Sanyo tv troubleshooting
Indiction light flashing but no picture or sound
shivam4529
  • 150 Answers
SOURCE: sanyo vizon tv black screen
hiiiiiii here shivam
i want to tell you that that same problem is occuring my computer but now it is fixed
but your problem is of tv don't worry is this is help full to you--
this problem is common on this model. your vertical output circuit has gone bad. but i am sorry to say that a repair cost is to much for a tv this age. a cost would range 100-150. i say invest this into a newer tv. this model was good for 10-12 years and you have got better than that.
good luck :)
let me know if you need more info?
Posted on May 24, 2008
  • 11800 Answers
SOURCE: Sanyo CE32LD47-B LCD TV.
No, the PS has nothing to do with that - the standby light blinks to signal an internal component failure and a bad source connection can't cause that. Since the light is steady at start it means that the power source starts normally but the process doesn't end correctly: the defect is located in either the mainboard (the processor has failed) or the inverter for the backlighting tubes has failed.
To identify which you will need to open the tv and test the voltages on the power source board starting with the output line for the inverter; after that the voltages for the mainboard - you will need at least a good multimeter and experience in electronics repair. If you don't have both then unplug the tv from the mains and call a repairman.
Posted on May 03, 2011
blueextc3221
  • 15935 Answers
SOURCE: sanyo lcd tv 20"has sound but no picture
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks! ! ! !
Posted on May 27, 2011
alpug
  • 1961 Answers
SOURCE: sanyo model 42848
This could be a faulty back light lamp.It is located right at the back of the screen It is an cold cathode lamp supplied by a high voltage from inverter board .Inverter board has a input voltage of 24 volts inverted into 300 volts AC this lamp lights up the screen...
You need to open the back cover to check the lamp.....
Posted on Jun 07, 2012
  • 43983 Answers
SOURCE: Sanyo LCD TV has green light , no picture or sound.
You have the classic symptoms of a power supply failure. Visual inspection of capacitors is not a reliable method of solving the problem
Posted on Mar 08, 2013
I have a Sanyo 44" tv model DP50E44 has no picture and has sound i have replaced the Sanyo 40-55E811-DRD2LG LED Driver DP55D44 and the main board. and still no picture. could my led strips be bad?
Do flash light test on unit. If you see images then go for the t con board. If no images it could either be your inverter board or the strips.
Sep 20, 2017 | Sanyo Televison & Video
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Sanyo dp26671 hdtv no picture or sound but have red light
If the power light is flashing, it could be excessive or shorted voltage or that the capacitors are malfunctioning. In this case, replacement capacitors or a new power board is in order. Contact a professional for help.
If you hear a chirping sound, that is the shutdown circuit activating, indicating a problem with the power supply.
For more tips and tricks, check out No picture on TV for troubleshooting steps and solutions. I hope this helps!
Sep 28, 2012 | Sanyo Televison & Video
No tv picture
Start by making sure that all of the set-top box cables and cords are firmly connected and that the set-top box is turned on. Also, check to see that the TV is set on the correct channel and that the DVD player is not on.
If the power light is flashing, it could be a problem with the voltage of that the capacitors are malfunctioning. In this case, it's best to contact a professional for help.
Sep 27, 2012 | Sanyo Televison & Video
Blue light flashing no picture or sound
Sounds like a main board problem, I've worked on quite a few Sanyo's and their main boards are notorious for failures.
Jul 23, 2012 | Sanyo 42 in. LCD TV
Sanyo model 42848
Jun 06, 2012 | Televison & Video
My tv ha as no picture or sound but the green light come on and flashes
hi. sounds like inverter to me. if you cant see a back-light then tilt the tv into lie light and if you can see a faint picture but its not lighting up then it needs a new inverter..
Jun 08, 2011 | Sanyo 42 in. LCD TV
37' lcd sanyo. sound no picture. no backlight. when turned on screen will flash on for a second, power indicator light stays on . Hear electric static sound when screen flashes
Check the lamps connectors on the backlight inverter board make sure they are not loose. You may be ahving failing inverter board itself.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 22, 2010 | Sanyo DP37647 37 in. LCD TV
Tv has no picture, has sound
this is a job for experienced tech need troubleshoot high voltage to picture tube 25 to 30 thousand volts
Mar 27, 2008 | Sanyo DS31590 31" TV
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
