Question about RCA RS2656 Shelf System
No fm reception - working fine and suddenly quit during an fm radio broadcast - now no fm channels work - only static
Fm antenna is firmly affixed and extended - no broken wires evident; all other system medias working properly
3 Suggested Answers
  • 277 Answers
SOURCE: no reception
hi YES that will b the problem... if you got a window try puting the system with the ANT outside and see if you recive anything if soo try fixing it there if u cant..do it the lazy way...: attach a copper wire (a speaker wire) to the ANT and set its end outside the longer the wire - the inferior signal you will get good luck
Posted on Feb 23, 2006
  • 905 Answers
SOURCE: FM Radio doesn't work
it may be that the fm detector has failed or possibly a tank(tunning coil)
Posted on Oct 06, 2008
My Denon Stereo Receiver (DRA-345R) (quite an old model but has worked perfectly up until now) has a very static reception on AM. FM is fine. It started when I had my DirecTV upgraded with a Genie (whole...
it's obviously getting interferance fronm that whole house broadcast unit (not abnormal!) best and only thing you can do is to move the stereo to a place where you can get the MOST am stations the loop ant. is exactly what it says it is a loop of wire with two ends..both ends connect to the ant. input on the back of the unit..however if that whole house broadcast unit is the devil then an ant. no matter what or how it's made will only recieve more static not built to reject static! so you've got to move it unfortunately ..fm is a totally different band obviously fm isn't being affected by that whole home broadcast unit..you're lucky! on that count
Dec 12, 2013 | Denon AVR-2307 Receiver
Subaru antenna
Check the antenna connections.
Jan 04, 2018 | 2008 Subaru Outback
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
1995 buick riviera radio was working fine now all of A sudden radio has A lot of static.
LOOK FOR BROKE OR MISSING ANTENNA.IF ALL IS GOOD RADIO ANTENNA LEAD ON RADIO COULD CAME A LOOSE OR RADIO RECEIVER IT SELF FAULTY.MAKE SURE RADIO BAND IS ON FM INSTEAD AM.BECAUSE AM STATIONS HAS STATIC.
Jul 02, 2010 | Cars & Trucks
The AM/FM radio in my 2003 cadillac CTS faded to only static
check antenna cable connections at radio & antenna.suspect power antenna if equipped.
Sep 30, 2009 | 2003 Cadillac CTS
FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
May 31, 2009 | Jensen CD400M CD Player
Radio static only but meta data displays
There will be static. A lot of my passengers are surprised that there is static on satellite radio, but there is. Your Sirius satellite receiver "broadcasts" to your car's FM radio through a frequency you select. For example, the Sirius channel on my car radio is 89.1, which is pretty clear and works pretty well on my regular commute. But if I drive beyond that route, where 89.1 is routinely used by regular broadcast radio stations, there is a lot of interference and static. I then have to switch frequencies on both the receiver and car radio, to find another clear channel. Quite a pain. There will be interference. Even the smallest bridge, tunnel, or parking garage often seems to block satellite reception, and occasionally the signal will completely disappear for no reason.
I DID TONS OF RESEARCH FOR YOU ABOUT THESE RADIOS. THE SAME PROBLEM YOU HAVE ARE FOUND BY 100'S OF OTHERS. IT'S THE COMPANY THEMSELVES HAVING DIFFICULTIES.
Sep 14, 2008 | Alpine CDA-9856 CD Player
AM Reception
what kind of car are you driving. on some cars the antenna need to be extended in order to recieve am reception.
May 27, 2008 | Kenwood KDC-222 CD Player
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
No radio
The front end is bad on this reicever. Your going to need special equipment to trouble shoot this problem, as Its all RF. It is most likly not worth repairing as a shop will most likly charge you more then its worth
Sep 16, 2006 | Denon AVR-1100 Receiver
RCA RS2656 Shelf System Logo
18 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
