Question about Sony Televison & Video
When guide plus loads overnight all prog numbers revert to same number. Can correct using editor but next overnight they revert to same number again
Recently purchased this RDR and done setup guideplus worked ok for about 2 weeks. Over the last week when Guide plus loads overnight from ITV host, all programme numbers are the same number usually 026. I then use editor to correct the programme numbers and guide plus then works correctly. However when in standby overnight again the guide plus loads again and yet again all programme numbers are the same, meaning I have to go into editor again to correct. This happens every night when in standby - ie EPG Guideplus loads but programme numbers revert to the same programme number for every channel. When in standby EPG comes up in the display now and again, tho I am sure that on one occasion I saw EPG Repair on the display. Appreciate any help you can give. Best Regards archie.sommerville@uk.thalesgroup.com
  • archie_somme May 22, 2009
    Forgot to say RDR is Sony RD-HXD995B
Fedarion
  • 33 Answers
SOURCE: loss of channels
If you mean "losing" as in you could no longer tune to those channels because they disappeared out of the channel list entirely, then it's likely a software problem.  If you haven't already, try resetting your DVR to factory settings (since this unit is TiVo powered, it should be under the main menu, Messages and Settings, then Restart or Reset system; follow the on-screen instructions to reset the system).
If you mean "losing" as in you can tune to the channel but there's no signal, then that sounds like a tuner problem to me.  If the box is still under warranty or you lease it, have it repaired or replaced.  If you bought the box and the warranty is up, it looks like you might have to get a new one, or pay for the repair out of pocket.
You might also try calling back to DirecTV tech support and asking to be escalated or to speak with a supervisor; especially if it's a box you're leasing from them, since it is definitely *their* problem in that case.
Posted on Oct 21, 2007
  • 51 Answers
SOURCE: DISH 311 receiver will not load Program GUide Info
this is a softwar issue which should be fixed, are you in AK????
Posted on Aug 19, 2008
SOURCE: Digivox DV3 cable box
press edit and go to bottom selection system instilation, press ok. type in 1004 on remote, nothing will appear till last digit entered. you will now see a hidden menu. there are three selections go to the bottom one and highlight, to the left another box says off use the right button and it will change to on. press exit till you come back. Go to sky movies or sport and a few minutes later you will see a box updating data, let it update and a picture will apear, all the pictures are now unscrambled. worked ok for me.
Posted on Aug 31, 2008
b_stro804
  • 68 Answers
SOURCE: Direct Tv Receiver No sound Black Screen
unplug the power from the reciever for a few moments. plug it back in and let it load. once its finished turn to channel 201. Usually it the reciever is on an unavailable channel (channel with no programming) when it restarted it will go back to that unavailable channel hince the black screen and no sound.
Posted on Jan 04, 2009
SOURCE: I use Guideplus on my tv, everything ok with the
Did you find a fix? I have the same problem!
Posted on May 13, 2010
My ti-84 se plus has batteries that work, but it isn't turning on do you know why?
Personally I do not know why because I do not lnow what the calculator went through. However, if the calculator was working correctly but after you changed the batteries it does not seem to come alive when you press the ON button, then I may have an idea. Here it is.
After you change batteries, the screen may become too dim or too dark. For your case it may be too dimm.
To darken the screen, follow the procedure below.
1. Press the [2nd] key and release it.
2. Press the UpArrow and hold pressure on it (to darken screen) or DownArrow to lighten screen.
As you keep the UpArrow held down, you will see somes numbers at the top right corner of the screen. You mifgt first see a 2 or a 3, then the next number and it keep increasingAfter a while it becomes too dark to see anything.
To lighten the screen
2. Press the and hold the DownArrow
As you keep the DownArrow held down, you will see somes numbers at the top right corner of the screen. You mifgt first see a 8 or 7 , then the next number and it keeps decreasing.
Release the Arrow keys when the screen contrast is to your liking.
If you overshoot your intended screen contrast you can revert the process by reverting the procedure.
Aug 27, 2011 | Texas Instruments TI-84 Plus Calculator
How to change spanish to english when phone fell from bed it now is in spanish
1. Press the flash/prog button until 1ENG 2FRA 3ESP shows in the display.
2. Use the Caller ID/vol ( + or - ) button or the handset number pad to select 1 (English), 2 (French), or 3 (Spanish). The default setting is 1ENG.
3. Press the flash/prog button to confirm and to advance to the next menu feature.
You can download the manual at
http://www.home-electronics.net/USER-GUIDES/25861_CAN_EN_CL_IB.pdf
Jun 21, 2011 | GE 25861GE3 Phone
How would I program a number into this phone?
