Question about Kenmore Washing Machines
8:88 error code
Washing machine all of a sudden started flashing all lights and continuous beep. does not stop unless I unplug it. When I plug it back in, the display shows 8:88 and will not ler me do anything. It just stays like that and then will start the continuous beep until unplugged
SOURCE: LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Posted on Dec 30, 2007
SOURCE: Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
Posted on Aug 19, 2008
SearsTechToo
  • 261 Answers
SOURCE: kenmore elite HE 3t - error code F dU and door is locked
Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
Posted on Sep 04, 2008
aborcass
  • 2651 Answers
SOURCE: FIsher and Paykel washing machine won't stop beeping.
if you remove the back panel you can look under there, there should be atrouble shooter/techsheet that will let you know what the flashinglights mean. if not theres a tech support number to aid you as well
Posted on Mar 02, 2009
tbirdfan1
  • 3051 Answers
SOURCE: F70 Error Code after initial wash. Unplugged
Hello there
Here is your Answer
Error code 70 means a Central Control Unit Heartbeat Failure. There is no
communication detected from the Central Control Unit to the
User Interface (the part that you touch in the middle to set cycles).
Possible Causes/Procedure
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and
the Central Control Unit.
If these connections are ok then
3. Replace User Interface if drum is rotating. Part number is W10164402
4. Replace Central Control Unit if drum is not moving. part number is 8183259
Hope this has been very helpful
best regards michael
Posted on Dec 26, 2009
After starting briefly, why did it suddenly stop?
I know it is an old post but this will help the fault code lights 1 and 7
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
The Motor Control Module has found an error in the pattern received
from the Rotor Position Sensor. Likely causes of this fault are a bad
connection on the harness between the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Watch this video if you are good with fixing things
Fisher and Paykel 130 10000010 Error Code Fix
Jun 06, 2015 | Fisher and Paykel Washing Machines
Smart drive 051 error code 32
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Fisher and Paykel Washing Machines
Samsung vrt wf44aap/w front loading washing machine will not start cycle. Beeping and flashing 3E
Unplug for a few then plug back in. Sometimes his will reset the machine.
Jun 08, 2013 | Washing Machines
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
Simpson encore 605 fault code are as follows during wash process stop suddenly, strat to beep and all lights are gone except the Maxi light . It flashs while beeps
Hi, my Simpson encore 605 wash machine wash on the half way keeps beeping, and the maxi is keep flashing. What kind problem it is?
Cheers!
Feb 12, 2012 | Washing Machines
Hi, I have a F&P smart drive 603. It is continuously beeping and the lights for slow and hold are lit up. The machine is full of water, why has it done this???
Hi just read your posting.I have looked in my manual and the 2 lights that are flashing when the machine is beeping are not an error code.Try unplugging the plug at the power point for 5 min then plug back in and advance the cycle to spin and see if it drains.Please reply on what happens and if it drains.Looking forward to your reply.
Sep 21, 2010 | Fisher and Paykel Washing Machines
Will not start
Alright, unplug the machine for 5 or 10 minutes, after plugging the machine in make sure power is off and hold the spin button down for 5 seconds, then off for 5 seconds until all lights light up, if there is serious error a F code will appear, press spin again until it clears, now 88 appears in the display,flashes and starts a diagnostic cycle. Your error will pop if serious in the display stopping the test at which write the F code down and power off the machine, Either the toe panel or at the right side behind the toe panel is a tech manual to decipher the F bomb.
Sep 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Oasis Elite---110-27086601
This error only shows in diagnostic mode, with power off choose any buttons except stop and power, press in intervals 5 seconds on and 5 seconds off until 88 appears and all light light up. If the user panel is faulted F 2 will flash in the display, press the same button you used to start diagnostics to jump to the next error code and once through 88 will flash and diagnostics will start. Sometimes once F2 flashes and the machine has not been repaired it will stick at that mode.
Aug 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
20 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
