Question about Polaroid PDV-0700 Portable DVD Player
Polaroid pvd--0700 ribbon cable replacement - Polaroid PDV-0700 Portable DVD Player
2 Suggested Answers
SOURCE: polaroid fdm-0700 with black screen display. DVD
go here to see a how to replace the board
http://clickondavid.com/photo1.html
And downloada pdf on the procedure
Posted on May 14, 2010
WHERE TO BUY A NEW POLAROID PVD 0700 BATTERY
Go to www.ebay.com Type: make and model, refine search for battery, if available you will be presented with a list.
Apr 01, 2012 | Televison & Video
Polaroid fdm-0700 with black screen display. DVD
go here and order the replacement inverter board. this will fix the backlight issue or no picture issue
http://lcdparts.net/LCDTVInverterdetail.aspx?InverterOriginal=UI8007S-1MSS
Aug 09, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Error: Bad disk
If you are using original discs and have the problem. Try with a cleaning disc and is still the same, check for calibrating the optic lens. About how much is the replace or the calibrating you have to ask on the repair shop or manuf. website. Sometimes, is better buy a new one because the technology moves so fast it makes the same technology disposable.
Jul 29, 2009 | Polaroid PDV-0700 Portable DVD Player
Dvd player, pvd-709
Hi lindy,
My kid broke the ribbon tape, so I took it apart. It is easy to fix all you have to do is plug it back in if the connectors are in tact. 1 goes to the reader and the other plugs into the circuit board. My problem is that I cant find a new flat ribbon cable/wire anywhere.
Aug 12, 2008 | Durabrand PDV-709
Car Adaptor
here is an free 800 number you can call and ask the techs to make positive friend
Polaroid electronics
1-866-400-5168
Hope that fixya up there
Nov 19, 2007 | Polaroid PDV-0700 Portable DVD Player
Will not read disk
If you can go into the player then check to see if ribbon cable is attached. If it is ok then probably see if laser move by sticking something in the lock mech. that starts the disc to move and if it doesnt moves then throw away, cause is not worth buying new one.
Nov 29, 2006 | Polaroid PDV-0700 Portable DVD Player
No video - just a white screen
So I am guessing you have audio and no video, your monitor has went out. you can check and see if ribbon cable is slightly uplugged, but maybe just a bad monitor. These happen usually from a drop or hard hit to the unit.
Sep 28, 2006 | Polaroid PDV-0700 Portable DVD Player
Definite ribbon problem!!! Need help.
Hi It's sad when a simple problem, causes a piece of equipment to be thrown away, while all the expensive parts are still ok. If you are mechanical, and can carefully take the unit apart,(make sure it is unplugged), the ribbon cable may be a plug-in type, and you can remove it from it's connector on the monitor end, and in the main unit, and if you bring it to your local electronics repair shop, they may give you one if they have one the same size (same # of conductors), or sell you one for a few dollars. Otherwise, if you have a fine tipped soldering iron, and experience soldering, you can bypass some or all of the damaged connectors in the ribbon cable with small wires. Cut them to length, and solder them to the respective pins on the ribbon cable connectors. Hopefully, you can see which lines on the ribbon cable have been damaged, and will only have to hard-wire bypass a couple. Otherwise, it would be more economical to replace it. Hope this helps! Good Luck!
Sep 26, 2006 | Polaroid PDV-0700 Portable DVD Player
Polaroid PDV-0700 Portable DVD Player Logo
37 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