This is the way to program the numbers
  • 1.Lift the handset and press PROG button.
  • 2. Enter a phone number as you would dial it.
  • 3. Press PROG again and then press the corresponding memory button to store this number. Hang up immediately.
  • 4. The number is now stored into memory. The memory button in the lower right corner of the frame can be programmed for emergencies. Whenever the handset is lifted, a light will guide you to that button.
  • Note: Press the REDIAL button to insert a pause in the numbers you are.
Pleas this link, for the phone user manual http://www.startechtel.com/docs/76593.000_Manual.pdf
May 18, 2011 | Ultratec CrystalTone Corded Phone
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
My TI-83 plus calculator add zeros to numbers. for example i press 5 and hit enter and it comes out as 5.000 how do i make it normal again
Press MODE to bring up the mode editor. Press down-arrow to go to the second line. Use left/right-arrows to highlight NORMAL. Press ENTER to select it, then 2ND [QUIT] to exit the mode editor.
Alternatively, you can select any other display format.
Sep 18, 2010 | Texas Instruments TI-83 Plus Calculator
I bought a house with a Hunter # 44100A programmable thermostat but have no manual to program it from. How can I program it?
To change the time, press Hour once. Then press and hold Hour to until it reaches the correct one (pay attention to the AM/PM notation). Do the same with the Min and Day buttons. Press Return when done. (The thermostat will leave return to the normal mode after 10 seconds without a button press.)
Now to set the program, set the switch to heat or cool depending on which you want to program first. Press Prog (this will program M-F settings) then press and hold Hour until the time you want Prog 1 to start. Press the Up or Down arrows to get to the temperature you want to reach and stay for this period. Press Prog again and use the Hour/Min/Up/Down keys to set the time and temperature for next period. Repeat for program 3 and 4 for weekdays. Press Prog again to do the same thing for the 4 possible weekend program segments. Any time left at 0:00 results in a program being skipped.
Press Prog to set the Program. These settings will not take effect until the next time change in the program. You can review the settings by pressing Prog and scrolling through the settings.
Change the switch to the other setting and repeat the programming if your system has both AC and heat.
If you want to press the AutoProg button the thermostat will use preset times and temperatures. For Heating that is 5 am 68, 7 am 60, 3 pm 68, 10 pm 62. For cooling it is 5 am 78, 7 am 85, 3 pm 78, 10 pm 82.
For more information, you can get the manual from Hunter: http://www.hunterfan.com/Support/Manuals-and-Parts-Guides/ , just enter the model number in the Search line.
I hope this helps.
Aug 17, 2010 | Hunter Heating & Cooling
Speed dial access
It's easier if you have access to the database to put in names with the numbers, but in the simplest sense, you can take a piece of paper, write down locations, and start entering numbers.
PROG
They are added in sytsem speed dial from the first extension or one designated as the manager's phone. PROG **1234 gets you into programming and 001 is the system speed dial area. With a combination of NEXT's and ENTER, you can be looking at SD 000 (ie PROG **1234 NEXT NEXT ENTER NEXT) and you're ready to enter a speed dial in bin 000. The complete number starts with an access code (9) plus the number as you would dial it. For example 918005551212 ENTER puts that number in bin 000. NEXT will step to 001.
USE
Press INTERCOM or select a line and press AUTODIAL and dial the 3 digit code. If your installer was lazy, you will have a problem as "9" selects the highest line in a trunk group, one that you might not have. In that case, he'll either have to program the system properly, or you will always have to pre-select a line to use speed dial.
Notice that this is just hte instructions for SYSTEM speed dial. I guessed that it was what you're looking for. Personal speed dial is a different set of instructions and it could be either under a button or in your 10 or 100 number personal directory (so that's where the 2 digit SD's went :-))
Anyway, if you need those instructions and can't find them in the user manual, please post back.
Carl
Nov 21, 2008 | Panasonic KX-T7630 Corded Phone
Help..
Follow these steps to check for problems on the machine you cannot access.
1) Open the registry editor on the machine you cannot connect to by clicking on Start, Run
2) Type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following entries
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Services
Lanmanserver
Parameters
4) In the right-hand portion of the Registry Editor look for a key called IRPStackSize
5) If the key exists, double-click on it and increase the decimal value to 15 and click OK. Close the Registry Editor, reboot the computer and try to connect to the network share. If you are still unable to connect follow the above steps again and increase the decimal number for IRPStackSize by 5 and try again. Continue to do this until the stack size is large enough to permit access. Personally, I had to increase the number to 25 before I could connect. The decimal range for the parameter is between 11 and 50.
