Question about Veo Observer Network Camera
Problems with cam veo sn/601VB35X observer, suddenly stopped working in local network if I can access it remotely cun but do I connect only have access to the language and not the user name and password, I have said that the firmware update camara because of the problem is the active X. I would like to know if anyone has the solution or the firmware. My email is raulmedina48@hotmail.com Thank you for your answers
  • Veo Master
  • 10,322 Answers
1st You download Webcam Driver.
camara Driver After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Veo Camera Drivers for Windows XP Vista Windows 7
Posted on Mar 03, 2014
  • 1,006 Answers
It can bre the password expires every 30 days or 3 mnth or sumthin....Check the firewall ( TURN IT OFF )
Posted on Oct 19, 2007
VEO observer hard wired version
Did you configure the webcam to be accessible over the internet? The IP address that you are using in your home network for the cam is only valid there (I assume you are running on a workgroup).
Jan 25, 2008 | Veo Wireless Observer Network Camera
VeoNetwork Web cam
You can view your Veo Observer web cam at home by either of two methods. The first is to use the Observer Studio software that came with the camera. When you configured the camera, you selected a local (private) IP address for each Veo Observer, and set the address specific to each camera. You then put the same IP address into your Observer Studio Software.
Depending on the brand of router you use on your home network, your Veo Observer camera probably has a local (private) IP address in the format 192.168.0.xxx or 192.168.1.xxx where "xxx" is the actual address assigned to your Veo Observer (by you) and configured to display on the LCD window on the side of the Veo Observer.
You may need to log into your router to see which of the two local (private) IP address formats is used. Your router's user manual will show you how.
To view your Veo Observer, just type the exact local (private) IP address in your IE browser. for example, if you assigned address 100 to your cam, you would enter http://192.168.0.100 or 192.168.1.100 into your browser. Veo Observer will display the Language selection screen. Choose the language, then you log in and view your camera.
To view your camera from outside your home using another computer, you use the same method, but you have to substitute your WAN (public) IP address.
You can log into your router and select its STATUS tab to view your WAN (public) IP address. See you router's set up guide if you do not know how to do this.
An easier way to determine your WAN (public) IP address is to visit Gibson Research Shields Up! web page:
https://www.grc.com/x/ne.dll?bh0bkyd2
and scroll down to the last paragraph where you will find your WAN (public) IP address.
For example, if this address is 123.456.789.100, then you would enter http://123.456.789.100 on your IE browser. You should see the Language select screen, choose your language, then log in and you are now viewing your Veo Observer from outside your home.
Note: when you view your Veo Observer at home, you probably have a fast frame rate and smooth video motion. When you view your Veo Observer from outside the home, the frame rate is certain to be less, and your moving image quality will be choppy. This is normal, as viewing from outside the home is less efficient and the image suffers. There is nothing you can do to boost the frame rate.
Jun 15, 2008 | Veo Observer Network Camera
Veo observer
Connect your pc to your webcam directly with a cable,and close the firewall software on your pc,then try the set up utility.
May 20, 2008 | Veo Observer Network Camera
Veo network observer
since IT is a IP webcam,you should know what the IP address at your work and make sure that you can access that IP when you are at home.
May 15, 2008 | Veo Observer Network Camera
No installation software disk
http://www.camera-drivers.com/drivers/237/237620.htm
also in driver guide can you find your driver, the site requesta a free registration.
Thanks
Sergio
Feb 02, 2008 | Veo Observer Network Camera
No Wireless Camera Not Found
While you had it plugged in the serial port you should have set the SSID name for the camera? You may have to enter this manually to find the camera. If it is not set to broadcast this SSID, it will work but you must put it in the wireless connection settings.
Aug 08, 2007 | Veo Wireless Observer Network Camera
Voe observer down
Can you help me? I have an Observer camera too. And I have the problem "no response from camera" (Veo Observer Studio) and I can't reach the camera via Explorer too (the page dosen't exist).
Earlier it is working well except the remote access. I try it resolve and came the problem: "no response from camera".
What was the solution at your camera?
thanks
May 29, 2007 | Veo Observer Network Camera
Veo Observer network camera
Make sure that you are using Internet Explorer 5.0 or higher. If you are experiencing problems, try upgrading to the latest version of Microsoft's Internet Explorer from the Microsoft webpage at: http://www.microsoft.com/windows/ie Method A: 1) Go to C:\Program Files\Veo Observer Studio and delete the files: xrlknc.dll and xrlkncd.dll. 2) After the files have been deleted, try using the Veo Observer Studio again. --or-- Method B: 1) Uninstall the Veo Observer Studio from your computer. 2) Download the latest version of the Veo Observer Studio from our webpage at: http://www.veo.com/Observer/firmware.asp if it still has the same promblem refer to your display or the grafix recommendations
Oct 15, 2006 | Veo Observer Network Camera
Oh dear!,Wireless is a pain, could be your firmare needs upgrading if it isn't already,(this is from 2003) you can download it here http://www.veo.com/Observer-Wireless/firmware.asp If not check it's ip address is showing up in the router. Also there may be interference from other appliances or walls and objects; causing it to loose it's wireless connection.
Oct 11, 2006 | Veo Wireless Observer Network Camera
Veo Observer Network Camera Logo
139 people viewed this question
Top Veo Computers & Internet Experts
micky dee
Sulkhan Abesadze
Sulkhan Abesadze
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
