Question about Frigidaire FEF366BC Electric Kitchen Range
I was cooking squash at 400 degrees and then the oven flashed F1 code and won't turn off the heat. I unplugged and plugged it back in and the heat remains on.
  • Frigidaire Master
  • 3,361 Answers
Replace the electronic control.(ERC) (clock).
Posted on May 21, 2009
F1 error code
I think that your heating element might be going out on you. Or maybe unplug it and let it sit for ahalf hour and then plug it back in.
Jan 02, 2013 | Kitchen Ranges
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
LG RANGE LRE30451SB GETS ERROR CODE F1 AFTER OVEN CLEANING AND WILL NOT FUNCTION
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 18, 2010 | LG LRE30451 Electric Kitchen Range
I have a cook essentials 6qt digital pressure cooker - I got an error code E1(or F1) but there is no troubleshooting guide in the manual - does anyone know what this means? My email...
Same thing.I put a frozen pork roast in like I have before but I then put the rub on and added cold liquid. Normally I rub first then add to pan. I kept getting E1 code. My wife got on here and read this so I put the pan with the meat in the oven for 3 minutes to warm it then put it back in the base.It started and is working just fine.
Jan 07, 2010 | Cook's Essentials Cooks Essentials Arome...
I tried to cook a frozen pizza in my Tappan electric range last night (which required it to be preheated to 400 degrees) and it would not preheat at all, even after about a 3 hour wait. I just turned up...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153992&diagram_id=1251523#d1251523
your looking for part number 67 on that part breakdown
it is the bake element and if you inspect it im sure you will find it cooked or broken
befor you actually order the part take the unit out
unplug it
and inspect your wire connections to both sides of the element
Oct 17, 2009 | Tappan 30IN ELEC IGNa Oven
F1 Appears on Kenmore Electric Range
Sep 23, 2009 | Kenmore 90154 / 90152 Electric Kitchen...
Oven turns on by itself and F1 flashes on the digital clock
Without being able to look up the error codes for your model (number please!), I would guess that the oven control triac has shorted out or the relay is stuck on (I assume the oven runs at maximum temperature). In any case, the oven microcontroller knows something is wrong, so it says F1 and beeps for help.
Aug 10, 2009 | Kenmore Kitchen Ranges
F1-1 flashing in gemini electric range won`t let us use oven
&^TG
Jun 21, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire code F1
Rainbow, F1 could be one of three things. The loud pop doesn't sound good. 1. Shorted keypad-replace the control. 2. The control sensed a runaway oven temp. In this case you would have to ohm out the temp probe. 3. The control itself may have a shorted relay-replace the control. The temp probe should ohm at approx 1100 ohms at room temp. Unplug the oven for one minute, if the code returns, first ohm the temp sensor (probe) if that checks ok, replace the control..Catriver
Nov 30, 2007 | Frigidaire FEF355 Electric Kitchen Range
Gas oven not heating to temp
The fault is either the capillary has fallen away from back or it is a faulty thermostat.
Regards
Advisor
Nov 17, 2007 | Ovens
Frigidaire FEF366BC Electric Kitchen Range Logo
206 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
