Question about Canon Office Equipment & Supplies
Paper jam alarm light blinks, window displays "rec. paper jam" - doesn't seem to be any paper hung in machine
  • 407 Answers
Open the paper tray and remove the first couple of sheets of paper - If the paper tray is fully loaded leave it half full.
Posted on May 21, 2009
Alarm button is blinking and paper is not fed in machine
You need to look at the display (LED window) to see what is displayed. It will give you an error message such as "Clear paper Jam," etc. If nothing is displayed, press the "Resume" key to the left. The light should go off.
Jan 22, 2011 | Canon MultiPASS F80 All-In-One InkJet...
MF5500 Paper Jams Everywhere
check the paper ,from cassete tray to the drum and exit,on every section you have a sensor,check it ,
Feb 29, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Brother HL 1250 Laser Printer Alarm light blinks at same time as ready light and printer does not print - why?
I have saeen this happen and there is usually a paper jam somewhere in the machine. Remember, it doesn't take much of a piece of paper to jam. Use a flashlight and look inside your printer closely. Also check your toner supply level.
Oct 02, 2010 | Brother HL 1250 Laser Printer
Machine won't print, copy or receive a fax
With red button stop the copy, or switch off and on.
If you print on this unit make sure that you did choose a right format of paper (A4,A5,...)
You can change the format ap printer properties or preferences
May 21, 2009 | Canon imageCLASS® MF6550 Laser Printer
Rec paper jam message.
Normal 0 I suggest you get a sheet of Card Stock (Heavypaper) and place it in the feed way. Then press the printbutton applying a slight amount of pressure on the Card Stock so itwill feed through the printer. The reason for this is in some cases Ihave been able to clear the paper track of debris that was deposited thereover time.
Worth a try, as I have fixed a number of printers thisway, saving costly repairs.
Hope this helps. Bud
Jan 27, 2009 | Canon Laser Class 8500 Printer
The alarm light is blinking. We have unplugged it and it's still on.
alarm flasing can be more than one thing. check to see if alarm is representing a symbol on fax machine. It can be jammed paper inside, or toner/ ink run out.
Dec 15, 2008 | Canon Office Equipment & Supplies
Not working
Pull out the tray with paper.
You should find a moving plastic "tongue" near the middle of width in the area where your paper tray should go. It's a contact based flag for the device to consider how much paper is in the tray. Check if it's not broken or stuck in odd position. Move it back and forth several times, with no force, it goes very easily. When you lift the flag up, see message and blinking led stop appearing. Try to pull paper tray back in, add paper if error appears again. Enjoy!
Sep 15, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Rec . paper jam
This means your rollers are either dirty or damaged. The same thing happened to my Lexmark printer and they told me to clean the rollers. Nothing happened it still was messed up so they just sent me a new one...
Dec 13, 2007 | Canon FAX-L350 Plain Paper Laser
Won't feed the paper
the problem with your machine maybe that the default paper size programmed into your machine. My guess is that it is set to legal size{ 81/2x14} Get your owners manual out and see how to program the paper size in the user settings sections.
Jan 18, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
285 people viewed this question
old marine
old marine
