I just signed with ATS. Every morning when I boot up my computer, I can't go any further because there s this message"Configuring updates:Step 1of 5 do not turn off your computer etc. Then up comes another message "updates were not configured correctly. Reverting changes. What does hit mean, how do I get rid of it, why is it there etc. It is most annoying. I am using Windows Vista Home Basic. I am not putting any more money into this.
2 Suggested Answers
  • 7627 Answers
SOURCE: Not configuring update correctly...reverting changes
You didn't give your make, model of laptop, or your OS? What updates? Did you reboot your machine? Shut down, unplug, remove battery, plug in, reboot. Sometimes if you have change the OS on a machine you will get erroneous updates. Sometimes due to other conditions you will get a error message that may help to ID the problem.
Posted on Dec 16, 2012
My computer keeps saying, "Configuring
Here is how you solve this problem...
1. Boot the computer into the "Safe Mode" options by pressing F8 prior the Windows Logo.
2. Select the option "Repair Your Computer"
Note: If you do not have this option, you will need the client's Windows Disc. Once you have that disc, boot into it as if you were to install windows and after you select the language you will get the "Repair Your Computer" option.
3. Now you can get into Command Prompt
4. From the Command Prompt window, navigate to \Windows\winsxs folder
5. Then type: rename pending.xml pending.old.xml
6. Now reboot the PC, you might still see the configuring updates, but this time it will go away.
and walaaa, there you go..
hope this would help you..
please vote.. thanks so much
May 18, 2011 | HP Pavilion dv6000z Notebook
Forgot my acer laptop password
During the boot up process you will see on the screen press a certain key to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
hope this helps
Nov 02, 2010 | HQRP AC Power Adapter Battery Charger +...
My inspiron 1525 crashed and I turned it off using power button. Every time it comes on again it says 'configuring update stage 3 of 3 - do not turn off your computer'. It keeps shutting itself off then...
1. Insert your Vista Media into your dirve and boot from it.
2. Select "Repair your Computer" from the list.
3. Select "Command Prompt" from the recovery choices.
4. At the command prompt change your directory to C:WindowsWinSxS
5. Type: del pending.xml
6. Exit and reboot
This will fix all Windows update reboot loops and does not require you to restore your PC to and earlier state.
Apr 03, 2010 | Dell Inspiron 1525 Notebook
My computer is on step 3 of 3 of system updates -
It seems to be that Update was not done properly.
When computer is booting up, press "F8" key continuosly, it will bring you the Windows where you can find option say " Safe Mode". Enter in Safe mode.Once you logged into the Safe mode, go to start-->Settings-->Control Panle-->Add or Removbe programms -->Click on View upates right hand side and remove all lates update. --< Then Restart computer. It will fix the problem.
Feb 28, 2010 | Computers & Internet
Configuring updates dont stop
I'll assume last known good configuration didn't work, if you press f8 and choose disable automatic restart on failure, you should see the blue screen of death with more info, when you reboot the next time,(you may have to hold in power button for 5 secs), press f8 and see if Repair my computer is listed on the Microsoft Startup menu, if not, insert a windows vista disk and restart,booting to the cd(should happen automatically, but look for a prompt to press a key) choose your language, then choose repair my computer, choose the windows installation, and you can try to use system restore to go back before the uodates were installed and updated, then disable automatic updating so it doesn't repeat.
Mar 26, 2009 | Acer Aspire 5315 Notebook
Acer5920 stuck in configuring updates.
This is generally caused by bad blocks in the Master Boot Record(Table). The drive itself is probably not salvagable. You'll need a reputable reapir person to slave your drive to another system to get the data off.
Good Luck
Mar 21, 2009 | Acer Aspire 5920-6727 Notebook
Pls help me my computer worked perfectly on friday then monday morning when i put it on they tell me configuring widows update 3 of 3 and after that the machine goes off and the same message comes again
Hello. I recommed you to use this:  1. download advanced system care 3 free from 2. download spybotSD - also free program 3. set up  4. run updates 5. run both programs. the advenced sys care will probably do the magic. f you dont get this to work contact me. i can help you to fix this.
Dec 01, 2008 | Computers & Internet
When I switch on Acer Aspire 5315 get message "Configuring updates 3 of 3 0% complete" for a few second then pc shuts down restarts and goes back to the same configuring updates message just...
try starting the computer in safe mode. As the computer boots keep pressing F8 until you hear a beep. The computer will or should start in safe mode, once it has everything will look big, don't worry about that for now, click on start>programs>accessories>system tools>system restore and choose a date for when you know the computer was working without any problems. Once the computer has restored it will shut down and reboot. When/if asked what mode you want to boot/start your computer choose start windows normally. I hope this helps.
Oct 22, 2008 | Computers & Internet
Configuring updates
If it is windows xp OS plz do the following these step.
start the pc in safe mode and select the administrator login then
go to start programme go to acssories select the system tool- selcet the restore option, turn on windows in previous back day and resloved the porblem,.
Jul 30, 2008 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
