Question about ASUS Computers & Internet
Enable keyboard cannot get the numbers for the 10 key to turn on
2 Suggested Answers
  • 309 Answers
SOURCE: sony - the secondary numbers on my keyboard are
There is a key on the top row of keys just to the left of the backspace key that should have NUMLK or NUM Lock on it. Try pressing this key once to unlock the number pad.
Posted on Jan 04, 2010
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
Lenovo p580 numlock off
What options have you tried ??
Number Lock on IBM Laptop Computers b> Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
Try to locate the function key. On a T-series ThinkPad, it's in the lower left hand corner. It should be labeled "Fn," and the lettering may be blue, green or red instead of white. If your laptop lacks a "Fn" key, use the "Shift" key for Step 3 below instead. Locate the key labeled with "NmLk". On a T-series ThinkPad it shares a key with "ScrLk" which sits on the very top row between the "PrtSc" and "Pause" keys. On other IBM laptops, the "NmLk" key might share a key with "Delete." While holding down the "Fn" key or the "Shift" key, depending on your model, press the "NmLk" key. This should turn off Number Lock and restore your keyboard to its usual state. Number Lock on an IBM laptop is a "toggle" setting. You can turn Number Lock on by following the same steps.
also Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
Jan 30, 2013 | Computers & Internet
Laptop keyboard
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Aug 07, 2012 | HP Pavilion Computers & Internet
Left side of keyboard 123456789 is not working
Do you mean the right side of the keyboard is typing numbers instead of letters?
If so, you have enabled the NumLk which turns the RHS of the keyboard into the number pad.
Press the NumLk key near F11, F12 function key and the NumLk LED will switch off and return your RH keys back to letters.
Jun 15, 2012 | Toshiba Satellite L500 Series Notebook
Laptop types numbers instead of letters
Hi!
You have enabled NUM LOCK. Press button "fn" and find another button with blue tag "Num Lock". Pres both buttons at once.
Hope it helps
Jul 10, 2011 | Dell Inspiron Mini 10 Notebook
Please help. The 789uiopjkl;m./ keys have keypad numerals on the front bevel. when I try to type "uio" for example I get "456" and "jkl" gives me "123". To get the...
The number lock feature is enabled. You should see an indicator for the Num Lock (lit when on) that is next to the Caps Lock indicator.
You should be able to disable the lock by pressing Fn and Num Lock together on the keyboard. (On some Sony Vaio keyboards, type CTRL+ALT+NumLock or Shift+NumLock.) The number lock should be at the top of the keyboard near the F1-F12 keys. Sometimes the key is shared with the Scroll Lock function (otherwise it will be nearby). It's really easy for the Number lock to be enabled on some Sony keyboards; just some dirt between the keys can enable it when you didn't turn it on intentionally.
I hope this helps.
(I don't have the VGP-WKB1 wireless Sony keyboard and can't find a good picture of it to find the Num Lock key for this model.)
Jul 08, 2011 | Sony VAIO VGP-WKB1 Keyboard
When my number lock is on the letters will not print as stated they will print a number or other
This is normal for a keyboard with embedded number pad, rather than a separate 10-key area. Turn off the number lock to type the alphabetical characters and use the top row of numbers to enter values. Turn on the number lock when entering only a long string of numbers.
Alternatively, connect a USB external keyboard to the notebook. Either get a large keyboard with a separate number pad or get a 10-keypad only (http://www.cyberguys.com/product-details/?productid=37379 ). Then you can have a normal keyboard and stil have the 10-key functions without toggling the NumLock often.
I hope this helps.
Jun 11, 2011 | HP Pavilion DV9620US Notebook
I would like a manual for the latitude D610 keyboard to know how to use the symbol that are highlighted in bleu
In the lower left hand corner of your Dell Keyboard -- you will see a Blue Key labeled -- "Fn". This key allows you the use of ALL of the other blue labeled keys on your keyboard. You must press the FN key and the other "blue" key at the same time for them to work.
The keys on the right side of the keyboard with the blue numbers on them are controlled by the Numlock key and Fn key. The light at the top of the keyboard near the power button, with the number "9" inside a picture of a lock, will be lit if the Numlock is enabled.
You may need to press the Fn key to type numbers even if the Numlock is turned on. There is a setting in the BIOS called Enable Keypad and if you set it to By Numlock you will not have to hold down this key to type a number.
If you are still having trouble with these keys, please see the general keyboard troubleshooting guide
http://ftp1.us.dell.com/diags/R65848.htm#Key not responding or typing wrong character
Jan 13, 2010 | Dell Latitude D610 Laptop Computer -...
JUST HLP PLEASEEEEE
Sounds like your keyboard is sticking
Unplug the keyboard and do the following
Look on the bottom you should see some screws, remove the screws and leaving the keys facing down, pop the two pieces apart.
Leaving the electronics aside you can now continue with the following instructions
Ok, once you have the two pieces, all of the keys should stay in there proper place, take and soak that in the sink with some soap and water.
Moving all the keys to get the water to flow through.
Then dry off the Keyboard and vacuum all the excess water off, then replace and screw back together, you should be good to go.
I wouldn't recommend a dishwasher, this could get to hot and melt the keys
Apr 24, 2009 | Gateway 2520796 Keyboard
KEYBOARD NUMBERS
There should be a button called "numlock" which will enable to you use the keypad to the right of the keyboard, however, you don't need to "lock" the keyboard to use the numbers on the top row.
Apr 15, 2009 | Dell 0Y3740 Keyboard
Computers & Internet Logo
27 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
