Question about Home
Triton shower faults
No power, slow water flow
keemo68
  • 1263 Answers
SOURCE: Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Posted on Sep 03, 2008
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: cold water suply filling up header tank in loft thru hot water suply on shower.
hi did you run a seperate cold water supply from the storage tank to the shower pump & also a seperate hot supply from the hot water cylinder, it sounds as though the cold water is crossing into the hot service & pushing its way up to the tank as its the only way it can go, sounds as though the cold water connection to the shower is not tank fed & possibly directly off the water main.?
  • 20 Answers
SOURCE: I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Posted on Nov 11, 2009
  • 16 Answers
SOURCE: triton topaz t80i. Power to unit ok, but no water flow.
sounds like the pump is broke. better off just replacing whole unit unless you order new pump from triton.
Posted on Jan 10, 2010
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Theres only a low flow of water coming out of the shower.
remove the head and make sure you have a good flow to the head if you do look to see if a plug needed to be removed before installation if their isn't return the product
Jul 06, 2012 | Home
I have a triton dart shower which is operated by turning a flow control block. This is so hard to turn that I sometimes struggle and my family require my assistance. It is just as difficult to turn off...
I can't offer you a solution but will say that I have the same problem with my Triton Dart. I have put it down to a build up of hard water inside the valve but not sure. Think I'm going to have to contact Triton under their warranty although they do say that they will not cover faults resulting from limescale.Great
Nov 09, 2010 | Home
I have a triton r2 which has suddenly stopp working no water no power there is power at isolating switch
My guess is that the solenoid valve on the inlet pipe has died. This assembly is held closed by water pressure and power is needed to pull it back to allow water through to the heater coils. These systems are designed not to operate in the absence of water flow for safety reasons. The valve will be fine, it is the electrical coil within the solenoid which is at fault. Disconnect the shower unit from the mains supply and disconnect the solenoid terminals, Its the little cylindrical device immediately to the right to the stabiliser valve (the lower knob). Try a voltmeter across the solenoid and it should register some continuity, if no continuity the coil is fried. Triton will be the best place to get a replacement part.
Apr 29, 2010 | Water Pik Waterpik& Elements& Fixed Mount...
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
Shower has power but no water flowing can you suggest a reason
The solenoid valve on the water outlet needs replacing. This fixed my Triton Power Shower anyway!
Oct 29, 2009 | Sun Time California San Diego Tritons Ncaa...
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Aug 30, 2008 | Home
Home Logo
53 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
