Question about Sewing Machines
How to thread a janome
How to thread the janome mb4
4 Suggested Answers
  • 323 Answers
SOURCE: janome mb4
Loud chirping noises indicate a need for lubrication or something is rubbing against your carriage.
sewman7
Posted on May 19, 2008
SOURCE: I have a Janome MB4 and have had so many problems
Hi!
I was having the same problem(s) and I loosened the tension on the bobbin case and switched to prewound paper bobbins and everything sews beautifully.
Hope that helps!
-Donna Jo
Posted on Sep 08, 2010
  • 1564 Answers
SOURCE: janome mb4 restarts in different place after stop to replace broken needle
My machine is a bit different than yours but there is a way to back up your Janome 10 stitches at a time. Here is a thread that I initiated at the janome embroidery forum that should help you. Digimad included a detailed help for me. It should direct you to get you going again. Do join the forum the gals there are generally a great bunch and very helpful.
http://content.janome.com/fusetalk/forum/messageview.cfm?catid=7&threadid=4317
Posted on Aug 25, 2012
My janome mb4 is 3 days out of the shop. I was able to stitch 2 letters and now all it does is birdnesting to the point that I have ruined 5 samples. I have changed needles, thread and bobbin
Verify that you are threading it correctly. Thread nesting will happen often because the thread path is not correct.
Since you just had it serviced, don't hesitate to take it back. Perhaps something was missed.
Aug 14, 2016 | Janome Sewing Machines
Why does my Janome mb4 keeps shredding its top thread?
Change your needle and if it continues to happen, change the thread. Most likely your needle and thread are not compatible, ie the thread is too large for the needle's eye. Also, inexpensive thread will shred.
Sep 05, 2015 | Janome MB4 Four Needle Embroidery Machine
Tengo problemas con maquina de bordar janome mb4, me distorciona el bordado. I have problems with mb4 janome embroidery machine, embroidery distorts.
If your embroidery is distorted be sure you are using the right stabilizer for the fabric you are doing the embroidery on and enough for the density of the design.
I hope that helps.
Dec 04, 2014 | Janome MB4 Four Needle Embroidery Machine
How do I fix my MB4 that has locked after thread caught around bobbin. There must still be hidden thread, how can I fix please, regards Pam
IF THE GEARS ARE PLASTIC, THE LOCKING MAY HAVE CAUSED THE GEARS TO JUMP A TOOTH AND THREW THE TIMING OF THE MACHINE OFF. IT MAY NEED TO BE SERVICED.
Nov 20, 2014 | Janome MB4 Four Needle Embroidery Machine
Janome mb4
I suggest you call a Janome dealer and ask them your question.
Sep 02, 2014 | Janome MB4 Four Needle Embroidery Machine
Janome mb4
are you using a good thread and the same thread on the top and in the bobbin, different threads will sometimes act up. I also can not sew one brand of thread on my machine, try Mettler or gutermann's you can get them at JoAnn's or Fabricland. hope it helps good luck K
Sep 23, 2017 | Janome MB4 Four Needle Embroidery Machine
Janome MB4 wont sew breaks threads really bad?
1--thread breaks really easy if it is a couple of months old
may be new to you but in the shop for a long time
2---thread breaks easy if the incorrect needle eye size is used for the thread thicjness
3-- thread breaks easy in the needle tension is incorrect
4-- thread breaks easy if the needle is threaded from the wrong side ( look for a small groove down the back of the needle and thread from that side so the thread sits in that groove )
5-- thread breaks easy if the needle /hook timing is a bit out as the hook pierces the thread instead of picking it up cleanly from the recessed section at the eye
find another repair shop because if the dealer couldn't fix it under warranty, they sure cannot fix it when out of warranty and for money
Aug 06, 2017 | Janome MB4 Four Needle Embroidery Machine
Janometroubleshooting
checks that the strip wire and strip wire sensor, this worked well.
(the strip threads is the small spring by which you spend the thread to thread)
Jan 04, 2014 | Janome MB4 Four Needle Embroidery Machine
Janome mb4 why does thread ravel whiles embroidery a project
check for burrs on the needle plate and in the bobbin area
also check for burrs in the threading area,like one of the thread guides
Oct 15, 2013 | Janome Sewing Machines
Sewing Machines Logo
178 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
