Question about Canon Pixma iX5000 InkJet Plotter Printer
Why does my Cannon IX5000 keep printing black and white in colour
  • 164 Answers
SOURCE: black cartridge emptied half way
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most walmart pharmacy departments.
*Warning: You may want to usea pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Patience
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent aeound it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, slternately sloshing/swishing and pouring solvent over head (be carefull not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY,with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Posted on Feb 07, 2010
puertobori
  • 7733 Answers
SOURCE: My printer Cannon MX280 cannot printed pictoure
Canon U.S.A. : Support & Drivers : Consumer & Home Office
Posted on Oct 27, 2010
  • 111 Answers
SOURCE: Canon Pixma 3600 I want black
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
  1. Open the presentation you want to print.
  2. Click on the word File in the Menu Bar.
  3. Select the option Print.
  4. The Print dialog will appear.
example:
sayurisan20_3.jpg 5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray. 6.Choose the Pure Black and White option to print in black and white only. 7.Click on the OK button.
Posted on Jun 06, 2011
  • 11800 Answers
SOURCE: how can i print black
Yes, there is: in Printing Preferences , in the first tab, you have the Grayscale option - select it.
Posted on Jul 29, 2011
Testimonial: "love you"
Geekman
  • 32281 Answers
SOURCE: my cannon mp490 not printing
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Posted on Sep 04, 2011
Why cannon ip3000 can't print in only black and white although I choose grey scale priting?
Not sure of the QUESTION..? Do you want to print colour or black and
white..? Anyway,try this, bring up image , at top left click on Fix , at top
right click on Auto Adjust then go down to Adjust Colour click on and
hold Saturation Slider move to left to remove colour ,right to add colour
go to print and it should give you a black / white image. Remember to
return image back to original colour or image will return to file in b/w
hope this works for you..goodluck...T.C.
Mar 31, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Will not scan due to no colour ink. do not want to
hi,
As you dont want to use the colour ink,When you give the print command you wil get the print properties page ,In that you can select black and white so that you wil not use up the colour catridge. It uses black catridge only.
thanx
Jul 21, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
I have a HP PSC 1610 all-in-one printer. Can the colour cartridge be bypassed when it asks for replacement cartridge? I only print in black and white now 99% of the time.
No , we all only wish, this is the bane or all printer users. You cannot print without all in full & being OK. Also must use color sometimes else nozzles can clog up. Must clean, too.
Mar 26, 2010 | HP PSC 1610 All-In-One InkJet Printer
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
Print black & white?
Your printer will keep using the color cartridges to keep the printing head working even if you don't print in color. If you need to print only in greyscale, buy a cheap HP printer (Printer only, not a PSC) and remove the color cartridge.
Apr 14, 2008 | Brother DCP 115C All-In-One InkJet Printer
My colour ink catridge is empty, but I do not want to use it. Is there a way to overide using colour ink?
You can go to the printer settings (Start, Printers and Faxes, rightclick on printer and click Properties).
Click on Printing Preferences and in there should have a setting to print Black & White only.
Thanks,
Lolita
Apr 09, 2008 | Office Equipment & Supplies
Why does it keep running out of color ink, while printing only Black and White?
Whilst you rarely print in colour, its important to know that you should try to print in colour at least once a week. This will reduce the risk of your colour nozzles blocking up.
Many people have gone out to replace their 'hardly used' colour cartridges when they dont work, thinking that they have dried up, when infact its simply blocked nozzles.
If you want to keep your colour nozzles and ink ready to run, just do a full colour alignment every 1-2 weeks. Minimal ink usage there and you keep your Canon MP780 running well!
Jan 12, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Cannon mp130 not printing colour
click on print then a box will come up and select advanced options
and fine where it says print grayscale and then select the color.
Oct 21, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma iX5000 InkJet Plotter Printer Logo
15 people viewed this question
old marine
old marine
