Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Mtd 17.5 will not start
Turn motorcouple inches then locks
  • Dwain Pippen May 11, 2010
    Can you turn it backwards by hand and how far?
Take off the flywheel you will see the problem. I have put too much money into it every year that I have owned it. JUNK.
Posted on May 26, 2009
Mtd 11.5 HP lawn tractor
go to Parts Tree.com punch in make and the model no you have a page of MTD mower models will come up try page 17 or 18 your model should come upo with pages of parts take your pick.
Apr 15, 2016 | Mtd Garden
Can anyone tell me the size of the bolt that secures the front (drive) pully on a 38" cut MTD ride on ? I'm pretty sure it's 7/16 but un sure of tpi . Bolt has fallen out!
the beauty of imperial measured bolts is that there are only 2 threads for each size bolt
so if it is 7/16 bolt it will be either unf or unc one thread is fine (unf and most likely) and one is course (unc)
however if it is mtd make it could be running metric in which case the bolt will be ( if 7/16) 11.11 mm in which case the thread can be 1.25 or 1.5 or 1.75 pitch
might have to talk to a mower shop that sells mtd and get the size bolt from them
Mar 14, 2016 | Mtd Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
How do you find an inline fuse for a mtd riding mower 38 inch cut 14 horsepower
Start at the ignition switch and look for the starter wire..it should be the one tat is slightly heavier and normally red..and goes to the solenoid pos side..good lu k
Nov 16, 2014 | Mtd Garden
Where to get the parts? Cam & blades
http://www.remingtonchainsaw.com/parts.html
To the best of my knowledge, all parts have to be obtained online. Remington (DESA) went out of business in 2008/2009. They are now owned by MTD. It is still unknown if MTD will continue to offer parts for the older units.
Jan 04, 2011 | Remington Factory Reconditioned 17-Inch...
IMac 17-inch 2.0GHz Core 2 Duo SuperDrive Mac Desktop: The computer dosn't start. the light on the side s...
Maybe a type of ram issue. Pull off the back of the unit by unscrewing the 3 lock screws on the bottom of the unit and press the little button on the motherboard which will be up and to the left kind of as you look at the board. Assemble and try if that doesnt work you may need to send the unit in for service.
May 18, 2010 | Intel iMac 17-inch 2.0GHz Core 2 Duo...
Recoil will not pull. The walk behind MTD,Yard Machine mower, a B&S 500 Series stalled while mowing. I went to restart and pull cord will not pull more then a few inches. How do I go about the fix?
If all the safety gear is working on the mower; Possibly sounds like you let it run low on oil and the engine is locked up.
Which would mean a new mower.
Sep 29, 2009 | Mtd Garden
2006 MTD Yard Machine 38 inch 12.5HP won't start. Replaced ignition switch that was corroded and replaced battery. No power at all. Is there a solenoid switch of some kind that could be bad also? ...
should be a solonoid under dash when the bonnets open.to check this turn your ignition on start and put a screwdriver from the small wire to the main battery cable going to the starter.if this does not turn the motor over replace the solonoid.if the motor does turn over let me know .
Jul 25, 2009 | Mtd Garden
Does Bolen's weed wacker BL100 17" cut 31 cc require a mix of gas and oil. Thank you
I was able to get information from someone's manual. I can't find mine. Would like a manual.
May 16, 2009 | Mtd Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
116 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
