Question about Miele S5281 Callisto Canister HEPA Vacuum Cleaner, S5281
Miele solution hepa 5281 overheated and stopped working
2 Suggested Answers
stuart_basse
  • 109 Answers
SOURCE: My Miele Hepa 5281 stopped working for no apparent reason. No burning smell etc. I've replaced the fuse on the plug but it's still not working. Any suggestions on what could be wrong a
Could be a break in the mains lead. Usually where it enters the machine and gets stressed. Some motors have a thermal cut out or thermal fuse fitted to them. If the motor overheats it breaks the circuit. Some of them reset when they cool down, some are a one shot device, when it blows it has to be replaced. Could also be faulty brushes on the motor not making proper contact because the are sticking or worn.
Posted on Dec 18, 2014
Dec 18, 2014 | Miele Vacuums
How do i put the vacuum bag on my miele pisces vacuum?
Hello, this is Ava with Think Crucial.
You may check the instructions on how you can install your Miele bag inside your vacuum using the link provided below.
Miele 5281 Pisces Operating manual
You can purchase a wide variety of high quality Miele replacement parts for your Miele Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 26, 2014 | Miele Pisces S5280 Royal Blue Canister...
Miele 5281 vacuum cleaner permanently on high speed
Most likely the speed control board has failed. The solution for this is to replace the electronic unit unless you know of someone who can diagnose and repair circuit boards. The part is common and easily replaced for around $60. Miele's website can point you in the right direction for a service center, or tell me your zip code and I'll look it up for you.
Nov 09, 2013 | Miele Vacuums
Blows hepa filter from mounting
I have seen generic filters do this. Be sure to use original Miele filters. The generics are a few dollars cheaper to buy but you end up with an inferior quality filter that could cause other problems by continued use. same is true with bags.
A clogged filter may also do this. Miele vacuums are very tightly sealed, the exhaust air has to come out. If the filter is clogged, the pressure could pop the filter out, HEPA filters are suggested to change out about every 50 hours, for most people this is between 1 - 1.5 years.
We had a Miele come in for service the other day with the same complaint, installed filter was a generic, customer said it was a new filter just installed. We replaced with an original filter and problem ceased.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Mar 16, 2013 | Miele CatAndDog700 Bagged Canister Vacuum
Miele Solution 5281 motor problem - can it be fixed?
You cant repair the motor but it is not too hard to replace the motor. I have made a video showing how to replace the motor on a miele S5311 which is a very similar machine. The part number for the Miele S5281 motor is 9271290
Jan 21, 2013 | Miele Vacuums
Where do you put the prefilter on a miele canaster vaccuum
Hi If the power head isn't working it may be clogged. Try taking it apart to see if threads and general dirt has got in at the sides. Also without the power head if the Miele still isn't working then its a possibility that the on switch wiring is either loose or check the plug at the end of the power cord.
Sep 11, 2012 | Miele S514 Solaris Electro Plus Vacuum
Miele vacuum cleaner keeps overheating and shutting off. It is only possible to use for about fifteen minutes at a time
Hi Lauren, how do you know if it is the circuit board? (the speed control buttons still work).
Mar 13, 2011 | Miele Vacuums
My Miele Solution HEPA 5000 vacuum cleanr gives off a burning smell but will continue to run with a varying motor tone. I have not run it for more than a minute like this. I have reviewed responses to...
Check both the bag and the HEPA filter behind the bag, torwards the motor. The HEPA filter could be clogged. Love these units but it takes clear attention to multiple filters.
Mar 06, 2018 | Miele S318 Bagged Canister Vacuum
My Miele Silver Moon "Reset" light is blinking. What do I do?
Greetings from GoVacuum,
Ahh yes, the Silver Moon. One of Miele's best made vacuums ever! So good that out of all the different vacuums that I could of chose for my home, the Miele S558 Silver Moon was the one I chose.
When you're Reset button is flashing, this simply means that it's time to replace the HEPA filter on your vacuum cleaner. Miele included this feature on their upper end models to alert the user when their filter needed to be changed.
The Miele Silver Moon uses Genuine Miele S-Class HEPA Filter for S300i/S600i, and Miele S7 Uprights. Miele Part # 04854915 (replaces 04854911) Which can be purchased from GoVacuum for $52.95 with free shipping.
Once you have installed the new HEPA filter, simply press down on the flashing Reset button to restart the 50 hour internal timer inside. Miele recommends to replace this filter after every 50 hours of vacuuming.
If this answer was helpful, please click on the helpful Thumbs Up icons in the top right hand corner of this Solution.
If you have a repair that you would like explained, please check out our Q & A website, askgovacuum.com.
Thank you very much,
Chris Jones
GoVacuum.com
Feb 19, 2010 | Miele s558 Silver Moon Vacuum
Overheating indicator comes on straight away
You could have a bad heat relay.
Feb 24, 2008 | Vacuums
Miele S5281 Callisto Canister HEPA Vacuum Cleaner, S5281 Logo
78 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
