Question about Sony VO-9800 VCR
SONY VO-9800P U-Matis SP compatibility
Hello, I would know If this model can read every U-Matic tape (standard,low band , high band) or only SP tape. Thanks
No, this U-Matic VO-9800p ist a PAL Model, it only Records in SP and High Band Mode. If a SP Tape is inserted, it Records SPMode, otherwise High Band. Low Band Mode is only for Playback !
(Low Band Playback is of very poor Quality, do not use this for Digital DVD Captureing )
Posted on Aug 23, 2010
    Problem Solver:
  • 10 Answers
Yes, The VO-9800 will play and record both low and high band tapes. There is a pin swich in the transport that falls into a hole in the SP tapes to tell the machine what mode to use.
Posted on Apr 03, 2008
2 Suggested Answers
  • 160 Answers
SOURCE: compare specifications between Sony BVU-800 and VO-9800
sony vo9800
sony bvu 800
Posted on May 07, 2009
SONY U-matic VO-5850 does not record audio
Has the video got some kind of switch for switching between different audio sources? You might have to look on the menu to switch it back to normal.
Mar 04, 2014 | Televison & Video
How Does One Adjust Settings for Reading Time Code?
you have to use the "dial menu operation"! where the buttons "menu" "data" and "set"
Sep 26, 2007 | Sony VO-9800 VCR
SONY keeps switching to EP at beginning of playing SP tapes
You may have dirty heads in the vcr---most 4 head machines use two for sp and the other two for lp and or ep.
Tape residue will usually be seen on the drum where the heads are when this happens--also look for the black residue on the tape guides that hold the tape in position against the drum-------
Apr 27, 2012 | Sony Televison & Video
Need a service manual for Sony VO-9800 Umatic SP Recorder/Editor
it is available for download from for about
Sep 02, 2009 | Sony VO-9800 VCR
Compare specifications between Sony BVU-800 and VO-9800
sony vo9800
sony bvu 800
May 07, 2009 | Sony VO-9800 VCR
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
I have a Sony SLV-EZ717
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours
ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
Jan 25, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Head Hours
Nope it's in the user menu and you have to have video going into the deck to read it on the monitor video out put. Head hours are the time the tape actually is in contact with the drum and the most accutate easy indication of drum ware. 3/4 Umatics don't eat heads as a rule. I think I only replaced 1 out of hundred for thousands and thousands decks. Brokers love head or durm hours tipically it's T2 on the menu.
Jan 21, 2008 | Sony VO-9800 VCR
this sounds like the belts on the take-up pinch wheel if it's streached then it's going to be fast if you can find all belts that take tape to drum and read heads then check each one if streached replace if all fails when replaced belts then it needs repair. hope this works
Aug 15, 2007 | Sony VO-9800 VCR
Sony VO-9800 VCR Logo
472 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
