Question about Goodmans CD car radio GCE358MPT CD Player
Radio signal strength not very good
I have just installed goodmans stereo in ford escort and cant get good radio signal all the time. The signal was fine with old stereo. The stereo i have installed also had excellent signal in old car.
  • 3 Answers
It is due to the vehicle antana. you need to purchase a antana booster. hook it to a 12v power plug antana from car to one side of booster and radio to other side. this will increase signal from car antana to radio and should fix problem. most boosters can be found at any car audio or truck stop and run from$10.00 - $25.00 good luck
Posted on May 22, 2009
How do I disconnect factory stereo on 1998 ford escort se ?
I don't see an SE and not sure what you mean by "disconnect" but you can disconnect it electrically at the instrument panel fuse panel by removing the 5A RADIO fuse and the 10A ROOM fuse or by disconnecting the connectors on the rear of the radio
Sep 30, 2012 | 1998 Ford Escort
I have a 96 escort with no radio ;the wires are there,but i want to install a new radio.i don't know what wires hook up to the new radio
Hi, if the connector is still there, it is easiest to purchase a ford wiring adapter. The adapter will match the factory wires to an aftermarket stereo. If the connector is gone, see your factory wire colors below. Please let me know if you need additional help or have any questions, and thanks for using FixYa.
1996 Ford Escort Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
Apr 18, 2011 | Ford Escort Cars & Trucks
What is the color coordination for a ford escort, i want to chance the stereo and the wiring colors don't match up
Here are factory wire colors from modifiedlife.com:
1995 Ford Escort Car Stereo Wiring Diagram
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
If you have more questions, please reply
Sep 11, 2010 | 1995 Ford Escort
Wiring diagram to fit stereo in 1998 ford escort
http://www.tehnomagazin.com/Auto-radio-car-connector/FORD-Car-Radio-Wiring-Connector.htm
Jun 22, 2010 | 1998 Ford Escort
I need a stereo wiring diagram for a 1991 ford escort four door sedan
Good luck and hope this helps, keep me posted if you need more information.
Radio 12v dk. blue/red + radio harness Radio Ground black - radio harness Radio Ignition dk. blue/black + radio harness Radio Illumination dk. green (dimmer) + radio harness Factory Amp Turn-on red/black + radio harness Power Antenna N/A LF Speaker +/- purple - dk. blue/orange +,- radio harness or amp near radio RF Speaker +/- dk. blue/white - white +,- radio harness or amp near radio LR Speaker +/- white/dk. blue - red/dk. blue +,- radio harness or amp near radio RR Speaker +/- white/dk. green - dk. blue +,- radio harness or amp near radioclear.gif
Jan 15, 2010 | 1991 Ford Escort
Installation for a ford escort 98
the easy way is to stop by meijer or walmart or radio shack and pickup an install kit for your car and that way you know where all of the wires go and it will be install right wish the best of luck Michigan Man.also give these websites a try www.alldatadiy.com and www.autozone.com
Nov 02, 2009 | 1998 Ford Escort
2000 ford escort finess audio wiring diagram
Here ya go, this should help ya out... Be sure to vote!!!!
2000 Ford Escort Car Audio Wiring Schematic
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Dark White
Car Audio Rear Speakers Size: 6′ x 8′
Car Audio Rear Speakers Location: Rear Deck
Sep 23, 2009 | 1999 Ford Escort
I have a ford puma r reg my stereo is askin 4 the code i dont know the stereo serial number so i cant find the code
YOU WILL NEED TO REMOVE RADIO FROM CAR ONCE YOU HAVE DONE THAT YOU WILL SEE SERIAL NO. ON SIDE STARTING WITH M. THEN 6 DIGIT NO. GET THAT & I WILL GET UR CODE NO. FOR U.
Feb 21, 2009 | 1999 Ford Escort
Ford Escort 1998 Radio Antenna problem
Go to Crutchfield.com, check out item # 12040UV42, I think this will solve your problem, it's a 6inch male to male adapter. Let me know if it works, if not I'll try to help some more. Happy listening! Almost forgot, it's $9.99.
Nov 21, 2008 | 1998 Ford Escort
Ford Fiesta Radio Code
cant tell you what it is sorry but can give the advice i was told take stereo out using 2 alan keys of small size in little holes at sides this can be tricky but do one side then wiggle while doing other then look at stereo all over most people cant remember it so they write it on one lables stuck to ally cage or stereo its self failing that its a trip to expencive ford service centre
Aug 16, 2008 | 1997 Ford Escort
Goodmans CD car radio GCE358MPT CD Player Logo
236 people viewed this question
Top Goodmans Car Audio & Video Experts
xxxxxx xxx
Are you a Goodmans Car Audio and Video Expert? Answer questions, earn points and help others
