris New Genuine Polaris Snowmobile...
My indy 500 wont start i changed the fuel pump and it will turn over with stater fluied got compresion and spark
i have trouble starting a polaris indy 500 1990 new gasgets, pistons rings all i does is back fire through the two carbs
Dec 11, 2009 | Polaris New Genuine Polaris Snowmobile...
On my 86 trail boss the shifter handle goes past
adjust the handle underneath , also check to see if the dipstick is showing any oil in the tranny(yellow ring). mine fell out and all the bearings wore out on me after a week of not noticing it. $100 in bearings and seals but a real pain in the *** to seperate two halves of tranny without the urge to screwdriver it.but when the bearings wore out it wouldn't go in reverse and shifting way ahead to get it in drive .
Nov 26, 2009 | Polaris ATV
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
29 people viewed this question
Top Polaris Winter Sports Experts
Todd Arndt
Todd Arndt
Lawrence Oravetz
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
