Question about Zenith SY2049DT TV
I have a Zenith model SY2049DT. I just bought an Insignia NS-DXA1-APT converter box, hookes it up and the pictures are purple, expecially the black and white programs
  • 275 Answers
SOURCE: picture is dark
Does not seem like a bad tube alone. Could also be that the Video output Transistors Supply Filter capacitor having dried out. It is a 100mfd 160V capacitor, which on replacement will improve the brightness of the immage. And yes, you could also try increasing the heater voltage (Filament Voltage)of the Pictuire tube, this will definitely increase brightness, but will reduce the life of the Picture tube. You gotta think - 10 year old TV, should I repair or exchange and get a new one???
Posted on Mar 04, 2007
SOURCE: zenith dtv converter, favorite channel button
Found the solution in the user manual. You have to go to the 'edit channel' section of the on screen menu.
Posted on Dec 30, 2008
  • 20 Answers
SOURCE: program my zenith converter box to my tv
while holding down the tvs power button push the channel up or down slowly. this will turn your tv off when your code is found. when it is found and your tv goes off release the power button. now your remote will work with your tv...........
Posted on Jan 02, 2009
  • 75 Answers
SOURCE: I have a Zenith SR2568S TV purchased in 1996
you need to get the box soory
Posted on Mar 01, 2009
SOURCE: DTV converter Box and Zenith system 3
I have the same problem.... On the back of the tv, there are three coax spots. One is for Cable, one is antenna decoder, and another is a loop. I have had zero luck getting any of those to receive the signal. Instead i have ran my digital signal to a vcr, then ran rca cables from it to my tv. I then put my tv in vcr mode, or aux depending on where you hooked it up. You can watch tv through your vcr this way.
Posted on Apr 14, 2009
Insignia ns-dxa1-apt receiver is not picking up signal and all cables are connected correctly, we have suddenlink cable. Does this receiver not work with them?
Hi- My name is Shannon and I am with Suddenlink. If you are still experiencing trouble, I would be happy to assist you. Please email me directly at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 04, 2012 | Insignia NS-DXA1-APT
I own an Insignia flat screen tv, NS-LCD27, & I was given the Insignia converter box, NS-DXA1; how do I program tv remote for the box? Thanks, frances b.
The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
A replacement remote for your TV is available here: http://www.mcmelectronics.com/partfinder.aspx?brand=&mdl=NS-LCD27&mode=part . An exact replacement remote for the converter box can be purchased at: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13055197980390&smodel=NSDXA1&brand_pn=INSIGNIA_NSDXA1 . The manual for the converter box (as a PDF) is here: http://cbsdallas.files.wordpress.com/2011/01/insignia-ns-dxa1-manual.pdf .
I hope this helps.
May 16, 2011 | Insignia Televison & Video
I need to program a universal remote, a ge modal249 my Insignia modal NS-DXA1-APT digital analog converter chgang4895@yahoo.com
Since Insignia and LG share compatible codes for digital-to-analog converters, review your remote control's manual for LG VCR codes as they should work to control our converter.
Apr 19, 2010 | Insignia Digital-to-Analog Converter for...
Have an Insignia (NS-DXA1-APT). Have tried 3
connect up another tv and see if it is the tv or where you live.if the tv is the culprit then you have a defective tuner in the tv and is probably is not available.
Jul 18, 2009 | Televison & Video
Programming Insignia Digital Box to Phillips Universal Remote
I have the Phillips Universal Remote (model#SRU4208WM) and I have the Insignia digital converter box (model#NS-DXA1-APT). The code was 0267. The Insignia converter box is the one the government grants work for.
Feb 03, 2009 | Insignia Digital-to-Analog Converter for...
Is the LG DTT 901 the same as the Zenith DTT 901
I don't think there's an actual LG DTT 901. They make the digital converter boxes for Zenith (DTT 901) and Insignia (NS-DXA1-APT). Look at this chart:
http://en.wikipedia.org/wiki/Comparison_of_CECB_units
Jan 09, 2009 | Logitech Harmony 550 Remote Control
Insignia NS-DXA1 APT remote control doesn't work
Set your TV input to match the input your have your Insigna connected to. Then run the Insignia setup. You are getting a distorted screen because you probably have the Insignia connected to channel 3 and the TV on channel 4.
Dec 30, 2008 | Insignia Digital-to-Analog Converter for...
Remote doesn't work for the Insignia converter box
Strange as it seems, both converters had "bad" batteries included for the remote. Bought new batteries, problem solved.
Dec 27, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
14 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
