Question about iLive Bluetooth Speaker System
I just bought an IHB23B, I can play my music through my phone but i would rather it came from my computer. How do I connect the speakers to the computer so I can play my music?
IHB23B speaker system. I want to play music from my computer and not my phone. How do I do that?
I have purchased 2 of these speakers. I want to Bluetooth connect them to my iphone. How do I do this and get music from both speakers?? Thx
If you have purchased Speakers with Bluetooth Connectivity capability you can do this by switching on the speakers and on your iphone use the Bluetooth Pairing Option from Bluetooth settings to establish connectivity and play music to hear from speakers
Jun 15, 2015 | Audio Players & Recorders
Speakers wont come on
Lets start with the basics.
1. Make sure the power cord to the computer speakers are plugged in. Check at the wall and make sure the power cord is connect to the back of the speaker. If there is a power button make sure it is pressed in the on position. Make sure the volume level is turned up.
2. Check the computer and make sure the sound is not on mute. Turn the volume level up from the computer settings.
3. Try playing some music. If you hear sound you are good to go.
4. If you are not able to hear anything than continue. I would suggest plugging your speakers into you cell phone. Try playing some music from your cell phone.
5. If music plays through the speakers from your cell phone, something is wrong with the computer. If no sound plays with your cell phone then something is wrong with the speakers.
6. If worse comes to worse bring your computer into a computer store. Tell the salesman you want to buy a new set of speakers. You just want to make sure your computer works with the speakers before you buy them.
7. If all else fails, ask a local tech you trust.
May 25, 2015 | Audio Players & Recorders
Still need to know how to download music from cell phone to the Omnitech Bluetooth speakerphone everything else works except for music playing on my bluetooth
You do not download music from your cell phone to your Bluetooth speaker. You pair and connect your cell phone with the speaker via Bluetooth and when you listen to music or make phone calls on your phone the sound comes out through the speaker. Please read the instructions on how to connect the phone to the speaker.from the set up guide that came with the speaker.
Jan 03, 2015 | Cell Phones
How to connect to computer
I do not have a solution...i have a problem. I do not want to hear my music through my phone i want to hear the music on my computer. How do i connect the IHB23B BlueTooth system to play on my computer? thank you
Dec 16, 2013 | iLive Bluetooth Speaker System
I just bought the aux cable to connect my I phone 4 to my cde-9881 alpine stereo but when I hooked it up my iPhone connects to the head unit but only plays music thru the speaker on the phone. Why??
try playing your music first on your phone then with the cord alreay in your radio, plug it in to your phone....If that doesnt work, might be a setting on your radio....is it on aux in????
Mar 17, 2012 | Alpine Car Audio & Video
Sound not coming out of the speakers
Check your sound settings on your computer
Check to amke sure your speakers are muted by the computer
Check to see if the volume is down or muted on the program that is playing the music
Sep 04, 2008 | Manhattan 1100 Computer Speakers
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
No sound
check the plug that goes directly to the altec box. or it could be the wire is the culprit..
Apr 08, 2008 | Altec Lansing VS4121 Computer Speakers
Speakers Buzzing Whilst Playing Music
sounds like interferance try moving the speakers around maybe away from the monitor and try turning off any thing elec around your pc to find out maybe what is causing this
Dec 01, 2007 | Philips MMS 460 Computer Speakers
Speakers do not work
yes thats the fact when you plug a headphone into any speakers the head phone will be the only one to function the speaker stops thta the circuit technically which will break the connection of power to speaker if you plug head phone
Jun 29, 2006 | Logitech X-230 Computer Speakers
iLive Bluetooth Speaker System Logo
54 people viewed this question
Top iLive Audio Players & Recorders Experts
cwradio73
Andrew Taylor
Andrew Taylor
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
