Question about Video Game Consoles & Games
Final fantasy xii walkthrough
Cannot find way into 3 locked doors in Necrohol of Nabudis.
4 Suggested Answers
CA92793
  • 78 Answers
SOURCE: black screen when tryin to connect to final fantasy 11
Your disk file is corrupted. Try to return it, or trade it in for another copy. Hope this helped.
Posted on Jul 12, 2008
Ravege
  • 327 Answers
SOURCE: ps2 will play ps2 dvd games but wont play dvd movies
might want to check the parnet settings on the system
Posted on Jul 14, 2008
  • 183 Answers
SOURCE: how can i download final fantasy agito xiii onto the internet?
This game hasn't been released yet, and it should be on the Playstation store when it gets released.
Posted on Jul 24, 2010
1999 blazer Doors lock and unlock even when parked, help
Lock an unlock by them selves ? Door locks are computer controlled ,by the BCM - body control module .
Power Door Locks Circuit Description
The power door lock system includes the following components:
• The door lock actuators
• A door lock relay
• An door unlock relay
• A driver door unlock relay
• The door lock and side window switches
• The body control module (BCM)
• The endgate lock cylinder switch /liftgate lock cylinder switch (utility)
• The keyless entry, if equipped
The door lock and liftgate mechanisms may be controlled by the following switches:
• The BCM
• The endgate lock cylinder switch / liftgate lock cylinder switch (utility)
The following locking functions are included on the vehicle:
• All the doors unlock -- All the doors will unlock, including the endgate/liftgate, when any power door unlock switch is detected. The passenger doors lock directly by pressing the lock switches. The driver door unlocks by the BCM using a driver door unlock relay.
• All the doors lock -- All the doors will lock, including the endgate/liftgate, when any power door lock switch is activated. All the lock actuators will activate directly from the power door lock switch (external to the BCM).
• The end/lift gate lock switch -- All the doors will lock or unlock from the end/lift gate lock switch.
• The lockout prevention -- This function will prevent the doors from automatically locking if the keys have been left in the ignition and the power door lock switch is operated.
The motor is protected by a built-in electronic circuit breaker (ECB). If the motor is overloaded or voltage is applied for an excessive amount of time, the ECB internal resistance increases, essentially creating an open circuit. The resistance returns to normal only after voltage is removed from the circuit, thereby restoring circuit continuity.
You have a bad switch input to the BCM !
Door lock acting up 2005 Chevy Malibu fix it here
Door Locks Go Crazy 2
Jan 07, 2018 | Cars & Trucks
2007 Saturn ion 3 door locks fuse location
Power door lock's are controlled by the BCM - body control module . Are you familiar with automotive electronic's ?
Door Lock System Components
The power door lock system consists of the following components:
• Driver door lock switch--Uses a single signal wire for both lock and unlock switch activations
• Front passenger door lock switch--Uses a single signal wire for both lock and unlock switch activations
• Body control module (BCM)--Class 2 module which requires programming when replaced
• Reversible door lock actuators in each of the doors
• Body control module PWR 15A fuse--Located in the body control module fuse panel, supplies power for the door lock system
Door Lock and Unlock Operation
The BCM PWR fuse supplies battery positive voltage to the BCM for the door lock system.
The BCM supplies and monitors a reference voltage to the door lock switch through the door lock switch lock/unlock signal circuit. The door lock switch also receives a constant ground source. If a door lock switch is placed in the lock position, the reference voltage is taken directly to ground and the BCM senses 0.0 volts on the signal circuit. If a door lock switch is placed in the unlock position, the reference voltage is taken to ground through a 1.5K ohm resistor that is internal to the door lock switches and senses approximately 2.9 volts on the signal circuit. This is how the BCM determines what portion of the door lock switch was activated.
The BCM, upon receipt of a door lock switch lock or unlock signal, will switch the appropriate door lock actuator control circuits to battery positive voltage. The opposing side of the door lock actuators are connected to ground internally within the BCM through the other door lock actuator control circuit and the doors will lock or unlock appropriately.
Vehicles without keyless entry have two internal drivers in the BCM to control the door lock actuators. All door lock and all door unlock. Vehicles equipped with keyless entry have three internal drivers in the BCM. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked by itself using the keyless entry transmitter.
Nov 26, 2017 | Saturn Cars & Trucks
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A door lock cylinder switch unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
Mar 23, 2017 | 2006 Chevrolet Monte Carlo
2005 Buick Rendezvous you can hear the relay clicking but the door locks will not open and close
Check for broke wires inside the boot from body to driver door , this is a common problem . If you don't find broke wire's , pull the door panel to get at driver door switch . Check for voltage an ground circuit .
Rendezvous Door Lock System Components
Door lock system fuse into the BCM (BCM D 25A fuse)
Door Lock Operation
When the BCM detects a transition of either of the door lock switches to the LOCK position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the Lock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the LF door lock actuator motor transitions to the Unlock position.
