Question about Sansui Televison & Video
How to hook up headphones to HDTV sansui hdlcd4050c
Want to hook up a philips sound bar to my t.v. what cable do I need and where do I plug in at
Which model TV and which model sound bar do you have? Some Sansui TVs have a coaxial digital audio port and a 3.5 mm headphone port; this is true for the SLED2480. Some of the smallest Sansui TVs may only have a headphone out option or no audio output. These jacks will be on the back or the side depending on the model. For some Sansui models, these will be easiest to see when you put the TV on its face (on a clean soft surface) and look next to the base of the TV.
The Philips CSS2123B/F7 has a digital coaxial port, a digital optical port and RCA analog inputs on the back of the unit. It also has a 3.5 mm input on the right side for connection with auxiliary devices (like a headphone out). Other models may have different ports.
Thus the cables you need will depend on the specifics of your devices; similarly the locations of the ports will depend on the models. If your TV only has a headphone out and the soundbar has analog audio inputs, you will probably want a 3.5 mm to RCA audio adapter. There are several options depending on whether you want to use an 3.5 mm audio cable or an RCA audio between the TV and the soundbar. (Pick a cable and then get the adapter to plug into either the TV (M 3.5 mm to RCA FF) or the soundbar (2 RCA MM to 3.5 mm F).) There are 3.5 mm M to RCA MM cables as well.
If your TV has an digital audio outputs, get the correct cable (optical or coaxial) and connect that to the port on the sound bar and TV.
Please add a comment with the model of your TV and soundbar for specific information. I hope this helps.
Nov 30, 2013 | Sansui Televison & Video
Sansui HDLCD4050C 40" TV -Horizontal Lines bottom half issues. What is wrong?
It sounds that the vertical output section has the fault. Contact any service technician. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jul 14, 2013 | Sansui HDLCD4050 TV
How can I hook up headphones on my Sony Grand Wega 60" TV?
There are wireless units on the internet that can be connected to most sets--do some research with Google.
Dec 09, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
Is it possible to connect this model of wireless headphones to a Samsung HT-C5900 Home theatre system?
So long as there's a regular 3.5mm headphone jack on the Samsung home theatre system, then yes they should work. If not, I would try hooking them up to your HDTV directly.
Mar 02, 2011 | Philips SHD8900 Wireless Headphones
How do use a sansui hdtv as a computer monitor. I've already hooked up the vga cord. but I need step by step instructions of how to set it up with my remote
If you are trying to get your remote to control your computer, that will not work. The remote for your Sansui will only run the TV.
Jul 06, 2009 | Sansui Televison & Video
Sound quality/ connection to tv/ audio problems
The sound quality from an HDtv could very well be better than from a lesser-quality TV. The sound from the headphones can only be as good as the signal that feeds it.
Apr 26, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
I have an old Sansui au999 amp
you can go about this many ways.depending on what you have to work with.are you useing a satilite or cable box?if so assuming they have audio/video out just send the audio to the amp and the video cable to the tv.u could use the aux or the tape in.just put the dvd in the other input aux or tape in.dont matter which.if you dont have a cable box your tv must have some kind of audio out to run to the amp.it can be a rca out or simply a headphone jack.you will need a headphone jack too rca plug cable if you have a headphonejack on your tv.hope i could be of help.
Jan 05, 2009 | Sansui Audio Players & Recorders
Televison & Video Logo
22 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
