Question about Hardware & Accessories
24hr will not change to 12hr on my ge 7day digital timer
Instructions say to hold clock button until timer displays 12 hr my timer only shows 24hr what am I doind wrong?
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
SOURCE: Need to re-set time on Salter digital timer
If it's the same as ours (clock button top left, clear bottom left):
  1. press and hold clock until the clock starts to flash
  2. set time using h/m/s keys
  3. press clock again
Hope it works
Posted on Nov 01, 2009
SOURCE: setting GE Plug in mechanical timer 24 Hr Model
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
Posted on Dec 18, 2009
SOURCE: GE 15 amp 7-Day In-Wall Programmable Digital Timer
Your timer is bad. It comes with 1 year limited warranty.
Buy one at Home Depot and then return defective one.
Make note of wiring before removing bad timer, so re-wire is easy.
GE 15086 is White 7-day digital, non-astronomic timer made by Tork, and sold on-line and at Home Depot.
On the shelf, 15086 timer looks identical to 15071 >> same package >>> difference is 15071 offers daylight savings time and random option, and costs a bit more.
These in-wall timers usually last a few years, and some can last for several years.
Especially when timer operates from electric circuit and not battery.
15086 operates from electric circuit.
15086 manual on-line:
http://waterheatertimer.org/pdf/GE-15086-Manual.pdf
Posted on Dec 05, 2010
SOURCE: intermatic digital lamp timer dt300.
There is no repair for defective timer.
The DT300 is sold under at least 3 different brands and product numbers, and each manual shows identical steps for choosing 12H and 24H format.
The manual says to press and hold CLOCK button until display shows 24H. Then press HOUR button to change to 12 hour format.
I am guessing this step cannot be done if timer has programming in memory, so timer has to be reset first by pushing in reset button for a few moments.
Open following links to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Sep 14, 2011
Can you fix the clock on a 97 jaguar xj6 radio clock at home?
1: press and hold the MODE button until TA VOLUME is displayed. 2: Press and release the Mode button until CLOCK SET is displayed.
3: While the display is flashing use the SEEK UP/SEEK DOWN keys to select 12hr or 24hr style display
4: Press and release the MODE button again If 12hr format has been selected use the # key to select AM or PM Using the Numeric Keypad enter the correct time using four digits i.e 1045 for 10:45. Press and hold the MODE button to return to the normal audio mode.
May 18, 2016 | Jaguar Cars & Trucks
Kenmore stove
here are instructions for a Kenmore, of course they may not apply to your model, but then you haven't specified your model so it is difficult to help!
do let us know if they work
Press "Clock."
Enter the time using the number pads on the right-hand side of the clock display.
Press "Start."
Press and hold down "Clock" for six seconds, until "CLO" disappears and "12hr" or "24hr" appears on the display. Press "Flex Clean" to choose between the 12-hour or 24-hour display. Press "Start."
May 15, 2014 | managemylife.com
Jensen jbd-100 change clock
Take battery out and unplug to force a reset.
Hold Display until it starts flashing 12 hr
----use tuning buttons if you need to change that to 24hr
Tap Display to confirm setting and move to next stage
Repeat the same steps of tap Display and then use tuning to adjust up or down for the hour and minutes.
Make sure to increase hour setting enough to have the "pm" show up for times after noon when using 12 hr format
Nov 06, 2013 | Jensen JBD-100 UNIVERSAL BLUETOOTHR CLOCK...
Sharp spc570 -cant change from 24hr military time to 12hr time
You must remove the AAA batteries. It will then reset to 12 hr upon reinstall of the batteries. I tried everything to get the 24 hr to12 hr using the time set buttons but nothing worked.
Aug 24, 2013 | Audio Players & Recorders
How to set the time
How to set the time on what make and model device?
Mar 01, 2013 | GPS
How do I set the current time on the Woods Digital Timer Model#59203?
78a8604.jpgWoods 59301
Manual for 59301
http://waterheatertimer.org/pdf/Woods-59203.pdf
Plug timer in wall for 1-2 hours so rechargeable battery charges
If display does not show after 1-2 hours, the battery is dead and timer is no good
After 1-2 hours, you can remove timer from wall to program
Press reset (R) with paper clip to clear memory
Select format: Press and hold Clock button until 12 hour or 24 hour shows on display, then release
Press hour button to change display to 12H
press Clock button and display returns to normal
AM shows in upper left corner
Set current time:
Press and HOLD clock button
While holding clock button, press hour button and minute button until display shows current time
Release clock button
Press and HOLD days button until current day shows in display
Release days button
Further instructions to set ON-OFF times are in manual (click link shown above for manual)
If you have problems, re-post additional question.
Oct 17, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
24 hour clock
Sometimes if you depress both the Hr/Min buttons this toggles the time 12hr/24hr, Im not positive on this one..You can always check with a dealer or look in the owners manual if you have one. Or just learn military time..lol..
Mar 24, 2010 | 2006 Audi A4
Coleman watch Model No. 40-328 How To change from 24 to 12 hour
I couldn't find the instructions for your watch but as watches tend to have similar operating characteristics, try this:-
Press the mode button until you come to a message that says something like "12hr" or "24hr" or something that indicates display change.
Then press one of the two buttons on the right to change to the display you require.
Some experimenting may be required!
Feb 01, 2010 | Watches
Change Clock - Logitech Pure-Fi Elite
hold the src button left of power along with button to the right power.a model number will appear once it does let it disappear and the unit will go into reset. set the language, 12/hr, 24hr etc and the time. :)
Dec 13, 2008 | Logitech Pure-Fi Elite High Performance...
I have lost the instruction manuel too my GCR 1870 iB (which is a Radio Alarm Clock with a docking station for an iPod). Please help, as I don't know how to change the time.
There is a 'Clock' button omn the back of the alarm clock. Hold this down for 4 seconds until the display changes. You will then be able to change the 24hr/12hr display by clicking the skip fwd/back buttons. If you press the 'Clock' button again you canc cycle through changing the year, date and time in the same way.
Hope this helped :)
May 26, 2008 | Audio Players & Recorders
Hardware & Accessories Logo
18 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
