Question about Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator
Recently moved freezer and fridge won't get cold
I recently moved this fridge (2004 unused, have no idea how well it worked). Was plugged in and cold when I picked it up. I transported it on its side and made the mistake of plugging it in immediately after righting. I have since unplugged it for 12hrs, then 24 hrs, but won't get cold. Fan comes on, but i don't think the compressor does (not sure). Any help?
  • 212 Answers
SOURCE: Does not hold temperature, warms up.
if you hauled on its side then it is very possible you have oil in evaporator. replace all sealed system parts. compressor, drier and evaporator.
Posted on Jun 21, 2009
heatman101
  • 43501 Answers
SOURCE: roper fridge
Check out these tips...they can help you figure out whats going wrong...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 12, 2010
  • 5370 Answers
SOURCE: Freezer Side of Roper
Its a compressor issue.The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.But as you mentioned that freezer section not cooling this indicates problem with compressor.when compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.----------- ---------------- If the compressor is not turning on or its again and again making clicking noise.Then there is a overload relay( its also called run capacitor).This part has to be replaced first and checked.Its a $15 to $20 part.Its located beside the compressor.If you notice click click noise then first get the overload relay replaced.Then see, if still the same problem, then compressor has to be replaced.-----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Posted on Jun 21, 2011
imufo2
  • 3773 Answers
SOURCE: roper refrig 9 yrs old..rt18bkxkq00..started
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 16, 2011
rickead1
  • 1998 Answers
SOURCE: Roper Whirlpool side by side
If you were to take everything out of the inside of the freezer and look at the rear wall of the inside of the freezer you will notice there are screws on this panel so that this panel can be removed. Once you removed this panel this would give you access to the evaporator coil. If you look above the coil you will see the culprit that makes them awesome noises you enjoy so much. If you see any ice build up anywere in this area you would defrost it with a hair dryer. This issue is called a defrost problem that your unit is experiencing. This is due to one or more of three basic parts. Two of those parts are located right in the area where you have accessed the evaporator coil. You would need a multimeter and be able to perform an ohms test on each of these next two parts mentioned to diagnose which part or if both had a fault. The first part is called the defrost thermostat which is a small round sensor that is clipped onto one of the copper lines near the top of the evaporator coil. Here is a link to click that is the entire schematic for your machine if the last numbers after the q that you posted were 03 there are three models an 04 as well as an 00. The 03 has 3 more parts listed then the others. http://www.searspartsdirect.com/partsdirect/part-model/Roper-Parts/Refrigerator-Parts/Model-RS22AQXKQ03/0893/0165000?searchedModel=RS22AQXKQ&blt=11
you would then go into the unit section and click that as well your defrost thermostat is part number 35 and the defrost heater is part number 33 do the testing on these parts and if you find no fault message me back and I will explain more on the defrost timer or adaptive control due to the look up site just went down for maintenance. If you have any questions message me those back as well. Thank you
Rick
Posted on Nov 24, 2011
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
Westinghouse fridge freezer Model no. WBM4000WA-R I have recently moved and upon plugging it in at the new place only the freezer is working. Do you have any idea of what I can check or do to fix the...
Hopefully you didn't have the unit on its side when you moved! That could present another problem.
The cold air for your refrigerator comes from the freezer compartment. When you say it is working, can we assume you mean it is getting cold or just making noises in the freezer compartment?
Check to see if the refrigerator temperature control is on and in about the middle of the scale on this model, e.g., 5.
Refrigerator Defrost Parts
May 06, 2014 | Refrigerators
Fridge not getting cold
Check the condenser grille on the back is clean and warm to the touch. It should cool down towards the bottom and the drier cooler still. If it's cold, suspect short of refrigerant. If it's hot, move the fridge away from the wall to help it cool down.
Aug 06, 2012 | Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Bottom freezer left open overnight. Freezer does not work anymore. Top fridge does not getting cold as it should be.
Your fridge gets it's cold air from the freezer. If the freezer is not working then the fridge won't get cold.
May 26, 2011 | Refrigerators
Freezer works, fridge does not. Also the sides of the fridge are really hot but not up the top near freezer section. Fridge has recently been moved. Thanks
Warm sides are usually caused by the condenser fan which is underneath around back not running. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
When it was moved, was it laid down? If it was it should be stood upright for 24 hours before being plugged back in.
Feb 13, 2010 | Refrigerators
Suspected broken fan prevents top fridge section cooling down
Very good diagnosis and conclusion. That price for the motor is about right. I think you will not have any truble with the ciculation after you install the motor.
Jul 29, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Freezer in my kenmore refrigerator isn't cold
Make sure the freezer fan motor is running. The wires may have come off when it fell.
Mar 08, 2009 | Kenmore Refrigerators
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Roper RT18DKXKQ / RT18DKXKT Top Freezer Refrigerator Logo
79 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
