Question about Pacific Cycle Cycling
What size tire tube for a schwinn/side winder men's 26",need to be replaced
  • 6 Answers
SOURCE: What size tire tube goes in a 700x28c Denali Bike
700c tyres are bigger than 26".The tubes you need measure 700x28 (to32).This size is used in Hybrid style bikes.Make sure you get the same type of valve(Schreader are the same as car,Presta are narrower)or it won't fit the hole in your rim.
Make sure when inflating that the tube isn't trapped between the tyre and the rim.Only inflate to the pressure written on the sidewall of the tyre.
Posted on Sep 26, 2009
ftw1952
  • 10319 Answers
SOURCE: i'm trying to date my Schwinn bike. Serial # is
looks like a 1950 model
Check it out for your self on the link below by clicking it on
http://www.re-cycle.com/History/Schwinn/SwnB_Serial.aspx
Posted on Jul 08, 2010
  • 83 Answers
SOURCE: schwinnn men's 26 " jaguar
The tires will say on the side-wall, it's likely around 45-50psi.
Posted on May 05, 2011
dunnbiker
  • 8546 Answers
SOURCE: baugth schwinn bike midmoor 26
'Not right'??? You can find answers to most 'how-to' questions with simple web searches. Schwinnbikes.com has basic generic manuals.
Posted on Sep 16, 2011
  • 34789 Answers
SOURCE: What size tubes do i need to get for a 26" men's
Refer this question to a bicycle shop
Posted on Jul 16, 2013
I have a Schwin Solution FS AL mountain bike. I would like to put road tires on it. It now has 50-507 (24X1.95) on the side wall of the knobby tires. What road tire would fit?
I have done a similar thing with my mountain bike. The first number is the size of your wheel. The second number is how thick your tire is. You can get any road tire that has a "24" in the first number of the 24X***. Depending on the number after the 'X' you will probably need to get an inner tube that falls within that size. Most of the inner tubes will have a range for that second number. If the number is too large the inner tube will not fit inside the road tire.
Jan 30, 2015 | Schwinn Mens Solution FS AL 24 Bicycle Red
What is the air pressure or psi for a schwinn bicycle called discovery 700c
All tires have the maximum inflation pressure molded into the sidewall.Try inflating to about 5psi below the max as a start.(My 26" tires are "MAX INFLATION PRESSURE 65PSI",I like it at about 50psi.
Sep 17, 2012 | Pacific International Mens Schwinn 700C...
Schwinnn men's 26 " jaguar
May 05, 2011 | Schwinn Men's 26" Jaguar Cruiser Bike
What type of bike tires are they?
There are lots of different wheel sizes on bikes today (20", 24", 26", 700c, etc.), and lot of different tire widths for all those different wheel sizes. Fortunately, tires are marked with their size, so you just need to learn how to read those markings, and they are not complicated.
For the purpose of picking a replacement tube, there are just two numbers you need to know: tire diameter and tire width. These numbers are always written somewhere on the side of each tire. (Sometimes when tires get old the numbers are hard to see. Don't give up, just keep looking.) Here are some examples of what the numbers might say: 26×1.95, 700c x 25. Sometimes the there will be three numbers, something like this: 26×1-1/2×1-3/4. Don't worry about that, just remember the first number (26 in this example), and the larger of the other numbers (1-3/4 in this case). Sometimes there will be letters with the size (such as EA3 or S-6). Sometimes there will be another number or two in parentheses, for example (622) or (559-45). Don't worry about those letters and numbers. They are important for getting a replacement tire that fits, but not important for replacing the tube.
The numbers can be hard to remember. It's a good strategy to write them down somewhere to bring with you.
Dec 21, 2010 | Cycling
How do you set up brakes after changing tube? What is the position of the lock washers - inside or outside of frame?
The lockwashers go outside the frame, right next to the nuts. But I would need more info to answer the brakes question. Schwinn called lots of bikes "Jaguar". If this a single-speed bike with a coaster break, then you can Google images for COASTER BRAKE..
Aug 18, 2010 | Schwinn Men's 26" Jaguar Cruiser Bike
What size tire tube goes in a 700x28c Denali Bike tire? I installed a schwinn 26inch tube, rode the bike around the block, parked it in the garage and two hours latter, sitting in the garage, the tube blew...
Sep 25, 2009 | GMC Denali 700cc Women's Road Bicycle
I need a drawing to reassemble my Schwinn Tiger, can you help?
I don't know the year or size of your bike, but schwinn's website has manuals from '03 to '07 online.
If the bike is older, I can only suggest searching the internet for photos of your bike. Sometimes a picture is worth a thousand words.
Sep 03, 2009 | Schwinn Windwood 26 Men s Cruiser Bicycle
Need tire tubes for back tires. Can't find anywhere. please help or Schwinn should take back faulty product.
Usually you can look on the tire sidewall and find the info you need.For a really good explanation of tubes and tire sizing try http://www.sheldonbrown.com/tire_sizing.html In general a 12" marked tube should fit a 12" tire. There are other factors to consider though and the mentioned site explains them all very well. When you replace the tube make sure you use plastic or synthetic tire tools to prevent a pinch flat. A pinch flat occurs when you accidently puncture the tube while mounting the bead of the tire back on the rim and the tube gets caught between the rim and the tire or the tool and the tube etc. Only put enough air in the tube to give it a little shape when inserting it in the tire. Hope this helps. Get back to me if you need any more advice and I can further direct you.
Jul 09, 2009 | Schwinn 12" Roadster Tricycle
Cycling Logo
19 people viewed this question
Top Pacific Cycle Cycling Experts
John Egan
John Egan
Are you a Pacific Cycle Cycling Expert? Answer questions, earn points and help others
