Panasonic sa-dt310 fault 61 showing
  • 4 more comments
  • Anonymous Dec 06, 2007
    When turned on it reads:
    "Reset DVD"
    "F61"
    The system then turns off.
    I have tried shutdown all power & disconnect - then start up again and also checked and re-connected all cables, especially speaker cables. (As the book says i"F67" is a speaker cable short out problem)
    The player still does same thing as described above.
  • Anonymous Feb 19, 2008
    all same
  • lozy Apr 04, 2008
    i have just trned my paansonic sa dt310 on and it came up with f61. have tried disconnecting and checking all wires no luck there. it did make a whirring noise yesterday but stopped so didnt think nothing of it.
  • Anonymous Jul 01, 2008
    i turn the power on and it comes up with "f61" and then says dvd reset. i have tried turning it off and on and un plugging it. but it doesnt sound like its working properly?
  • drewzer Jan 23, 2009
    UPON START UP I GET CODE F61 THEN IMMEDIATLY SHUTS DOWN AND I DONT KNOW
    WHERE TO START TO FIX I PAID $500.00 LESS THAN A YEAR AGO AND GOT IT
    REFURBISHED AND GOING TO COST ALMOST $200.00 TO SEND TO WARRANTY
    PROVIDER.
  • moravianphil Apr 19, 2009
    i have this problem too. can't even work out how to open the cae to check the fan. Has anyone managed to resolve these problems yet with the SA-DT310.
Same problem here. In my case, it's a problem with the fan. I solved this (for the time being...) by cleaning the fan.
Howto:
1. remove the 3 screws fixing the cover (at the back of your DT310);
2. the 2 side covers come off easily, but to release the (plastic) top cover, you need to push in the cover at both sides to let it come off the retaining hooks (take a closer look at the side of the top cover, you'll see what I mean);
3. remove the 2 screws holding the remaining metal cover, and move this cover backwards;
4. now you can check, clean or replace the fan.
Putting it back together should be easy now. ;-)
Posted on May 17, 2009
How to repair panasonic SA-DT310, F61 fault code, including how to remove casing for inspection of electronics.
Posted on Oct 09, 2008
    Loyalty:
    Visited the website for 30 consecutive days.
  • 321 Answers
Just had this problem for the second time having cleaned the fan over a year ago - a clean didn't work this time around.
The panasonic part is difficult to find and expensive so I replaced the 12V 100ma fan with a 40mm x 10mm silent type from ebay (
Posted on Oct 21, 2010
  • Sock Puppet Oct 21, 2010
    That should read £2.99 including postage - it works fine.
It is definetly the fan!
Posted on Jul 19, 2008
  • dkoffler593 Dec 16, 2010
    I spent a couple of hours searching for a suitable fan yesterday and you can either pay £17 and get a replacement original from Panasonic who gave me the number for Seme NEDIS Ltd or buy a slightly higher spec (0.13A versus 0.11A) 40mm 12V RG08J from Maplins for £6.99. it comes with loose wire ends so I simply cut the original two pin fitting about an inch away from fitting and then joined the loose wires of the new fan to the cut and bared ends of the wires coming out of the original 2 pin plug using electrical insulation tape. It works perfectly and runs silently. So total cost of fix was £6.99!
  • duffisrar
    duffisrar Oct 19, 2012
    i cleand the fan but still it showing the same problem f61 anyone can help me out here plzz :(
    New Friend:
I have just got mine to work fine now, after having the same problem. I turned on the unit, after 1 or 2 seconds, it would say 'DVD RESET', then it would say 'F61', and then just switch off.
I opened the amp, the fan looked clean. Closed the amp.
Then reconnected all speakers (from scratch) and now it's working fine. Some of the connections were frayed, so they had to be twisted again. I think the ehow site says to connect the copper wire to negative terminal, and silver to positive, but in the manual it's the other way round. Just to be clear, I've got:
copper -> +
silver -> --
Posted on Dec 17, 2013
I had the same issue, i opened up the unit and cleaned the fan and it works now. Thanks for your help
Posted on Jan 02, 2013
I've had the same problem, well, the F61 and turning of part. In my case it was the fan, so I'd suggest you'd check it, if its running properly.
Posted on Dec 16, 2007
Panasonic cd stereo system sa-ak87
F61 is a faulty amp IC - IC need to be replaced
Jul 28, 2014 | Panasonic Audio Players & Recorders
SA DT310 showing F61 and closing down
the F-61 code means your audio outputs are bad you must have it repaired
Dec 19, 2009 | Panasonic Home Theater System System
Panasonic cd player sa-ak75 showing fault 61 on display screen,machine will not fire up regards derek
check fan it might not be rotating.the fan should rotate when increasing the volume.check also the power module ic
Mar 06, 2009 | Audio Players & Recorders
Switching off of SA-AK-37 Music system
Do you have the manual, I think panasonic put some of there fault codes in the back.
Seems to have lots of people saying it could possibly be a power supply fault, an amp fault or shorted speakers.. Some people have gone to the extreme of actually buying new components and trying to unsolder and resolder to try to fix it themselfs.
Try contacting Panasonic, they will be able to advise you better ot possibly repair / replace the system.
Jan 31, 2009 | Panasonic SC-AK200 CD Shelf System
F- 61 keeps comming up
It probably needs repair of bad solder connections on the output or voltage ic's or replacment of one of them.
Jan 28, 2009 | Panasonic sa-ht800V Home Theater Audio...
Panasonic sa ht990 fault 61
This a memory problem ,try to look for the reset button and press it . If you can't find the reset button then the other option is unplug the unit for 24 hours the purpose is to dessipate or drain the charged current .
Hope it may help you;
Regards;
VOTIT
Jan 07, 2009 | Panasonic Home Theater System System
Error61 code
thats a "protect" mode..your audio outputs are stressed and overheating..will need to be replaced soon
Aug 26, 2008 | Panasonic sa-ht800V Home Theater Audio...
Error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
Aug 23, 2008 | Panasonic SC-AK640 Shelf System
Panasonic sa ht 540 fault 61
my panasonic sa ht540 starts up and then says f61 then goes to stanby
Apr 18, 2008 | Televison & Video
4,121 people viewed this question
 Grubhead
Grubhead
