Question about Onkyo TX-DS989 Receiver
TX DS989 turns off after 3 seconds
I have a TX DS-989 Onkyo receiver that I have had for about 14 years. It has worked flawlessly until now. Suddenly, after exercising the amp a couple nights ago (music was loud), it will no longer turn on. It did not shut off when I was using it, but the next time i turned it on, it was not working. It powers on and shuts off immediately after the 3 second pause. I have read that this is an amplifier failure. Before I bring it in to get looked at, does anyone have any suggestions to try? I have already tried unplugging for an hour: no luck. Thanks!
  • 905 Answers
Sorry but it does sound like an Amp failure and testing the unit for other electronic component failure will be needed
Posted on Jan 03, 2014
  • 3422 Answers
SOURCE: Onkyo AV Receiver TX-SR503 While sleeping
HI,
Did you try reseting it?There must be a reset button at the back of your reciever.
Posted on Jul 03, 2008
thaurfen
  • 623 Answers
SOURCE: Onkyo just shuts off...
check for blown fuses
Posted on Aug 15, 2008
SOURCE: Onkyo HT-R501 7.1 reciever issues
you have to get it fixed. same thing happened to my onkyo reciever and they said it was a bad circuit. had to take it to an onkyo tech and have it replaced.
Posted on Oct 15, 2008
freetek
  • 5568 Answers
SOURCE: Onkyo TX-DS989 not staying on
This sounds like the action of some protection circuit that is monitoring some condition or voltage that isn't within its design limits. If it was mine, I'd look for an Onkyo forum to see if others have experienced the same problem.
Posted on Jan 08, 2009
bluenadas
  • 203 Answers
SOURCE: after turning in my receiver, it immediately turns back off.
Sounds like it's going in to safe mode. This can be caused by a number of things but the first thing to look at is a failed output amp.
Posted on May 04, 2009
Onkyo TX-SV515PRO2 -- circa 1994 When I turn it on sometimes there is no sound. I turn up the volume (sometimes loud) until this triggers the sound to suddenly work. Speakers work great.
Hello, I am sorry about your issue. It sounds like the receiver needs to be serviced. I suggest that you contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you and provide options. Thank you, Onkyo USA
Jul 06, 2017 | Onkyo Audio Players & Recorders
Onkyo tx-ds989 goes to stand by mode just playing for 3 second ... rest every thing is ok I just hear a click sound (relay switch off) and it goes to stand by mode again switch it on .... same thing...
Check the speaker wiring on back that it is not shorting against one another, output ic's may have bad solder connections and should be checked carefully.
May 28, 2012 | Onkyo Audio Players & Recorders
I have a Onkyo TX-DS989, I have my xbox connected to it but only the red and white wires, my question is I have an optical cable that I wish to connect to it. i know where it goes but I get no audio....
You have to assign any digital audio inputs and that requires a functioning controller.
http://remotes.com/remotes/servlet/rs?&smodel=RC875&brand_pn=DENON_RC875&o=c&o=c&a=Search&uid=0&m=Onkyo+TX-DS989&uuid=A13121693494221
http://cgi.ebay.com/RC-390M-ONKYO-HOME-THEATER-CONTROLLER-/120752334524?pt=LH_DefaultDomain_0&hash=item1c1d6666bc
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
http://www.remotes.com/
Jul 31, 2011 | Onkyo TX-DS989 Receiver
When I turn on my Onkyo TX-DS 989, the standby LED does not light up and you can not turn on the amp, but after about half an hour the LED lights stby and then you can turn on the amp and everything works...
The trouble is almost certainly bad capacitors in the power supply. As they age they become very slow to charge up (think of them like buckets that store electricity for other parts to draw on, and it's taking them much longer than normal to fill). As a result it's a while until the rest of the circuitry starts working properly. But once they've charged, the thing works like it should.
If you know someone with some electronics skills, they could check the capacitors and replace any that are visibly bad or don't measure correctly. Or you could see about getting the receiver serviced if you have a shop in your area. Musician's supply stores are a good place to check, or ask retailers if they have anyone they suggest. Since the receiver is basically okay otherwise, having this repaired would probably be worthwhile.
Mar 04, 2011 | Onkyo TX-DS989 Receiver
Just purchased a Panasonic DMT-350 with analog 7.1 out and hooked up to my Onkyo 989 but tried everything and i mean everything to get my rear surround to play but no luck....pleeeeeease help me.
Hi.
Connect the Panasonic to one of the AV inputs on the Onkyo. Use red white and yellow AV cables. Connect the output from the Panasonic to one of the five AV video inputs on the Onkyo (or use the DVD dedicated input in the Onkyo backpanel). I indicated this option using red arrows. You can use any of the AV inputs or the DVD input at the bottom. Just ensure you do not connect to an output at the back of the Onkyo.
Alternatively use component cables and optical audio input, as indicated using the blue arrows in picture below. Select source and listen surround from the Onkyo.
There are more options. In some case you may decide to connect the DVD video output to TV and the audio to the Onkyo.
Here a manual for the TX DS989.
Here the backpanel:
Dec 26, 2010 | Onkyo TX-DS989 Receiver
Sep 10, 2008 | Onkyo TX-DS989 Receiver
Low volume while on both DVD and watching Satellite channels.
call onkyo product support 8002251946 option 6...since they did the mod for u...they should b able to take care of this at a minimal charge if any. alan audio video designs 3822 s. staples cc,tx 3618577236
Apr 30, 2007 | Onkyo TX-DS989 Receiver
Onkyo TX-DS989 Receiver Logo
179 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
