Question about Panasonic Dmr-es20s Dvd Recorder Silver
Troubleshoot panasonic DMR-S20
Will not turn on.There is power in the unit and there is only zero's showing on the display.
SOURCE: Panasonic DMR-EH75VS
On the EH50, you have to go into Setup Display Front Display and change it to Bright or Dim. Automatic turns it off when power is off
Posted on Feb 08, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
nandosnut
  • 112 Answers
SOURCE: panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
Posted on Apr 24, 2009
SOURCE: Panasonic DVD player shows EXT-L in its display.
You have switched machine onto external link mode
Either press external link on remote or find it under the flap.
Has a small child been playing with the remote?
Posted on May 28, 2009
SOURCE: PANASONIC DMR-EX768 DISPLAYS MESSAGE EXT-L
Hopefully you will have figured this out by now but you have accidentally turned on the external link function (used to automatically record from a sky box or similar) - simply press the ext-l button on the remote (second row from the bottom of the remote, 3rd button from left) to turn it off again and everything will work normally once more.
Posted on Apr 14, 2010
Unit turns on and off but nothing else works
Simultaneously press the [CHANNEL UP] and [CHANNEL DOWN] buttons on the front of the DVD Recorder for approximately 10 - 15 seconds (until the unit powers off).
Disconnect the wall outlet. Wait for 10 minutes. Then power up.
It this still does not help....and If you are capable of taking the risk check out DMR-EZ47 Firmware Installation Instructions
Panasonic DMR EZ47 Installation Instructions Manual
Familiarize yourself with all the steps and especially the page 7,8 before you attempt this,
Mar 25, 2016 | Panasonic DMR-EZ47V DVD Recorder/VCR
How do I get rid of all these zeros moving accross the display
This problem maybe is caused by a software bug and
can only occur if the Line-in NR is turned on in
DISPLAY > VIDEO menu before starting to
record, Unit hangs after trying to record from Line
Input to DVD
If the "OK" or the "Return" button on the
remote is pressed at this time, the unit will
hang and the front display shows scrolling
"ooo...".
Unit can be recovered by pressing the RESET
button on the front panel.
to correct it Download the improved firmware from
Panasonic Web site and update the
unit
May 13, 2013 | Panasonic DMR-EZ28K DVD Recorder
How can I fix a panasonic dmr-ea18 that is malfunctioning
I'm having exactly the same problem with the same model. Solutions?
Nov 19, 2012 | Panasonic Televison & Video
I have the Panasonic DMR EZ28K and while in stand by mode and even while playing a DVD, the display will show U99. When this happens, the unit will not turn on to record whatever I have programmed. To...
You can probably fix this issue by updating the firmware and doing a system reset. First, download the latest firmware and burn it to a CD. You can download it from here: http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/Drivers-Downloads/model.DMR-EZ28K.D#ts
Now, power the unit down, press Skip/Rev + Time Slip + Open/Close for 5 seconds. The CDR should be in the disc drive as you do this. This will install the new firmware and re-initialize the system settings.
The complete manual is here: http://service.us.panasonic.com/OPERMANPDF/DMREZ28-MUL.pdf
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this answer. Happy holidays!
Dec 05, 2010 | Panasonic DMR-EZ28K DVD Recorder
Have a Panasonic DMR that will not work, keeps showing U61 code
u 61 means-displays when a malfunction has occurred,playback or copy.this is displayed when the unit is in the recovery process to return to normal operation,it is not broken.once the display disappears you can use the unit again.
Apr 26, 2010 | Panasonic DMR-E55 DVD Recorder
Ihave dmr-e55 it records advd for 5 minutes and it goes to self check
1) Press and keep [POWER] button on the unit for more than 10 seconds
to turn off the power of the unit.
2) Unplug power cord and wait for approx. 1 minute.
3) Plug power cord in.
4) The display shows [RECOVER] or [SELF CHECK] and it becomes under
recovery. Wait till the message on display disappears.
*When the unit does not recover after taking above procedures (1 to
4), it is needed to be checked and repaired.
Mar 25, 2010 | Panasonic DMR-E55 DVD Recorder
NO FUNCTIONS
Replace the Digital board
Feb 26, 2008 | Panasonic DMR-E50 DVD Recorder
My display on the dmr-e50 shows ready but will not turn on.
UNPLUG UNIT FROM THE WALL SOCKET & REPLUG AFTER 12 SECONDS.
Jan 23, 2008 | Panasonic DMR-E50 DVD Recorder
Jan 13, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Panasonic Dmr-es20s Dvd Recorder Silver Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
