3100 manual Channel numbers continue to scan, but unable to change channels
MikeNJ1964
  • 398 Answers
SOURCE: Unable to channel to channel 3
If you take a working remote, point it at the TV and hit "3", then "ENTER", does the set go to channel 3?
Posted on Sep 04, 2007
  • 129 Answers
SOURCE: channel scanning
SEEMS LIKE CONTROL PANEL SWITCH, ONE OF THEM IS STUCK OR DEFECTIVE, CONTROL PANEL NEEDS TO BE TESTED
Posted on May 16, 2008
  • 374 Answers
SOURCE: Channels are skipping
Turn the power off to the receiver and let it run its course. It should download a new program guide at this time. Another thing is to make sure you are on ALL SUB on the guide as opposed to a favorite self created guide.Thanks for using Fix Ya.
Posted on Mar 16, 2009
SOURCE: Dynex 32" 720 LCD HDTV - no channel listing after run auto scan?
Excuse me but the other answers are written by people who have not actually confronted the problem and are just guessing. They are all wrong. Here's the answer:
If your TV is expecting a TV input, it will keep searching for at least one TV channel on cable or antenna. If you only have a DVD player plugged in, for example, or if your cable is hooked up wrong, so there's no video signal on it, the TV will keep searching forever. (This is an unforgivable design flaw, by the way. But then, it was a cheap TV, wasn't it?)
To solve the problem, look at your remote control. You will find input buttons. Mine are small, along the top, right under the "power" button. Try pressing "video" for example, instead of TV. That stops the TV from hunting for TV channels.
Have a merry Christmas. Enjoy your new TV. Watch it in moderation and eat fruit and vegetables every day.
Posted on Dec 25, 2009
falspet
  • 438 Answers
SOURCE: Auto Channel Search places all channels in Skip
check the agc line from the tuner is functioning properly, if the agc signal , is not reaching the processor it will register that channel as being inactive and lock it out, there is not much circuit to contend with so a multimeter should do the trick to trace down the fault, you should find AGC marked on the board where the tuner modual is mounted.. i suggest obtaining a service manual to do the job good luck
Posted on Jan 28, 2010
Channel numbers missing
local channels are usually below a channel 1000. they are always on same assigned channel. If your cable box or tv has it, it has option to not display channels with no service on them. you can't reassign the channel numbers. they are channels but not being displayed.
Apr 10, 2014 | Televison & Video
Missing cable channels
You need to contact your cable service provider about this, it is a signal issue not a TV issue.
Apr 24, 2017 | Samsung SyncMaster Televison & Video
TV is showing no signal. So I did a channel search and it stops and says unable to continue channel search due to error. I even unplugged - left for an hour and still does the same thing. I then hooked...
this could be a fault with the tv actual connector for the cable check the connection on the tv and try again or try a manual search to pick up one channel and then do a full scan also are you doing a scan to add channels to the current list as I would personally try and do a complete scan for all new channels list and see what happens
Sep 21, 2013 | Televison & Video
How can I program my remote with scan
Hello
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Mar 24, 2011 | One For All URC-4021 Remote Control
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Feb 21, 2010 | Radio Communications
I have a Regency Touch K 100 ( NO MANUEL ) Scanner
I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
For $5 it might be worth it.
For all of your scanner needs: ScannerMaster
Nov 17, 2009 | Radio Shack Radio Communications
I have a green signal light that keeps blinking? My radio will not reset when I try to reset it.
Accirding to the manual, which can be found at,
http://inform3.kenwoodusa.com/Manuals/USA_LMR/TK-2200%203200_B62-1791-00.pdf,
To start scanning, press the Scan key.
• The LED indicator flashes green and scanning starts from the
current channel and ascends through the channel numbers.
• When a signal is detected on a channel and the QT/ DQT
matches, scan pauses at that channel and the LED indicator
lights green.
• When the signal is no longer present, scanning continues after 3
seconds (default).
As far as the radio not resetting, I would suggest contacting Kenwood:
By Phone/Fax:
Land Mobile & Business Radio Divisions
Phone: (678) 474-4700
Fax: (678) 474-4730
Hope this helps,
tkhusa420
Oct 03, 2009 | Kenwood ProTalk TK-3200U8P (8 Channels)...
How do I program a Regency Z30 scanner?
To program the Regency Z30
1. Press "MANUAL"
2. Enter the frequency you want, example 162.475
3. Press "ENTER"
The display will show "Ch_" with the _ (underscore) flashing
4. Enter the number of the channel where you want to store the frequency.
Note: channels 1 thru 9 must have a zero before them, example 01, 02,........ 09
If you want to add more frequencies at this time, got to step 2.
To lock out a channel, press "SCAN" and while the unit is scanning,
enter the channel number. Repeat this action to unlock a channel.
To increase or decrease the scanning rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission to wait for the next response, press the "DELAY" key while the unit is scanning.
You can change the display by pressing the "CHANNEL / DISPLAY" key. There are 3 choices: display only the channel number, only the frequency,or alternate displaying the channel number and the frequency.
Jul 10, 2009 | Radio Communications
I dont no how to program my regency z30 scanner
1. Press "MANUAL"
3. Press "ENTER"
If you wish to add more frequencies at this time, got to step 2.
To increase or decrease the scanning2.gif rate, press the "SPEED / ENTER" key while the unit is scanning.
To create a delay after a transmission, press the "DELAY" key while the unit is scanning.
Apr 07, 2009 | Office Equipment & Supplies
Channel selection woes continue!
Sorry but your going to need to get an original remote from a friend or relitive to program this set. They sell rca universal remotes for 10 to 15 bucks that will work for you too.
Sep 18, 2006 | RCA F27628 27" TV
94 people viewed this question
 Grubhead
Grubhead