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked seperate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed). This video on testing computer controlled door locks on a Subaru , doesn't matter . test yours same way > The BCM controls your door locks .
Are all of the power door locks inoperative from both door lock switches?
Oct 12, 2016 | 2005 Buick Rendezvous
2002 Cadi Deville, can't get any locks to operate with remote or dash push buttons, the remote operates everthing but the locks! When the remote door lock is pressed, lites flash,horn blows locks not.
Power Door Lock Operation
The vehicle is equipped with power door locks. Each lock actuator is powered and controlled by the door module mounted in the individual door, but the rear integration module (RIM), which is the master control for the door lock system, determines when the lock functions are permitted. The RIM receives and examines the requested lock function from the individual door modules, or from the remote function actuator (RFA) via the class 2 serial data circuit. The RIM also examines the transmission shift selector position and the ignition switch position information available over the Class 2 serial data circuits. If the RIM determines that a lock or unlock function is permitted, it sends a class 2 message back to the individual door modules commanding them to perform that Lock or Unlock function.
Power Door Lock Components
Passenger front door lock switch
LH rear door lock switch
RH rear door lock switch
LH middle door lock switch (w/ V4U)
RH middle door lock switch (w/ V4U)
Driver door switch assembly (DDSA)
Driver door module (DDM)
Passenger front door module (PDM)
LH rear door module (LRDM)
RH rear door module (RRDM)
Left middle door module (LMDM) (w/ V4U)
Right middle door module (RMDM) (w/ V4U)
Driver door lock actuator
Passenger front door lock actuator
LH rear door lock actuator
RH rear door lock actuator
LH middle door lock actuator (w/V4U)
RH middle door lock actuator (w/ V4U)
Driver door cylinder unlock switch
Rear integration module (RIM)
DRVMDL fuse (10-amp)
PASS MDL fuse (10-amp)
RRDR MDL fuse (10-amp)
Class 2 serial data link
Sep 27, 2016 | 2002 Cadillac Deville
Door lock dont always work
What door lock doesn't always work ? One or all of them . This is a complex set up for these door locks ! The switch is an input to the BCM - body control module . There is logic involved in the microprocessor , there are relays built in to the BCM ! Could have a DTC - diagnostic trouble code stored in the BCM ! Could be a bad connection at the BCM or master window switch ! A bad ground !
DOOR LKS fuse
GMLAN serial data link
Keyless entry transmitter
Passenger door lock actuator
Passenger door lock switch
Remote control door lock receiver (RCDLR)
The DR LCK fuse supplies battery voltage to the body control module (BCM) for the power door lock system. The BCM supplies and monitors a reference voltage to the driver and passenger door lock switches through the door lock switch lock/unlock signal circuit. Each door lock switch receives ground at G300 which is also the ground for the door lock and unlock relays located in the BCM. When a door lock switch is placed in the lock position, the reference voltage is switched to ground and the BCM senses 0.0 volts on the door lock/unlock signal circuit. When a door lock switch is placed in the unlock position, the reference voltage is switched to ground through a 1.5k ohm resistor that is internal to each of the door lock switches and the BCM senses approximately 2.9 volts on the door lock/unlock signal circuit. The BCM interprets what position the activated door lock switch was placed in based on the voltage drop.
The BCM, upon receipt of a lock or unlock switch signal, will switch the appropriate door lock/unlock relay coil control circuit to ground causing the appropriate door lock/unlock relay to energize. With the relay energized, voltage is applied to the door lock actuator control circuit causing the door to either lock, or unlock depending on what command was received from the power door lock switch or remote control door lock receiver (RCDLR). When a power door lock/unlock relay is not energized, the switch contacts are normally grounded through the BCM which provides ground to the appropriate door lock actuator for the lock/unlock function being performed. The power door lock/unlock functions are performed by reversing the flow of voltage through the door lock actuator control circuits. The BCM has three internal drivers for the power door lock system. Driver door unlock, passenger door unlock and all door lock. This is done to isolate the driver door lock actuator so it can be unlocked separately from the passenger door. For additional information concerning keyless entry, refer to Keyless Entry System Description and Operation.
This is one you may want to take to dealer or some other ASE certified repair shop ! To do this right you need a Tech 2 scan tool !
Ignition ON, observe the scan tool Door Lock Switch parameter while using the driver and passenger door lock switches. The parameter should change from Idle to Lock and Unlock.
If the value does not change, refer to Door Lock Switch Malfunction.
Command the doors to LOCK and UNLOCK with the scan tool, the door lock actuators should LOCK and UNLOCK when changing between the commanded states.
If one or more doors do not LOCK or UNLOCK, refer to Door Lock Malfunction.
Aug 12, 2015 | 2009 Pontiac Solstice Convertible
What causes a malfunction in power locks?
The power door locks are controlled by the BCM -body control module ! The door lock switch is an input to the BCM .
