Question about Oreck Vacuums
Something stuck in vacuum cleaner
The cleaner turns off after a few seconds and the stuff isn't going into the bag, just accumulating by the beater bar
reddevil6
  • 1673 Answers
SOURCE: beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Posted on Jan 15, 2008
SOURCE: beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Posted on Jan 01, 2009
  • 3600 Answers
SOURCE: The beater bar won't come back on.
Did you replace the beater bar belt?
Posted on Jun 13, 2009
Vac Belts
  • 701 Answers
SOURCE: DC 17 Beater Brush won't turn
You need to replace the belt. Here is the belt you need and a manual you can view which has instructions:
Dyson DC17 Belt and Manual
Posted on Feb 07, 2010
  • 231 Answers
SOURCE: Dyson vacuum DC17 beater bar won't turn
sounds like the brushroll motor has gone bad. disassemble the head and check the continuity on the brushroll motor
Posted on Feb 27, 2010
I have a eureka 4D boss vacuum that won't go into barefloor mode and has no suction in carpet mode
turn the beater head over and see if something is stuck ours was totally plugged with stuff till I cleaned it last week for wife .
Dec 24, 2015 | Eureka Vacuums
What is wrong with my vacuum cleaner when it want pick up and it blow the trash back out
Sounds like you might be hitting the reverse button some vacuums have. Otherwise there's stuff getting trapped in the space above the beater bars and when you lift the vacuum while it's running, this trapped trash has an opportunity to get out now that there's no pressure from the floor. You might want to check and make sure there's nothing stuck in your tubing that's preventing things from going into the bag. My wife use to suck up gum wrappers and half sheets of paper and it would clog up the hose. I'd have to use a broom stick of wire coat hanger to unplug this.
Aug 29, 2014 | Kirby G10 Sentria Vacuum Cleaner...
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
What does a flashing light on the dc28 vaccuum mean
There are a few things a flashing light could mean. One is that the beater bar has something stuck on it. Or, it could be that the bag or canister is full. Then again, maybe something is stuck in one of the intakes. Be careful when checking the beater bars. Unplug the vacuum before touching them, you wouldn't want your hands getting injured or fingers broken:( Clear anything that is wrapped around the beater bars, hair, string, etc., and then check the hoses to make sure nothing is stuck in them. If you have suction, the interior is clear. If not, then check in there to make sure nothing is clogging it. Good luck and be careful:)
Jul 23, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Kirby G series won't turn on
COntrol of the connection of the bag at the bottom of the machine that must be against the housing rotated are, there is also a microswitch used for safety, but there is a second micro switch that sits in front of the vacuum cleaner housing near the air intake as a push button which is operated next near to the hoseconnection by a pin.
Feb 10, 2014 | Kirby Ultimate G Bagged Upright Vacuum
The beater carpet cleaner is not turning
You may have a broken belt. Hope this gets you going in the right direction.
May 28, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
The motor spins but the belt will not move, therefore the rubber on the belt burns right where it is attached to the motor.
Sounds like your carpet beater roller is jammed up, probably with hair or string, in most cleaners you can remove the roller by taking the cover off below the brush. Remove the roller and clean wrapped uo stuff
Dec 06, 2009 | Oreck XL Ultra Bagged Upright Vacuum
This vacuum keeps getting clogged in the hose and has terrible suction. The women who helps clean my house won't even use it as it performs terribly. Any suggestions
check vac air filter(not the dirt collection bag) also something could be lodged in hose mechanism so there is always a partial restriction. make sure the beater bar is not set too low. check the dirt that accumulates in bag to see that there is not an excess number of carpet fibers in there. beater bar should be clean and spin freely.
Oct 10, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Hoover U6476-910 - Very little suction from the bottom
If you haven't already, remove the beater bar. This is accomplished by unplugging the vacuum and turning it beater bar up. Remove the clips or screws that hold the plate on the beater bar and set aside. The beater bar sits in sockets, so carefully remove the bar, noting the correct position of the sockets. This will make reassembly much easier. Slip the beater bar out of the drive belt. Now, inspect the suction cavity that the beater bar would discharge into. Usually, things clog up here as there is a flex hose that catches things, creating a pluggage.
Hope this helps, --W/D--
Jul 18, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Vacuums Logo
14 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
