Question about LG GSA-2166D DVD RW Dual Layer Burner
LG dvd external drive not recognized by computer
Lg DVD external drive, model SP60NB50. not recognized by computer running Windows 7. All drivers are automatically updated. Shows Window error Code 43
    Problem Solver:
  • 10 Answers
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Posted on Feb 05, 2015
MAXTRIXKHAN
  • 45 Answers
SOURCE: LG DVD burner model GSA-H42LK "code 10 cannot start"
hey try updating your os if winxp try updating with servicr pack 2 or 3
Posted on Jan 04, 2008
Saigua
  • 981 Answers
SOURCE: Need Vista driver for external DVD writer of LG model GSA-5169D
There aren't any such drivers.  The drive control protocols are standardized.  Just do Windows Update a few times and make sure the thing's connected when you restart storage subsystems (pretty much a reboot; though installing Nero will of course get things going if you don't love Vista built-in tools.)
Posted on Feb 22, 2009
rulds2008
  • 3866 Answers
SOURCE: LG GSA-5169D DVD w/ Honestech One Touch on Win XP SP3
You got a bad laser in the drive not the laser the reads the laser that writes and this does generally happen when a dvd ram drive goes. Recommend buying a new drive as a replacment laser is upwards of $90 bucks, thanks for using fixya please do accept and rate.
Posted on Aug 18, 2009
  • 1481 Answers
SOURCE: LG GH22 LS50 (Sata Dvd Writer) Will not write dvd discs
What software do u use to write DVDs on both PCs...
if they are different then that may be the issue....
dont spoil the DVDs....
try DVD RW disks...that way you can erase them later...
i too have the same DVD writer, not had any issue in either XP or Win7....i have dual boot and have made many movie DVDs using both OS...i use Nero and Power2Go of LG(the install disk that came with the LG DVD writer has this great software...."LG Power tool")
try this tool...it should work...
the inbuilt DVD creator in Win7 has some issues with DVD creation....due to non compatibility of graphics card and display drivers (WDDM)....+ you may not have the correct codec required to burn DVDs.....
get the FFDSHOW codec from google.... and install it...shutdown and restart and then try...
let me have a feedback pls...
reg
Posted on May 04, 2010
bronk50
  • 27725 Answers
SOURCE: computer won't recognize LG external
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Dec 21, 2010
In my desktop computer the LG CD/DVD writer/reader is showing empty though the CD is filled with data..hat could be the reason, i tried by re-installing the drivers but no success...
Not knowing the operating system, In windows 7 and 8 sometimes it forgets the cd format. Then you need to go to the device manager and remove the drive and let windows re-detect it.
Feb 11, 2015 | LG Super Speed USB 20X DVD / 48X CD...
Hi: I just purchased an LG External multimedia burner, Model GE24. DVD Shrink on my computer is not recognizing the burner although other programs on the computer are. Can you please tell me how I can...
Unfortunately, DVD Shrink probably does not support your LG external media burner. Some programs are built just for certain CD/DVD drives. You can probably find another program similar to DVD Shrink for free online.
Jun 01, 2011 | Computers & Internet
Anyone know where to get the drivers for my LG lightscribe burner GSA-E30L ?
Windows XP/Vista/7 operating systems have the driver for all disc drives build in. If it isn't working, then the driver is not your problem.
Mar 23, 2011 | LG GSA-E60L 20x DVD?±RW USB 2.0 External...
I need LG GP08LU10 Driver for Mac please...
Unfortunately, LG does not offer drivers for their products for the Mac platform. You can use a program like Parallels to run Windows as a virtual computer on your Mac and install this optical drive under Windows.
I wish that I could be of more help.
Aug 14, 2010 | LG SecurDisc 8x External Double-Layer DVD...
External LG DVD drive is not recognized after upgrading from Vista to Windows 7
Try to install the usb driver compatible with your windows 7..
If your external drive also come with its cd installer, try installing the driver for this hardware compatible for windows7.
hope this help..thanks..
May 26, 2010 | Computers & Internet
Laptop not recognizing drive...
sir
you should reinstall the drivers for your DVD ROM . It should be given to you when you have purchased it.
if not go here and download
Mar 08, 2009 | LG SecurDisc 20x External Double-Layer DVD...
My LG dvd driver cant read certain dvds
LG and HP in known for thier reading laser to become trashed or crash. Once this happens, you can only replace the drive.
Sorry for the bad new but I faught an HP drive for months before I just bought a new one.
Save yourself the hassle.
Jan 22, 2009 | Computers & Internet
LG GSA-2166D DVD RW Dual Layer Burner Logo
365 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
