Question about Coffee Makers & Espresso Machines
Keurig leak bottom - Coffee Makers & Espresso Machines
How do I remove then casing from Keurig K10 manufactured in 2014 water leaks from the bottom
I have taken apart a Keurig and most items are not serviceable but remove the screws on the bottom and follow your water lines and see if one came lose or is leaking.
Dec 02, 2017 | Keurig Coffee Makers & Espresso Machines
Why is my keurig 560 leaking water from the base
Most likely the water lines inside your unit are leaking. If you can take the bottom of B60 off and look inside the unit. Usually, the line that comes off the water pump is leaking at the T connector. If not leaking there look for other signs of leaking while the bottom is off. You can call Keurig 800 number to see if your unit is still under warrenty. Hope this helps.
May 28, 2014 | Keurig B60 Coffee Maker
My Keurig leaks from the bottom, it's a pain.
You may have water in the holder that supports the CUP. It needs to flushed as it has a limited area for maintain the overflow.
Mar 12, 2013 | Keurig Platinum B70 Coffee Maker
My keurig is leaking from bottom
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Oct 02, 2011 | Keurig B60 Coffee Maker
I have a puddle of water that is leaving out of the coffee maker from the bottom. (underneath)
Here's what I discovered about my Keurig B60: The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Aug 28, 2011 | Keurig B60 Coffee Maker
My keurig leaks from the bottom only when brewing coffee. Can it be fixed?
Here is a tip that I wrote about Keurigcoffee brewers and the Keurigleaking problems
Keurig OneCup Coffee Brewer leaking
heatman101
Jul 17, 2011 | Keurig B50 Coffee Maker
Coffee maker leaks from the bottom somewhere. Any suggestions?
heatman101
May 22, 2011 | Keurig B60 Coffee Maker
My Keurig Platinum B70 is leaking. When I put the water reservoir on to the coffee maker, water seeps out the bottom where the reservoir sits into...almost like the little valve in the reservoir stays...
Apr 23, 2010 | Keurig Platinum B70 Coffee Maker
Permanent Keurig filter leaks
Are you using the my k-cup with the Keurig pre-filled K-cups? If so it won't work. There must be a needle on the top and bottom of the K-cup for this machine to work. The My personal K-cup does not have a needle in the bottom. It's only to be used for filling with your own coffee.
Sep 17, 2009 | Keurig B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
19 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
