Question about 1989-1991 Peugeot 405 Antenna, 89-91 Peugeot 405 Replacement
My USB stick not work in my Peugeot 208 it not the right format
What are the tyre pressures for a peugeot 208
the tires have that stamped into the side walls . and should also be on the tag on the door frame .
Nov 18, 2016 | Peugeot Cars & Trucks
How to use Toshiba Media Player
Is the USB drive able to be read on your PC / Laptop ?
It COULD be that the USB drive has been 'Formatted' (made ready to receive files) but not in the 'FAT32' mode. It WILL say so in your TV manual.
PCs can read all format USB sticks but TVs are fussy and generally only work if the USB stick is formatted 'FAT32' and not 'NTFS' (which it probably is.
1) Put the stick in your PC - right click on it from 'my computer.'
2) Format the USB drive with FAT32,
3) Reload the stick from your PC with the photos.
4) Plug it in your TV.
It will be fine.
Sep 14, 2014 | Toshiba 50L5200 50-inch LED TV
Usb does not work in Peugeot 508
unplug the usb stick and plug it into the usb slot.
Nov 14, 2013 | Computers & Internet
Can't find wheel bolt torque setting for 2012 Peugeot 208
Peugeot 208 wheel bolts (with alloy wheels) should be tightened to 100 NM
Mar 25, 2013 | Cars & Trucks
I recently purchased the device listed below and when I ried to use I received a message that it was either not formatted or formatted for a Macintosh. How do I format it for use with my Dell PC?
Your usb stick could be formatted in either 2 ways:
1) If you go into "my computer" or "computer" (depending on if you are using XP or Vista/7) and you see your usb stick on that list, you can right click on it and select "format". You can just accept the defaults it gives you and hit ok and it will format it to be used on your computer. If it doesn't show up in "my computer" then there is another thing you can try:
2) If you right click on "my computer" or "computer" there will be a menu that pops up, select "manage" from this list. Once a new windows opens up, on the right hand side you will see "disk management". Select this. You will now see a new list of all the hard drives/usb drives on your system. You can right click on your usb stick and hit "format" in the same way as 1.
DISCLAIMER: Make sure that you select your usb stick from these lists, and not your computers hard drive. If you accidentally format the hard drive you will lose everything on your computer.
Hope this helps and if you need any more help just leave a comment here and I will get back to you.
Sep 21, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to format my write protected usb stick
If there's a switch on the stick, switch that to turn off write protection.
Place the USB stick in your machine. Go to "My Computer", and then right click on the drive icon (pick the right one, it should have an image of a thumb drive or say "Usb" in the title), and select "Format". You'll want to format it to Fat32.
Note, this will delete everything on th drive you format. Make sure you get the right drive!
Mar 01, 2011 | Computers & Internet
1GB Memory Stick PRO Duo Memory Card: My sister's boyfriend put my stick into his comput...
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
May 14, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
In spite using DVD-R disks with the specified logo (in the case, Memorex and Sky), as I insert them in the recorder, it formats the disk but doesn't record anything on it and, when I try to eject the...
?Ÿ???¾?±?»?µ?¼?° ?µ ?²??µ?¾?±?? . ?¢????±?²?° ?´?° ??µ ??¼?µ?½?¸ ?¿?¸??°?????°???° . ?¢? ?µ ???¾?¼?¿?Ž???Š???½?° , ?¾?¿?¸???²?°?¼ ??µ , ?½?¾ ?½?µ ?µ ???°?·?¿?¾?·?½?°?²?° . ?¢????±?²?° ?´?° ??µ ?½?°?¼?µ???¸ ?½?°???¸?½ !
Nov 03, 2009 | Sony RDR-HX1000 DVD Recorder
16 GB USB 2 MEMORY STICK I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem...
I'm a little confused as you mention both Drive E. which suggests Windows and gnome which suggest linux.
WARNING: Formatting the disk will erase any data on it. Do not format the disk if you are trying to get the data off it that was on it yesterday.
It is possible that the partition table has been corrupted.
If you are using windows. You can either try right clicking on the drive (not double clicking) from Windows Explorer (My Computer) and clicking format. Choose the file system type and go. Alternatively, you could work through the disk management administrative tool. Right Click on My Computer -> Manage -> Disk Management. Right click on the volume and format it.
If you are using linux, see if you have a valid partition table using fdisk for the device. Then, after creating the partition, use mkdosfs to format the drive. If you have formatted the drive as a linux partition, such as ext2, ext3, or reiserfs, it is likely that Windows will not see it as a valid drive.
Jun 02, 2009 | Electronics - Others
Tried to password protect my Freecom 8GB memory stick. After the process which took about half an hour, the stick could not be accesses, but could by formatting. I did this and now the stick is only 8MB....
I'm not sure what you have done but.
Right click my computer
select manage
on the left side of the computer management window
see disk management
now on the right side where the disk management is open
find the usb drive from the list of drives, right click on all paritions of the usb drive and select delete partition, ones all parititons are deleted right click in the empty space and create a new partition.
it should work as normally, normal size.
Aug 11, 2008 | Computers & Internet
1989-1991 Peugeot 405 Antenna, 89-91 Peugeot 405 Replacement Logo
29 people viewed this question
Top Replacement Antenna Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Replacement Antenna Vehicle Part and Accessory Expert? Answer questions, earn points and help others
