Question about Watches
ATHM8265 manual Need to set and disable alarm and chime for ATHM8265 watch
SOURCE: Armitron Pro Sport Watch Hourly Chime
Based on insructions for another watch, I just figured this one out. The steps would be:
Get in Alarm mode (press mode button)
Then you can cycle through the following by pressing the ST/STP button
1. Alarm on
2. Chiime on
3. Alarm and Chime on
4. Alarm and Chime off
You can see this with a magnifying glass and watch the center and right hand circular icons at the top of the display.get highlighted.
Posted on Jan 16, 2009
  • 9 Answers
SOURCE: need to set alarm on my watch
It should have a CAL number engraved on the watch back and using this you can find instructions for download at www.accurist.co.uk under the after sales service area and downloads option
Posted on Jun 18, 2009
SOURCE: replaced battery- alarm won't chime anymore even though "ON"
I removed the battery myself, and underneath are 2 metal prongs. One was bent down and not touching the battery. I pulled both of them up so they would touch the battery, and now it works fine.
Posted on Aug 26, 2009
SOURCE: Timex 1440 sports wach chime disable
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
Posted on Sep 27, 2009
Aqualite stopwatch manual
To change the alarm settings on the Aqualite Men's Analog/Digital Watch, press the bottom left "Mode" button until you find the "AL" word next to your alarm time. Then let go of that button. Then press the top right (Start/Stop) button one, two, three, or four times to select your options (alarm on, alarm and chime on, chime on, alarm and chime off)
Jun 03, 2012 | Watches
I have an aquatech watch and don't know how to set it.
Thank you for contactng FixYa.
Setting the Time and Date
  • To set the time and date on your Aquatech watch, begin by pressing the "Mode" button three times to access the time setting screen. Use the "Lap/Reset" button to set the hour on your watch. Use the "Start/Stop" button to advance the numbers to reach the correct hour. When you've set the hour, use the "Lap/Reset" button to set the minutes, using the "Start/Stop" button to advance to the correct minute. Repeat the procedure to set the seconds, month, date and day of the week on your Aquatech watch.
  • Setting an Alarm
  • To set an alarm on your Aquatech watch, begin by pressing the "Mode" button two times to access the alarm setting screen. Use the "Lap/Reset" button to set the hours place, using the "Start/Stop" button to reach the correct hour. Repeat the same procedure to set the minutes for your alarm. When you have finished setting the alarm, activate it by simultaneously holding the "Lap/Reset" and "Start/Stop" buttons until the alarm icon appears. When the alarm sounds, silence it by pressing the "Lap/Reset" button.
  • Deactivating the Hourly Chime
  • Many Aquatech watch models feature an automatic hourly chime. This can be inappropriate and inconvenient in many situations. To deactivate the hourly chime on an Aquatech watch, simply press and hold the "Lap/Reset" and "Mode" buttons simultaneously. After you have correctly deactivated the hourly chime, the hourly chime indicator icon will disappear from the watch's main screen.
  • Best regards. Jewel
    Sep 18, 2010 | Watches
    How do I turn off the hour chime on a ess watch ?
    Press and hold the bottom right button; this displays the alarm. At the same time, press the bottom left to toggle the hourly chime. When the chime is enabled, the 'day of week' display at the top of the dial will show all days as selected. When the chime is disabled, no days will show as been selected.
    I have one of these watches and it took me a while to find this out!
    HTH
    May 17, 2010 | Watches
    Setting a 1440
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, please
    Mar 15, 2010 | Timex 1440 watch
    Aug 30, 2009 | Timex 1440 Nylon watch
    Roxy 70's watch alarm goes off every hour. I
    This manual will help http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
    I think these are the directions you need 2.0 Alarm and Chime On/Off 2.1 In Normal Display hold B-Button,and push A-Button once: Chime will be on. 2.2 push A-Button once again: Alarm will be on 2.3 push A-Button once again: Chime will be off 2.4 push A-Button once again: Alarm will be off 2.5 Release B-Button, the Display changes to Normal Display immediately.
    Jul 13, 2009 | Watches
    Need to learn to make adjustment on my watch
    Setting CASIO G-Shock Watch
    1) Home City
    2) Home city and Setting the digital time
    4) Alarm set/on/off
    5) Snooze
    6) Hourly Chime
    A -- B
    ( ) Button reference
    C__ D
    1) Select home city first (if equiped):
    Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
    Press C until timekeeping mode is reached. (makes higher pitched beep)
    2) Set time, Date, etc:
    Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
    4) Alarm set/on/off
    Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
    To stop any alarm, press any button.
    5) Snooze (SNZ):
    Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
    To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
    6) Hourly Chime (SIG):
    Press D to select hourly chime (SIG). Press A to toggle chime on and off.
    May 11, 2009 | Watches
    1. Alarm on
    2. Chiime on
    Dec 26, 2008 | JCPenney Armitron Sport Link Bracelet...
    Innovage Gear wristwatch beeps every hour
    To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
    Mar 11, 2008 | Watches
    Watches Logo
    54 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
