Question about HP-NOTEBOOK SB ELITE Hp Elitebook Folio 9470m C9h54ut 14.0" Led Ultrabook - Intel - Core I5 I5-3317u 1.7ghz - Platinum -
How to replace keyboard from 9470m - HP-NOTEBOOK SB ELITE Hp Elitebook Folio 9470m C9h54ut 14.0" Led Ultrabook - Intel - Core I5 I5-3317u 1.7ghz - Platinum -
How do you stop the cursor from jumping on an elitebook folio 9470m
go to control panel / mouse to open the mouse properties window. along the top of the window should be several tabs. select the tab for touchpad or maybe advanced properties. this tab allows you to adjust the touch sensitivity of the mousepad, momentum, and other properties. adjusting to make it less sensitive may reduce the tendency of the cursor to jump or move on its own. failing that, go for an external mouse!
Aug 14, 2014 | HP EliteBook Folio 9470m 14in LED...
How to disable mouse
have you tryd going into your control panel and click on you mouse icon and try turning off from there.
Jun 29, 2014 | HP EliteBook Folio 9470m C6Z63UT Notebook...
How to replace touchpad on hp elitbook 9470m
The video will show you step by step how to do it.
I don't think I would have the patients for that anymore
& I'm an old ham & cb radio hobbyist.
Jun 12, 2014 | HEWLETT-PACKARD EliteBook 8460p Notebook
How to install ram on an hp 9470m
Before removing the service cover, follow these steps:
1. Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the
computer on, and then shut it down through the operating system.
2. Disconnect the power from the computer by unplugging the power cord from the computer.
3. Disconnect all external devices from the computer.
4. Remove the battery
5. Remove the hard drive cover
Remove the service cover:
1. Loosen the 5 captive Phillips screws (1) that secure the cover to the computer.
2. Tilt the door up from the computer slightly (2), and then lift the cover up and off the computer (3).
Remove the memory module:
1. Spread the retaining tabs on each side of the memory module slot to release the memory module.
See pages 47 and 48 for more detailed directions and pictures.
http://h20565.www2.hp.com/portal/site/hpsc/template.BINARYPORTLET/public/kb/docDisplay/resource.process/?spf_p.tpst=kbDocDisplay_ws_BI&spf_p.rid_kbDocDisplay=docDisplayResURL&javax.portlet.begCacheTok=com.vignette.cachetoken&spf_p.rst_kbDocDisplay=wsrp-resourceState%3DdocId%253Demr_na-c03909856-1%257CdocLocale%253Den_US&javax.portlet.endCacheTok=com.vignette.cachetoken
Mar 20, 2013 | Computers & Internet
How to unlock the touchpad on a HP EliteBook Folio 9470m?
On the mouse pad there is a dot in the upper left. Tap it twice with your finger.
Jan 11, 2013 | HP EliteBook Folio 9470m C6Z63UT Notebook...
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
Laptop keyboard keys
To determine if the keyboard or the keyboard controller is faulty, plug an USB keyboard into the USB port on your laptop. If all the keys are OK on the USB keyboard then the laptop's keyboard is faulty and needs to be replaced. If the USB keyboard also malfunctions then the keyboard controller chip on the motherboard is faulty, then the motherboard needs to be replaced, but this may not be a cost effective solution.
A replacement keyboard for your model laptop maybe available from this WEB site.Keyboard replacement, LCD screens for mobile phones, Ipods and computer equipment. http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Sep 07, 2012 | Computers & Internet
Keyoard o hp dv-6 laptop has keys that will ot work ay more
Connect an USB keyboard to your laptop and if the keyboard functions normally then you need to replace the laptop's keyboard or just use the USB keyboard.
You maybe able to get a replacement keyboard fron this site.
Keyboard replacement, LCD screens for mobile phones, Ipodsand computer equipment.http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Aug 01, 2012 | HEWLETT-PACKARD Pavilion DV 6 Laptop
Replace keyboard on acer 8100 series laptop
Replace the inside of the keyboard with a new piece. One of the major problems with Dell keyboards is that the plastic pieces holding the keys in place become loose or broken. You can find a cheap keyboard from Papatek.com or an electronics store. Simply take apart the new keyboard, pull the keys off your keyboard, lay the plastic piece on top and replace your keys.
http://www.papatek.com/Acer-Keyboard/Acer-Travelmate-8100-keyboard.html
Jul 23, 2010 | Acer Ferrari 4000 Notebook
HP-NOTEBOOK SB ELITE Hp Elitebook Folio 9470m C9h54ut 14.0" Led Ultrabook - Intel - Core I5 I5-3317u 1.7ghz - Platinum - Logo
74 people viewed this question
Top HP-NOTEBOOK SB ELITE Computers & Internet Experts
David Payne
David Payne
Are you a HP-NOTEBOOK SB ELITE Computer and Internet Expert? Answer questions, earn points and help others
