Question about Behringer Fx600 Multi-fx Digital Stereo Multi-effects
Behringer fx600 works for 5mins or so then there is no output and the battery indicator just flashes rapidly with a clicking sound
2 Suggested Answers
  • 5603 Answers
SOURCE: My Behringer fx600 multi effects
The LED is ALSO used as a battery condition indicator... this is probably indicating the battery is expired. The manual sure doesn't say much!
Posted on Apr 26, 2011
I want to set up my behringer fbq1502
It sounds as if you are not running in series. I assume you are in an insert on the mic channel. The insert send should go to the first item in the chain, then from the output of that to the input on the next item and so on until the output of the final item in the chain goes back to the return on the insert. This is applicable to the type of equipment you have detailed, in some cases however you may be running effects in parallel. Your case is definitely a series situation.
Mar 08, 2014 | Behringer FBQ1502 Ultragraph Pro Dual...
I have a behringer pmp 1280s. I was running two speaker and two monitors through it. One of the monitors was kicked and the patch cable to it was bent. I smelled smoke and the sound coming through turned...
That's a bad sign. A dead short in the output results in a short of the audio output transistors. I believe that to be the problem and a fairly simple fix to someone good at soldering BUT, you can't get parts for behringer equipment. Most components are specially made for behringer. I've been working on an amp for 6 months and I can fix it BUT, I can't find the parts anywhere, or can even find any reference to them online. Without a reference to the specs, I can't even get a generic replacement. Check your music stores in you area, a behringer dealer may can help you.
Mar 03, 2013 | Music
My behringer xenyx 802 premium 8-input mixer worked fine for 1 day but now it sounds watery and behringer support was no help at all
Sounds like it may have failed. Yes, it is likely that it needs to be returned. Another option is to unplug all inputs and outputs. Plug in ONE device into the board, and use the headphone jack on the board. Does it sound the same? Just basic troubleshooting may help.
Oct 02, 2012 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
Behringer No Input Signal
Mic level in the windows control might be muted or off. The sound functions are a control panel iterm Or in Macs it is a CDEV.
Also check to make sure the program has that input enabled as well.
and make sure you start out with fresh batteries, double check where you have things plugged in, so you are not plugged into the worng port plug on the computer
Feb 06, 2012 | Behringer Ucg102 Guitar To USB Interface
Behringer SX3242FX intermittently looses signal to the left main. When it's out, the the level meter indicates signal on the left, but not the right. This is consistent in both mono and stereo inputs....
Make sure you are using BALANCED cables from this... eithe XLR or TRS cables. Using TS unbalnced cables MAY ground out the signal which is sent as balanced. Here is a schematic for the 24 channel unit... yours just has eight more channels. http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to "get manual" and click to download. Ignore other download links.
By looking at the signal paths, you can OFTEN do a lot of testing from the available jacks. If the contacts on the right main INSERT jack go bad, that would cause your problem,,, NEVER use other than an insert cable in these jacks.
Sep 24, 2011 | Behringer Sx3242fx Eurodesk 32-channel...
My pedal is brand new and cuts out after about ten minutes. I also bought the delay pedal and it cuts out around the same time while making a rapid pulsing sound.
This sounds like you MIGHT be running on batteries and they are near depleted... Pedals go through batteries pretty fast. Use power adapters and make SURE to use the right ones as some pedals require different voltages and types of current.
Jul 28, 2011 | Behringer Rv600 Reverb Machine Effects...
I don't know how to put batteries into my "Digital Multi-FX FX600 Behringer" Effects pedal. -_-
Most of these the battery is UNDER the pedal itself. You push in on the hinge pins with a pen to release and remove the pedal and change the battery.
Apr 28, 2011 | Behringer Fx600 Multi-fx Digital Stereo...
My Behringer fx600 multi effects pedal flashes rapidly when used with a power adaptor. this happens whether the pedal is turned on or not.
Apr 26, 2011 | Behringer Fx600 Multi-fx Digital Stereo...
My behringer ub2442fx pro has the numbers 88 flashing red in the display and a clicking sound every time they flash. any idea what the problem is?
A high likelyhood of a power supply problem.
I had a similar thing on a GX110 and it was an electrolytic cap that filters for the 5 volt regulator on the DSP board.
As the DSP starts up, the load on the supply sucked it below the operating point and caused the DSP to keep reseting. The display did flash.
The unit will have to be opened and trpunbleshooting done to find and repair the problem.
Dec 20, 2009 | Behringer Music
Behringer Fx600 Multi-fx Digital Stereo Multi-effects Logo
15 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
