Question about Refrigerators
Frigidaire FGHC2342LF3 water filter leaking - Refrigerators
4 Suggested Answers
SOURCE: Water leak at filter
You probably will have to replace the water filter housing that holds the water filter. This is an relatively easy job and should only take about 30 min. The housing will cost around $40-$50 online or from your appliance store. Turn off the water to the fridge. Take the top shelf out of the fridge to access the water filter area. There is a small screw in a really deep hole on the bottom of the cover, just to the right of the filter cup. I used a really small socket (9/32",1/4" or 9mm - can't remember) and extention. Take out the screw which will uncover the housing. The water hoses (white) just slip onto the housing - check these to verify if they are on tight. If they are loose this is the water leak. if they are on tight (which I'm sure they are) then proceed. Take off the filter cup which is screwed onto the housing. Remember "righty tighty - lefty loosy". Take another small screw (maybe two) out which holds the housing to the refrigerator. Now pull the water hoses off the housing. This is kinda tuff because the hoses are just slid on to the housing and are held on by friction only and its hard to get a good grasp because of the location of the unit. You can't really stick much under the hoses to pry them off either because if you damage them, they won't hold the seal later. Just pull and twist and they should come off. Visually inspect the housing unit, you should be able to see a crack if there is one. Replace if necessary. Just make sure not to overtighten the screws and especially the filter cup when reinstalling. Good luck and I hope this helps.
Posted on Feb 06, 2009
garing
  • 998 Answers
SOURCE: water leaks from the pure source filter
vaseline on filter threads and tighten...thumbs up...
VE6GAR 73 88 99
Posted on Aug 10, 2009
  • 65 Answers
SOURCE: Replaced leaking filter but still leaking
Where is it leaking?, at the filter?, at the hook-ups on the filter?
Posted on Aug 22, 2009
I have a frigidaire gallery series side by side and everytime the fridge says the water filter needs to be changed now it leaks a good bit of water from the bottom of the fridge.
There is an O ring that will leak water into the overflow pan under the fridge. I'd clean the pan too to eliminate bad odors. You must shut off the water supply before changing the filter element. There is no shut off valve built into the filter or its housing.
Aug 08, 2015 | Frigidaire Refrigerators
Leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Jul 14, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
What causes frigidaire puresource3 water filter to leak
Good Afternoon Friend,
I understand that the puresource3 water filter is leaking in your Frigidaire refrigerator. Please make sure that it is the filter leaking. Check for cracks in the filter. If the filter itself is not leaking, it might be something in the filter housing that is leaking. If this is the case, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose and determine what exactly is causing the leak. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire ULTRAWF Frigidaire PureSource...
Water leaking
Sounds like you have a cracked, faulty filter that needs to be changed, or a loose water valve connection.
Jul 29, 2012 | Frigidaire FRS26RLECS Side by Side...
Frigidaire refrigerator water filter area leaking
There has to be a loose or disconnected water line. Check the water dispenser inside the door and behind the door and then go from there.
Jul 23, 2012 | Frigidaire GS26HSZDW Side by Side...
Water dispenser on refrigerator leaks inside the refrigerator
Check filter houseing and filter, Its either not installed correctly , has a line leaking or disconnected to filter or has frozen over the filter. Good Luck.. Hope your freezer is keeping cool enough.. AARS
Jul 01, 2010 | Frigidaire FRS3R5EMB Side by Side...
I have a Frigidaire side by side - FRS26HF6BW2 - It will leak water from the filter cartridge area into the refrigerator. It has done this 3-4 times in the past year but never did this before. Any words of...
I have the exact same issue. If you look closely at your filter, it probably has a crack in it. The workmanship on the filters is apparently horrible and the material is too thin causing it to crack and leak within 2-3 months of purchase. I was replacing filters at $45 each every 2-3 months and complained to Lowe's where I purchased the Refrigerator as it's still under warranty. The sent a repair man who tested my water pressure which was fine and he pointed out the cracks on the last two filters that I had saved. He said he sees this all the time and that there's nothing you can do about it but complain to Frigidaire. Well that's been a waste of my time so either we deal with a leak or we don't use the water dispenser in the door. Maybe if some of us band together and file a law suit against Frigidaire they might listen.
Jun 20, 2010 | Frigidaire FRS26H5AS Side by Side...
Aug 22, 2009 | Frigidaire FRS23R4A Side by Side...
Water leaks from the pure source filter
VE6GAR 73 88 99
Aug 10, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water filter leaking
This happened to me and was the o-ring, the cup is sealed by the o-ring and in my case I did not realise it dopped off after I unscrewed. Either your o-ring is missing or needs replaced as it is worn out.
Aug 21, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