6) If the IRPStackSize key DOES NOT exist in the right-hand column of the registry editor, then click on right-click in the blank area in the right-hand column and choose New
7) Then Click on D-Word under the Key column
8) In the Name of the new key, type the name IRPStackSize and press Enter. Type the name with the correct capitalization as shown above.
9) Now double-click on the IRPStackSize key and type 15 in the value data box and place a dot next to Decimal then click Ok.
10) Close the registry editor and reboot the computer. Try to access the network share again. If the same error appears follow the steps above to increase the value and reboot again. Continue this procedure until the problem is resolved. The decimal range for the parameter is between 11 and 50.
Oct 18, 2008 | Computers & Internet
Guide Plus
Called the cable company..they said they don't block the signal. sooooo..
first..i unplugged the tv from the power source, and unplugged the cable from the wall. left both off for an hour, and reconnected power and cable.
entered the guide set up...changed the zip code from the area where i actually live to the zip code of the cable provider for my area. here on maui, there is only one provider.
used the editor in guide plus to turn on and off the channel line-up according to the published channels listed in my area tv guide.
24 hours later...voila..!! it WORKS..!! good luck..!!
Oct 16, 2008 | RCA G36705 36" TV
My cd rom will not play acd it as encountered a problem
You can Try these Steps :-
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Method 1: Remove the Adaptec CD-Burning Plug-in in Media Player version 7.x
Follow the steps below to remove the Adaptec CD-Burning Plug-in from Media Player version 7.x. Windows Media Player version 8 that came pre-installed in Windows XP does not display this issue.
Click Start , Settings , and then Control Panel .
Double-click Add/Remove Programs .
If installed, Windows Media Player 7.x will be presented in the list.
Click the Change/Remove button.
The Windows Media Component Setup window should be displayed. The radio button next to Remove Windows Media Player components should be selected. Click Next .
Place a check in the box next to Adaptec CD-Burning Plug-in . Click Next .
The Adaptec CD-Burning Plug-in will be removed from the computer. Click Restart to complete the operation.
Method 2: Removing the Upper and Lower Filter registry keys
The second method for resolving this issue is to remove the registry keys associated with the loading of CD recording drivers. Follow the steps below precisely to resolve the issue. Exporting the registry is imperative before making any changes to the registry. If mistakes are made during the editing process, the registry can normally be repaired with the exported registry.
Step 1: Remove upper and lower filters
The steps below describe how to remove the drivers associated with the drives disappearing. After removing the filter driver keys, the CD recording software will be have to be re-installed.
With a copy of the registry exported, click the plus signs [+] in front of the follow keys in the order they are listed: HKEY_LOCAL_MACHINE , SYSTEM , and then ControlSet . In some cases, multiple ControlSets may be listed similar to the following:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
or
Click the plus sign [+] in front of either CurrentControlSet or the lowest numbered ControlSet. For example, in the second list above, ControlSet001 would be the correct listing.
Click the plus sign [+] in front of Control.
Click the plus sign [+] in front of Class.
Locate the following key and highlight it in the left window of the Registry Editor (The numbers can be very similar, be careful select the correct key. Another method to find the correct key is to highlight Class, then cut and paste the key below into a Find window accessed from Edit and Find in the Registry Editor.)
{4D36E965-E325-11CE-BFC1-08002BE10318}
With the key highlighted, the right pane will have multiple keys listed including LowerFilters and UpperFilters. Highlight LowerFilters and press the Delete (Del) on the keyboard. A confirmation dialog box will be displayed asking if the value should be deleted. Click Yes to delete the value.
Repeat the process for the UpperFilters by highlighting UpperFilters, pressing the Delete (Del) key on the keyboard and again confirming the value should be deleted by clicking Yes.
Exit the Registry Editor
Restart the computer. The optical drives should then be recognized and available for use.
NOTE:- If the computer still does not recognize the drives, go back into the registry and repeat the above steps for editing the registry for each of the ControlSets listed on the customer’s system.
Step2: Reinstall the HP DVD / CD-Writer software
Deleting the LowerFilters and UpperFilters will prevent the previously installed recording software from operating successfully. The software that came with the HP CD-Writer or DVD Writer will need to be re-installed to function correctly. Follow the instructions included with your CD-Writer to re-install the software.
Oct 07, 2008 | Computers & Internet
Televison & Video Logo
78 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
