Question about Panasonic TH-42PX75U 42 in. Plasma Television
Top half of screen is fuzzy, then blanks out - Panasonic TH-42PX75U 42 in. Plasma Television
When printing my emails I only get only half the message, top part and the bottom half is blank.
Depending on which email service you are using, I.E. Hotmail, you may only be getting a screen shot of the email. In other words it will only show exactly what your seeing on your screen if you simply right click and print. Hotmail has a little ACTIONS with a downward pointing arrow on the right side of your screen. Click that and select print and it will print the actual message instead of a screen shot of the message. I have to assume other email servers use similar techniques to print the actual emails instead of just screen shots. Hope this helps.
Sep 17, 2014 | Dell Computers & Internet
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
One half of the t.v screen goes blank
Sounds like a back-light fault. Check its back-light inverter. To get more details, http://electronicshelponline.blogspot.com/Pull up older posts.
Nov 30, 2013 | Panasonic TH-42PX75U 42 in. Plasma HDTV
Half screen
Sounds like a faulty screen, has the laptop been dropped or physically damaged? can you only see half of the screen? if the other half is black and one half "fuzzy" it's most likely that the liquid crystal display has been cracked/broken. The only way to resolve this problem is usually by replacing the screen which in some cases can be as expensive as a new computer :(
Apr 28, 2013 | eMachines Computers & Internet
Bush tv, screen has gone blank with no sound or picture. Fuzzy noise in the back ground. Sometimes takes up half hour to come on but today no noise / no picture just blank screen, any advise on the issue...
I think it is Time for a NEW TV. Not worth the money to repair. If it is under warranty, have the work done but other than that, you are wasting your money
Apr 09, 2013 | Televison & Video
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
TV shows on half screen. other half fuzzy
You have some cold solder joints on the PC board. Flux and re-flow all of the electrolytic capacitors connections..
Aug 29, 2009 | Televison & Video
Screen goes fuzzy and blank.
u need a new phone i ahda similar problem with my lg kp500
Aug 09, 2009 | LG Dare VX9700 Cell Phone
Small text and screen blank top and bottom
try to replug the lcd connectors. you have to dismantle it
Jul 06, 2009 | Compaq Evo N620c Notebook
Half fuzzy screen
you have too get a wet tissue and put soap on it if you do that it will get fixed.
- Psp master
Dec 24, 2007 | Sony PlayStation Portable (PSP) Console
Panasonic TH-42PX75U 42 in. Plasma Television Logo
24 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
