Question about Hoover U6485900 Bagged Upright Vacuum
How do i replace the on off switch on Hoover U6485900
Make sure the power cord is disconnected! There are two sets of three screws one needs to remove. The first set hold the handle assembly to the sweeper body (there are two near the back of assembly and one in front). The second set is inside the cavity that hold the vacuum powered cleaning tool. There are two at the bottom of the cavity and one at the top. Refer to the Assembly Instructions in the Owner's Manual for help. One can then remove the power leads from the on/off switch, push the switch out, and insert a replacement switch. Pay attention to the color of the wires because some switches apparently work with models having 2 black wires (H-28161075), others with a black and yellow wire (H-28161074), and others with connectors to the wires. Reassemble the sweeper reversing the dis-assembly process outlined above.
Posted on Mar 22, 2015
3 Suggested Answers
  • 250 Answers
SOURCE: The hose will no longer suction on my hoover
First take the hose of the vacume and make sure you are getting suction where the hose attaches to the machine. If you are then there is a clog in the hose. Try to shake the hose to hear if something is stuck in there or take the brush off the hose and look in the hose for obstruction.
Posted on Mar 11, 2011
small6363
  • 18402 Answers
SOURCE: Hoover U6485900
go here for manual > http://hoover.com/file/509/
Posted on Apr 24, 2013
Testimonial: "I've got all the breakdowns which are really nothing more than a pictorial parts list. I don't want to take EVERYTHING apart to get to the motor. I replaced at least 4 of the old style motors ( Grainger's )but these weren't puzzles."
I have the Hoover U6485900 and the brush rollers keep spinning even when the vacuum is in the upright position. I have replaced both belts hoping that would fix it. Help!
depending on your exact model this is supposed to happen even when it is up right since the vac motor does two things besides just sucking up dirt but in order to prove that i would need some photos (photobucket links or any other imaging online service is welcome to be used to see the exact model vac it is) now if it has like a two stage mode switch in this model it could be that the two stage switch is a lil bad but i have seen where people have done mini mods to save cash and sort of make their own sorta two stage switch with two switches and a bypass to just run the main motor for sucking up dirt
Jan 05, 2017 | Hoover Vacuums
The dirt sensor light stays green. It won't turn red, even when I know I'm picking up a lot of dirt.
The Board(46851083) is No Longer Available
The EDF Duct (47823004) EDF= Electric Dirt Finder is $20.40 from
http www searspartsdirect com model part u6485900 0517 0645000 50039309...
You can test the board by crossing the 2 connectors to "close" the circuit for the mic (small black and blue wire) while vac is running and light should go to red every time you complete the circuit. WARNING: There will be exposed electrical points on board that could cause an electrical shock!!! or damage to board if not just crossing mic connections.
Jan 22, 2016 | Hoover U6485900 Bagged Upright Vacuum
Hoover u6485-900 Brush Bar won't turn.
Hello. Make sure that the brush bar is clean and that there is no hair or strings tied up.
Apr 18, 2014 | Hoover U6485900 Bagged Upright Vacuum
U6485-900 WindTunnel Self-Propelled I changed the belts but there is not enough tension on the brush drive belt to get it to rotate
I had the exact same problem with my Hoover U6485-900 Anniversary upright, self propelled, vacuum. It would move backwards and forwards, had good vacuum, but wouldn't pick up much because the brush/roller was not turning very well. I replaced the main drive belt (38528035) and it now works great. The old belt had stretched and was slipping under load. Thanks for the great suggestions.
Aug 02, 2013 | Hoover U6485900 Bagged Upright Vacuum
Service manual hoover windtunnel u 6485-900
http://www.vacshopusa.com/windtunnel.htm
it is cost $4.99
Dec 06, 2012 | Hoover U6485900 Bagged Upright Vacuum
U6485900 brush wont spin
check the belt av not broke this link is for the manual
Oct 02, 2012 | Hoover U6437-900 / U6439-900 Windtunnel...
The hose will no longer suction on my hoover u6485900. The vacuum doesn't seem to be sucking when it's upright either.
Mar 11, 2011 | Hoover U6485900 Bagged Upright Vacuum
Hoover U6485900 Bagged Upright Vacuum Logo
183 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
