Question about Samsung 997DF 19" CRT Monitor
HELP FOR CIRCUIT DIAGRAM
HELP ME THE CIRCUIT DIAGRAM OF THE TWO IC'S ie TDA4858 AND TDA4854 THE REPLACEMENT.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
VMS 4.1 Circuit Diagram (Power Supply)
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams to many popular brand TVs and other devices are given. Hopes it will hep you. Good Luck.
Aug 20, 2015 | Televison & Video
Bpl prima 18hd2 tv circuit diagram
Type in the brand name or the IC number used with your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 06, 2015 | Prima Televison & Video
I have a problem with tcl model 2027u. The vertical ic easily gets hot and will explode after several minutes. All the voltages in the vertical circuit seems to be normal. I replaced the def yoke, the...
I don't have the circuit diagram in front of me, but I would suspect a shorted or leaky capacitor in the output circuit. Another possibility is that the heat sink is inadequate or something is amiss with the thermal interface between the IC and heat sink.
Is the vertical waveform normal? Put a convergence pattern up and see if the grid is linear from top to bottom. This could give you a clue.
Mar 11, 2011 | Televison & Video
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to ...
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position ,please to help of rectivied this problem and send circuit diagram and IC pin configaration thanking you sir
Mar 03, 2011 | Televison & Video
Blown resistor and IC
R91 is a 1K Ohm
M1 is FSDM0356
Jul 15, 2010 | Technics SA-AX530 Receiver
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
Set has power, but fails to turn on
Your going to need a schematic diagram and some troubleshooting skills here or a quilifyed repair person. This set has several power supply problems as well as sweep dirived power problems. The biggest problem is the STR (I dont remember the other #'s)(ie- STR#####) regulator IC It is alway the first thing that goes bad in these chassis. Now do not get a general replacement as it will blow out as soon as you turn on the set. I've been through this and a half a dozen regulators till I relized that the replacement ics do not have one last digit on the ic that the original did have!! and that one last digit made the ic completely differant. Another common problem here would be The Two filter capacitors off the sweep derived 15 or 18 volt lines Good luck to ya.
Apr 22, 2006 | Toshiba TP55H60 55" Rear Projection...
Samsung 997DF 19" CRT Monitor Logo
218 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
