Question about Denon AVR-1906 Receiver
Power transformer - Denon AVR-1906 Receiver
Can the two transformers be hooked in parallel to service a 500 W zone?
If you are talking about low voltage light transformers, then answer is probably NO... but you could try it and see if it works... but I am almost certain that both transformers will probably burn out.
Output is 12 Volt AC... the transformer coils will probably burn out because the waveform from each transformer cannot be guaranteed to be the same.... even if both transformers are seemingly identical and plugged into same outlet.
For additional information, read transformer installation tips on following page.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#install
Power company transformers can be wired together in specific ways to produce 3-phase waveform, but these transformers are specifically engineered for the task. And the transformers do not combine the output (as you would be doing with yard transformer), instead each power company transformer produces 1 leg of power in a 3-leg power supply.
http://waterheatertimer.org/What-is-3-phase-electric.html#transformer
Gene
Water Heater Timers Save Money
Mar 14, 2015 | Hardware & Accessories
Does a ATX power transformer makes the difference of watts of a power supply unit of a computer? Exactly I am planning to improve performance of my pc's ATX power supply unit. Trying to attach another...
NO NO NO... PC power supplies are switching supply's. The transformers use high voltage to drive other components. Increasing the power out of the supply will require you to upgrade the power supply to a higher wattage output.
Oct 23, 2013 | Microsoft Computers & Internet
My transformer on my new polar express does not work what am i doing wrong
No power to the transformer or to the track?
If not to the track, make sure you have the correct wire connections made from the transformer to track.
If no power to the transformer from the wall plug,
sounds like the cord needs replacement.
Dec 19, 2012 | Lionel The Polar Express Train Set
Transformer is not providing power to timer unit, power bulb is indictaing off power on screen. Have completly powered down and powered up. Model - pocket star 4 zone Thanks Dan...
The transformer is seams to be working, the power bulb indicator working tells me that the transformer is ok. You may need to check the circuit
board.
Jun 04, 2011 | Orbit Sprinkler System Power Source...
No power past what I think is the transformer? My gauge indicates there is power in the main power cord. Thank you.
Can you test to see if power is coming out of the transformer thing? If it's not it could have failed. Some transformer have an internal fuse. Unfortunately these are generally not replaceable so the transformer has to be replaced. Transformers are also safety parts, so have to be replaced by manufacturer's replacement parts.
Jan 31, 2011 | Crosley CR-84 Turntable
Power is not working complite seat dead
hi,
check the power cable first. also the power at the wall out lets.
if ok the you have to check the input ac fuse of your receiver. your recever has problem with its power supply stage, that's why there is no standby light also. fist of all check the fuse. then check the standby transformer is it faulty or not. the system will power up if the standby transformer is ok. standby transformer is a small transformer near the mains transformer. check these things first, if u need any further assistance feel free to contact me through fixya.
ok
Jan 24, 2011 | Pioneer VSX520 Receiver
Need a 110v power supply(power transformer) for my Bose Wave Radio AWRCC1. Where Can I get it?
if the secondary voltage of the transformer is 12 volts A.C. go to radio shack and they will have a transformer,though being it an aftermarket transformer it will work
Aug 01, 2010 | Bose Wave Radio
Replacement substitute for Fender Sunn power transformer 28-4150
I can't find a schematic that references the transformer and cannot find a replacement either. I'd contact Fender for a reccomended substitute.
Jun 22, 2009 | Music
I need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Dec 11, 2008 | Music
Buzz in amplifier power transformer. The amp is a Marantz Model 240. It functions perfectly well, and there's no noise from it in the speakers, but the transformer buzzes whenever the unit is plugged in...
All transformers buzz though you cannot hear it normally. The big transformers on power lines like to buzz for all to hear. When a transformer in a stereo amp gets old and deteriorates or gets hot and  expands the coils, melts the coil varnish and epoxy coatings then rattles at 60 times per second.    You can ignore it or change the transformer. There are too many layers of windings to try to stick anything in there.  Disconnecting a transformer results in inductive kickback -that's not money. It's a big, whopping electrical gotcha! Be careful! Good luck, Steve Medley
Nov 09, 2008 | Marantz Audio Players & Recorders
Denon AVR-1906 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
