Question about General Electric WCVH6800J Front Load Washer
Wcvh6800jww machine making humming noise during drain and fill. Unplugged waited three minutes the plugged back in. Now power swithch will not illuminate and the only thing on the display is door locked.... followed shortly by the same hum... any ideas?
4 Suggested Answers
  • 1382 Answers
SOURCE: Washer door will not open. Power button will not
You can manually unlock the door on this washer. First you should unplug the washer from the wall outlet and then remove the lower access panel. With the lower access panel removed, and the washer unplugged, reach up to the door lock and feel for a round release ring and pull it down. The door should unlock now.
Thank you !!
Posted on Jun 30, 2010
  • 29 Answers
SOURCE: ge WCVH6800 front load washer.
Has this been solved? I have the same problem only I do not remember a power failure. But the other things are the same. <!-- from fixya rte -->
Posted on Aug 16, 2010
  • 1075 Answers
SOURCE: when washer starts it usually
your main belt is broken or loose i would suspect the latter,the reason the door will not open is the machine has started a wash cycle and because the belt is not able to finish the cycle the door wont open so the progam is not finished,switch the machine of at the mains and the door will open after 10 mins.But the problem remains the belt.please rate this answer thanks.adrian,,,,,,,,,
Posted on Aug 23, 2010
Maytag centennial washer
Put some water in the washer tub, a few gallon should do it. Then turn machine back on, it will recognize when the water has drained out and stop that cycle.
Aug 05, 2017 | Washing Machines
My machine had been giving E20 error code - cleaned out filter and pressed start button and it started again ok. During wash it jammed and all lights went on (except spin speeds) and it wouldn't...
E20 is a general error code to get to the real problem try this.. Reading ErrorCodes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
Kenmore Oasis Washer won't drain. "Ld" code during
Hi
Error code LD means long drain. This error appears when the washer takes more than 5 minutes to pump out the water till point where pressure switch resets. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. Hope this helps... Please post back for more information.
Daniel
Nov 26, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
The washer stopped all of the sudden. It was full of water, but even when I unplugged the washer and recycled the machine, it would not fill up. It makes a humming noise when I try to start the machine,...
If it fills and drains then I would suspect the motor coupler is bad, if it's a direct-drive washing machine. Most of them are, kenmore 80 or 90 series.
Oct 10, 2010 | Kenmore Washing Machines
Code
The PF stand for Power Failure. When you unplugged it, it truely did have a power failure..
Nov 02, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Won't drain
dip as much water as possible from tub..remove bottom panel remove clean out port on pump clean and reinstall
Aug 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Humming and not filling?
had the same problem this morning, turned out the pump on the drain side had frozen, took it apart, and broke free the fan, humming stopped, washer back up and working.  Its two screws to the bottom of the washer, two electrical connection (white and black) two hoses to undo, and three screws on the pump itself, after actually committing to doing it, only took about 10 minutes.
good luck
Oct 13, 2007 | GE WSXH208A Front Load Washer
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Stalled Motor
quite possibly the drain pump which would cause it to stick in rinse cycle. the humming noise you heard is probably the drain pump powered up but jammed. likely cause is a foreign object stuck in the pump impellor - main culprit is bits of bra wire. take the pump to pieces and extract whatever is jamming it.
May 12, 2007 | Kenmore 24852 Top Load Washer
General Electric WCVH6800J Front Load Washer Logo
21 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
