Question about Samsung RF217ABWP (20 cu ft) Bottom Freezer French Door Refrigerator
Service Ice maker
Need to reassemble the ice maker.
catriver
  • 878 Answers
SOURCE: Ice Maker not dumping
Sailor, Samsung put out a service flash on your model regarding the ice maker fill tube. What is happening is that ice is forming on both ends of the fill tube. When the ice tray twists in the harvest it is hitting on the fill tube and pulling it from it's mount. Could this be why the drive motor seems to weak. The flash number is ASC20060525001. They redesigned the fill tube, part number DA63-02928A. Just trying to help you find an answer...Catriver..post back.
Posted on Nov 15, 2006
thecritter
  • 29 Answers
SOURCE: Ice Maker
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Posted on Mar 01, 2008
Bgillespie
  • 89 Answers
SOURCE: Ice Maker problem
There is a water valve that "feeds" the ice maker. When the Ice maker makes ice it sends a signal to the water valve, it opens for approx. 7 seconds and fills ice tray with water. Another cause of no water in IM could be frozen water line where it feeds the IM.
Posted on Mar 21, 2008
  • 145 Answers
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Posted on Jun 07, 2009
  • 1531 Answers
SOURCE: ice maker wont dump ice. it will refill with
need to replace the ice maker
Posted on Sep 27, 2009
Ice maker water will not shout off Model WRS965CIAE it just runs till the tray overfills
Hello Andy;
My name is Peter. I am a retired field service appliance technician.
You have one of two problems.
1.) Ice maker module - Part Number 821515
http://www.ebay.com/bhp/ice-maker-module.
Fortunately, your ice maker is repairable. The module is like a little computer. It has a circuitry, a motor and a rotating gear set. The module tells the water solenoid valve when to turn on and how much water to fill the cube tray. Then it reads a sensor telling the module that the cubes are frozen. Then it turns on a heater under the cube mold. After a period the module tells the motor to turn on and harvest the ice cubes. It also has a lever arm on/off switch.
Watch the video. Remove the module from the ice maker. You may need a small flat head ***** driver to pop off the cover to get to it. Inspect the circuitry for any burn marks.
You will need to jump start the ice maker after reassembly and if you decide to just buy a new one.
1.) Insert a piece of 12 or 14 gauge jumper wire into the two holes on the face of the module marked: "T' and "H".
2.) Hold in the door light switch.
3.) After the module starts wait 5 seconds and remove the jumper, while still holding in the door light switch, until the ice maker has completer it's cycle and fills with water.
This will not solve your problem. This is how to start the icemaker - not shown in the video
Module Cost: Sears $98.56 + Tax
Ebay $25.00
2.) Ice Maker Water Solenoid Valve: Part Number W10341320.
If your ice maker is filling with water, then the solenoid is working, but the spool valve may be sticking and not closing quickly.
See general replacement video.
Solenoid Valve Cost: Sears $80.00
Search the internet for best price including used.
Go into the Sears website and put in your refrigerator model number. You will get diagrams and component part numbers.
Water Filters Lawn Garden Appliance Parts
Mar 16, 2016 | Whirlpool Refrigerators
Whirlpool Gold model GB9FHDXWS06 :I had the very common problem of the condensation drain being blocked; I removed the inside back panel, which necessitated removing the door, drawers and ice maker. After...
I know this is basic but did you check to make sure the ice maker didn't get switched off in the moving stuff around. Most have some manner of interconnect to shut down the ice maker if the receptacle is not in position - perhaps a wire got knocked loose?
Dec 01, 2014 | Refrigerators
Water keeps running and the ice maker isn't making ice
The ice maker will not make ice with the water running in contently this keeps the water temp to high. Turn machine off, cut water supply off to machine, remove water inlet valve, ether take valve apart and rebuild it or replace the water inlet valve. Reassemble in reverse order and machine should make ice.
Jun 29, 2014 | GE Monogram ZDI15C Automatic Icemaker
Reassembly of ice maker managemylife com
What make and model ice maker?
Jun 17, 2013 | Washing Machines
Had to disassemble ice crusher and lost order of reassembly
go to web sight . www.apdepot.com. put in your brand and model # look at the ice maker bucket assm. this will give you a picture af the proper assembly . pt # 12517801 .. **** .
Jan 05, 2010 | Refrigerators
I have model 3XART720F02 ART706 TYPE 2055A The water ice distribution area needs cleaning. Can this area be dismanteled
Prepare the Ice Maker For Cleaning
Step1Lift the power located above the ice maker storage tray.
Step2Unplug the refrigerator.
Step3Allow the refrigerator and to defrost. This will melt any large blocks of ice that have accumulated in the ice maker
Clean the Ice Machine
Step1Remove the ice machine storage tray.
Step2Dump any water in the ice machine storage tray.
Step3Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
Step4Sanitize the lines of the ice maker. Consult your manufacturer's
directions for steps to do this, because it's not available on all models.
Reassemble the Ice Maker
Step1Replace the ice machine storage tray.
Step2Plug the refrigerator into the outlet to restore power.
Step3Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
How to Clean an Ice Maker
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 21, 2009 | Whirlpool Refrigerators
After my ice dispenser jammed my ice maker stopped making ice
make sure you reassembled it correctly.
icemakers can be stubborn with their safety features and will not work if not propperly reassembled
Jul 30, 2009 | Whirlpool GS6NBEXR Side by Side...
Sub zero particles in ice from ice maker
This issue occurs if your Ice Maker is not clean or have dust particals inside, follow the below steps in order to clean it properly:
Step 1 Lift the power bar located above the ice maker storage tray.
  • Step 2 Unplug the refrigerator.
  • Step 3 Allow the refrigerator and freezer to defrost. This will melt any large blocks of ice that have accumulated in the ice maker.
  • Step 1 Remove the ice machine storage tray.
  • Step 2 Dump any water in the ice machine storage tray.
  • Step 3 Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
  • Step 4 Sanitize the lines of the ice maker. Consult your manufacturer's directions for steps to do this, because it's not available on all models.
  • Step 1 Replace the ice machine storage tray.
  • Step 2 Plug the refrigerator into the outlet to restore power.
  • Step 3 Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
  • Jul 20, 2009 | Refrigerators
    Ice maker arm
    you can take out the screws that hold the ice maker to the freezer wall unplug the ice maker take off the front cover remove the four screws holding the motor module which is brown take that off and reattach the shutoff bail arm and reassemble. their is a gold forked metal piece in there the bail arm has to be in that fork .or you can replace the ice maker
    Jan 09, 2008 | Amana ARB9059CS Bottom Freezer...
    Frigidare FRS23KF6CB manufactured 03/07 ice maker water fill wont shut off
    There is a float in the icemaker which controls water height. I'm going to bet the float is jammed or the switch it controls is bad.
    Dec 08, 2007 | Frigidaire FRS23KF7AB Side by Side...
    Samsung RF217ABWP (20 cu ft) Bottom Freezer French Door Refrigerator Logo
    21 people viewed this question
    Top Samsung Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
