Question about GoJo Soap Dispensers LTX-12 Touch Free Soap Dispenser, Chrome
Dispenser not dispensing soap. red light flashing
2 Suggested Answers
  • 17 Answers
SOURCE: Our 2 soap dispensers have
You might try taking out the batteries and wiping the area dry. It may be that the batteries are not getting a dry connection. Also, make sure the batteries are replaced correctly. There is usually a diagram with the battery placement on the lid where the batteries are installed. Also, sometimes the soap dispenser can get clogged. In that case, make sure to take the batteries out and then run hot water thru the area where the soap comes out. Hope this helps out.
Posted on Feb 25, 2011
How do I fix a whirlpool model number WFW9050XW00 soap dispenser overflowing water and not going into the tub?
Whirlpool WFW9050XW01 Use Care Manual Page 12
Sounds like the line between the soap dispenser and the tub is clogged. If you look at page 12 of the link I provided, it will show you how to remove the dispenser tray. Check, with a flash light and see if there is any obstruction. You can use a small flexible plastic snake to clear any obstruction.
Good luck.
Semper Fi,
Z
Aug 03, 2017 | Whirlpool Washing Machines
Tip
Fix simplehuman soap dispenser
Solution!!!!! to Simplehuman sensor soap dispenser with blinking red light no despensing of soap and new batteries. Rinse out soap with hot water. Fill reservoir with hot tap water. Use bulb end of turkey baster. Place on reservoir to form a tight seal. Force air into reservoir. Which will force the hot water thru the system unclogging the thick soap. Repeat this several times till clear of soap. Then turn on the unit and flush thru the rest of the hot water using the sensor till comes out nicely. Then fill with a thinned out soap. Good luck
on Jan 16, 2014 | Simplehuman Sensor Soap Pump ST1001
Blinking light
The issue is the dispensing unit you have is a sanitizer dispenser, not a soap dispenser. The adapter collar on the bottle is the issue. Soap dispensers use a GRY collar, sannitizers use an LBL collar. There should be a sticker on the dispensing unit that says "LBL" or "GRY". Try removing the collar from a sanitizer bottle and place it on your soap bottle......should work fine. In short, make sure your letter code on the bottle mathces the letter code on the dispenser.
Jan 30, 2014 | GoJo Purell 2720-12: TFX ? Touch Free...
How to get soap to come out of dispenser of mcculloch power washer fhh 18a
Most people make the mistake of using a high pressure tip on their power washer while trying to get the soap dispenser to work. These tips are usually red, green, white or yellow and they cause too much back pressure at the dispenser for it to work. You need to use the soap tip, they're usually black, for the dispenser to work properly.
Jun 17, 2012 | McCulloch Garden
Won't dispense soap. Changed batteries twice,
Sometime the viscosity of the soap could be the culprit. If you had changed to a thicker soap sometimes those pumps can't handle it. Try a less viscous soap and lets see what happens. Good Luck PAL
Jul 26, 2010 | NRS iTouchless Stainless Steel Automatic...
We have an Emerson hands-free soap dispenser that won't work. We've installed brand new batteries and it still won't dispense soap. The red light comes on to indicate it' s working but no soap will come...
We have 5 Emerson hands-free soap dispensers that don't work. Tried new batteries, light comes on, but no soap comes out. How can we get our money back?
May 20, 2010 | Vacuums
I have a Simple Human 14 oz sensor Soap Dispenser
This is what I found in the Simplehuman FAQ's. I had to wait about 30 minutes for the light to stop blinking, but it seemed to work for me.
If the pump is unresponsive or the blue light is flashing, fresh batteries should resolve this issue. Please power off the pump completely. Once the pump is turned off, remove the old batteries. Please wait for the pump to reset (until the flashing light stops and preferably letting it rest overnight) before you install the new ones.
Aug 05, 2009 | Kitchen Appliances - Others
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
GoJo Soap Dispensers LTX-12 Touch Free Soap Dispenser, Chrome Logo
1,995 people viewed this question
Top GoJo Home Experts
jrand1970
Level 1 Expert
Mike
Tom Chichester
Are you a GoJo Home Expert? Answer questions, earn points and help others
