Question about Zenith Televison & Video
Tv code list - Zenith Televison & Video
I have a Samsung TV iamuseing a ermsom remote need codes for this remote
Search Results
    Remote Control Codes
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    ... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    Remotes - Device Codes - HiFi Remote
    www.hifi-remote.com/codes-tv.shtml
    TYPE, BRAND, CODES ... TV, Emerson, 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, ... TV, Samsung, 0019, 0060, 0030, 0056, 0178, 0032.
Feb 05, 2016 | Samsung 50 in. Plasma TV
Comcast remote codes for apex digital dt502
Brand: Apex Digital
Most likely code: 10765
Others to try:
10748, 10879, 10767, 10890, 11991, 10889
To program your remote:
  1. Turn on your TV
  2. Using the code list, find the first five digit code that is listed next to the name brand of the TV that is to be programmed
  3. On the Comcast remote, press and release the TV key
  4. On the Comcast remote, press and hold the SETUP key until the TV mode key blinks twice then release the SETUP key
  5. On the Comcast remote, enter the first listed five digit code
    Note: If this number is entered correctly and is an accepted TV code, the TV mode key will blink twice. If the code is entered incorrectly or is not an accepted TV code, the TV mode key displays one long blink and exits programming mode
  6. Aim the remote control at the TV and press the POWER key once
  7. The TV should turn OFF - if it did not turn off, repeat steps 1-6 with the next TV code listed, until a working code is found
Nov 03, 2013 | Apex Digital DT502
I have a oleia tv im trying to program my rca rcu403 but it wont work
your oleia tv code is 1610 OR 1240 OR 073
In order for the 3 component universal remote to control your TV you must program it with the TV code
that matches your TV These instructions explain the preferred method of programming the remote the
Direct Entry method 1 Manually turn on the TV
2 Locate the enclosed TV Code List. Find your brand of TV
Note If your brand isn t listed, use one of the Code Search methods to
program this remote control See Code Search on page 24
3 Press and hold the CODE SEARCH key until the indicator light
illuminates Then release the CODE SEARCH key
4 Press and release the TV key The indicator light blinks and then remains lit
5 Use the number keys to enter the first code listed for your brand.
After you enter a valid three digit code, the indicator light turns off
Note If you enter an invalid code the LED will flash rapidly for 2 seconds
Start over at step 3
6 Aim the remote at your TV and press the ON OFF key If your TV turns off
you have found the correct code
7 Enter the code in the box provided on this page for future reference.
8 If your TV doesn turn off repeat steps 3 6 above entering the next code
for your brand.
If none of the codes work or your brand is not listed use one of the Code
Search methods to program this remote See Code Search on page 24
For a description of each key on the remote control refer to the Key
Descriptions section
If your component s brand isn t listed in the Code List or you have tried all of the codes for your brand and
the remote does not operate your component use one of the Code Search methods below Manual Code
Search or Auto Code Search. Both Code Search methods search all of the codes because your component s
code may be listed under another brand in the code list.
Note The Code Search method may take a long time because the remote searches all of the codes in its
memory for the code which operates your component. Therefore, if your brand is listed in the Code List
use the Direct Entry method described Manual Code Search
1 Turn on the component you want the remote to operate.
2 Press and hold the CODE SEARCH key until the indicator
light illuminates. Then release the CODE SEARCH key.
3 Press and release the component key that corresponds to the
component you want the remote to operate TV
indicator light blinks once and then
remains lit
4 Aim the remote at the component and press the ON OFF key
continuously until the component turns off
Important Because there are so many codes, you may have
to press the ON OFF key many times possibly up to
200 times.
5 When the component turns off press the ENTER key to store
the code
6 Use Code Retrieval on the next page to identify the code for
your component for future reference
Nov 05, 2011 | RCA RCU403 Remote Control
Need code to an rca universl remote to control a magnavox tv
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Magnavox TV Codes: 006, 007, 010, 013, 016
Sep 21, 2011 | RCA Computers & Internet
Need the codes for a NIKAI TV, that I am using in Iraq.
Hello
Code for NIKAI TV is not listed in the codes of URC-4021. Coreds for NIKKO TV is there. OK.
Mar 05, 2011 | One For All URC-4021 Remote Control
UVERSE REMOTE CAN NOT TURN OFF VIZIO 42' TV
The documentation that came with my U-Verse equipment doesn't list Vizio products, but I have been using 1343 which I saw suggested on another website. AT&T's support site has a new code list (http://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf) showing Vizio under the TV section as 1489 and in the HDTV section as 1429, 1433, or 1439.
None of the codes listed for Vizio work with my Vizio LCD(model VO370M), but the 1343 code I've been using successfully is listed in the new list as an LG HDTV code.
Jan 12, 2009 | Vizio L13e 13 in. EDTV-Ready LCD...
Code list forToshiba television is ineffectual
You tried all of the following codes?
018,021,023,071,085,090
Doing as follows
Try this if so
Jan 08, 2009 | RCA RCR311B Remote Control
Locateowners manual/program codes for tv remote
Codes for Zenith T.V are 1000,1001,1004,1083,1101,1100,1099,1097,1089,1078,1022,1020,1011,1009
Jun 07, 2007 | Jensen JER-822 Remote Control
Televison & Video Logo
277 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
