Question about Refrigerators
Condensation moisture - Refrigerators
About once a week, I have to unplug the bottom end of the condensate tube on my high efficiency furnace and let the water out, then do a reset so the furnace will run. Why is this happening and how do I...
Condensate drain plug? New to me. Remove the plug and put a 5 gal. bucket to catch the water and remember to drain the bucket, so the furnace won't trip.
When hot plenum is not set hot enough, moisture will condensate on the heat exchanger. This moisture is acidic. It could be your hot plenum temperature needs to be raised to avoide frequent moisture problem.
By the same token, heating and air cooling removes moisture from the air and air needs moisture to feel warm or cool. Dry air is not desired.
Jan 05, 2015 | Heating & Cooling
How do I fix/clean moisture dew condensation on my sony hdr-pj10 camcorder projector
Try putting it in a container of uncooked rice for 24-48 hours. The rice will draw the moisture out.
Jul 01, 2014 | Sony Handycam HDR-PJ10 Camcorder
I have condensation coming off the refrigernt tube that runs from condenser to freezer also ice build up on inside to the point of tearing the metal on inside back panel. What causes this ?
A side door heater is already defective.
It has heating element, it is there to dry any moisture build up around freezer door.
When it become defective, moisture or condensation occur, hence moisture is there.
Causing it to rust build or develope on the metal of the freezer.
Rust weaken the metal and soon tearing it.
Have it check by a service technician before it getting worse.
Good luck.
Jun 26, 2011 | Frigidaire 14.1 cu. ft. Upright Freezer...
It says that a moisture condensation has occured on my sony handycam
put it under sun light,for the moisture condensation, that will go,try it.
Mar 08, 2010 | Cameras
Asko dryers
Akso makes "condensing" dryers (Models T721 and T781) that condense the moisture wich then is directed to a drain. The T701 is a vented style dryer so I'm a little confused.
Dec 15, 2009 | Asko T701 Electric Dryer
Condensation around refrig walls
Either the door gaskets are not sealing properly or the doors are not completely sealing. The moisture is from air entering the refrigerator and the moisture in the air condenses into water. Check your doors and gaskets for leaks or gaps.
Sep 14, 2009 | Refrigerators
Stopping condensation inside refrig.
Condensation occurs when air is entering the refrigerator. There is moisture in air and the when the air gets in the cool refrigerator temp condenses the moisture in the air into water. So basically you have a gasket that is not sealing or one of the doors is not completely closing, or possibly it could be from constant opening and closing in a large family or kids getting stuff in and out all the time.
Sep 10, 2009 | Kenmore Refrigerators
How can I avoid camera moisture condensation on my Sony a1e camera, it keeps saying turn off for one hour or eject tape and is doing this constantly.
Camera gives Moisture error sign if it really have moisture condensation inside or its moisture sensor itself got defective.
if moisture is inside, blow hot air in camera mechanism for 5-6 minutes by hair dryer (not so closed with mechanism) and check / test.
If problem still exist it means moisture sensor is defective and i know its Sony high-end model camera and know how to fix it yet I would recommend to take camera to Sony Service center for proper repair.
Dec 06, 2008 | Sony HVR-A1E HDV Digital Camcorder
Sony TRV120 Won't load tape C21:00 code
From the user manual ...
Under self diagnosis display
C21:00
Moisture condensation has occurred.
Remove the cassette and leave your camcorder for at least 1 hour to acclimatize. (p117)
On p117
If your camcorder is brought directly from a cold to a warm place, moisture may condense inside your camcorder, on the surface of the tape, or on the lens. In this condition, the tape may stick to the head drum and be damaged or your camcorder may not operate correctly. If there is moisture inside your camcorder, the beep sounds and the [picture of water drip] indicator flashes. When the [end tape icon] indicator flashes at the same time, the cassette is inserted in your camcorder. If moisture condenses on the lens, the indicator will not appear.
If moisture condensation occurred
None of the functions except cassette ejection will work. Eject the cassette, turn off your camcorder, and leave it for about 1 hour with the cassette compartment open. Your camcorder can be used again if the [water drip] indicator does not appear when the power is turned on again.
Note on moisture condensation
Moisture may condense when you bring your camcorder from a cold place into a warm place (or vice-versa) or when you use your camcorder in a hot place as follows:
- You bring your camcorder from a ski slope into a place warmed up by a heating device.
- You bring your camcorder from an air-conditioned car or room into a hot place outside.
- You use your camcorder after a squall or a shower.
- You use your camcorder in a high temperature and humidity place.
How to prevent moisture condensation
when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and tightly seal it. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature (after about 1 hour).
Dec 06, 2008 | Sony Handycam DCR-TRV120BT Digital...
Condenser Dryer Still Filling Room With Moisture
all dryers produce moisture. thats what hapens when you heat wet cloths up. the dryers job is to remove the moisture to dry. thats how the automai]tic cycles work by deteting the moisture in the exhaust. i will say there is nothing wrong with your dryer. only thing i dont understand is the containers of water?
May 13, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