First thing to do would be check power an ground circuits at the BCM ! Do you have any other systems not working -power windows etc...
The DR/LCK fuse supplies battery positive voltage to the I/P fuse block for the door lock system. The body control module (BCM) supplies and monitors a reference voltage to the door lock switch through the door lock switch lock/unlock signal circuit. The door lock switch also receives a constant ground source. If a door lock switch is placed in the lock position or unlock position, the reference voltage is taken directly to ground and the BCM detects the voltage drop on the signal circuit.
Should have BCM checked for stored DTC'S - diagnostic trouble codes !
Ignition ON, observe the scan tool Driver Door Lock Sw, Psgr Door Lock Sw, Driver Door Unlock Sw and Psgr Door Unlock Sw parameters while using the driver and passenger door lock switches. The parameters should change between Active and Inactive.
If the values does not change between the commanded states, refer to Door Lock Switch Malfunction.
Command the driver door and passenger door lock actuators to LOCK and UNLOCK with the scan tool, the doors should LOCK and UNLOCK when changing between commanded states.
If a door lock actuator does not perform the LOCK and UNLOCK functions, refer to Door Lock Malfunction
DTC B3130 00: All Door Unlock Circuit
DTC B3135 00: All Door Lock Circuit
Aug 09, 2015 | 2010 Chevrolet Impala
Automatic door locks delaying in locking.
It can be issue with keyfob or door locking mechanism.
Check the help link mentioned below:---
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
2006 Toyota Camry: Power Door Locks Not Working?
http://whatisbyme.blogspot.in/2012/05/2006-toyota-camry-power-door-locks-not.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
All power door locks not working on Honda Accord?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
Power door locks not working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door locks not working on Ford Explorer?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
These details will help.
Thanks.
Dec 06, 2012 | 1995 Chevrolet G20
I have power to the door lock switches on the drivers door but the locks do not work nor does the back hatch or the switch at the back hatch that controls all the locks in the vehicle. Do the locks g
The power door lock system incorporates door lock switches on both front doors and on the RH D-pillar, door lock motors in all passenger doors and in the RR cargo door, a door lock relay and a door lock control module.
Power for the door lock switches and the door lock control module is supplied from the CIG LTR fuse 13 through CKT 640 (ORN). Power for the door lock relay is supplied from the PWR ACCY circuit breaker through CKT 540 (ORN). Ground for the door lock relay is supplied from G202 through CKT 150 (BLK) and ground for the door lock control module is supplied from G400 through CKT 150 (BLK).
The door lock motors are reversible and both sides are connected to the normally closed contacts of the door lock relay. Those contacts of the relay are connected to G202. When any of the door lock switches are placed in the lock position, voltage is supplied through CKT 195 (LT BLU) to the relay lock coil. Since the other side of the lock coil is connected to ground, the coil is energized and it pulls the lock contacts closed. Voltage is then supplied through CKT 295 (GRY) to all the door lock motors and the doors lock. The unlock function operates in much the same manner except that when any of the switches are placed in the unlock position, voltage is supplied through CKT 194 (WHT) to the unlock coil of the relay and CKT 294 (TAN) supplies voltage to the apposite side of the door lock motor and the doors unlock.
Door Lock Control Module Description
The door lock control module is used on vehicles equipped with cargo doors. The purpose of the module is to lock the cargo doors after a lock cycle has been commanded from any of the door lock switches with the cargo doors open. When the RH cargo door is open, the module receives a ground signal from the closed contacts of the rear door jamb switch on CKT 1897 (ORN/BLK) to G400. When a lock command is received, the module retains this input until it receives an open input from the rear door jamb switch. Then the module sends a lock command through CKT 194 (WHT) to the door lock relay and the doors lock.
Rear Cargo Doors Description
The power door lock motor will not operate unless the rear cargo doors are fully closed. The power door lock motor is in the right cargo door. The contactors are on the rear cargo door opening on the body and on the right cargo door.
May 23, 2017 | 1997 GMC Yukon
Central Locking
When you use your remote or insert your key in the Drivers Front door all the door locks should work at the same time by the door lock motors electrically. If you have to manually unlock the door because it will not lock or unlock by the lock motor, you need a door lock motor. The drivers and passengers front door can unlocked with the key manually. The rear doors you have to pull up the latch. If no doors unlock electrically with the remote or drivers door lock, intermittantly or all the time, you will need a Central Locking Electronic Control Module. You will hear the "beep" but no door locks will fire at all. If you have odd door locks not working intermittantly you need a new door lock motor for each door lock that malfunctions. You can hear of the door locks are working electrically. Yes, they are common problem. If you can hear the door lock working but the door still doesn't unlock you need to take the door panel off and lubricate the door latch assembly and work the lock, loosening it up. This is common as well.
May 30, 2009 | 1996 Saab 900
Video Game Consoles & Games Logo
177 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
