Question about Lexmark X4270 All-In-One InkJet Printer
Error 1203 The printer X4270 tells me about error 1203 and I can't find a manual to fix it. When I try to print it tells me that the printer is busy, but I don't have anything on que
  • Daniel Ortiz May 25, 2009
    Thank you, there was a problem with the black cartrige.
  • Lexmark Expert
  • 228 Answers
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
Posted on May 23, 2009
I want to print the letter . on the machine's screen i saw error #1203. it wrote consult user guide . could you tell me how to slove the problem
1203 error indicates a communication problem with your printer and one of your cartridges. Please refer to this article in the Lexmark website: How to Troubleshoot a 1203 Error on the Lexmark X4250/X4270/F4270 Printers. This will help you identify and resolve the 1203 error message on your printer.
Apr 21, 2011 | Lexmark X4270 All-In-One InkJet Printer
My all in one says error#1203 when im trying to print something
go to "lexmark.com" select "customer support, type in 1203 error and it will display several solutions how to fix your problem.
Oct 26, 2010 | Lexmark X4270 All-In-One InkJet Printer
I have error eading 1203 what is that and how can
I have an error reading 1203 that won't let me print. Message consult users guide.
Oct 08, 2009 | Lexmark X4270 All-In-One InkJet Printer
Need UsersGuide for Lexmark X4270, ?code 1203? on LCD panel!
cant find a user manual, only install manuals :(
from reading on your error it seems to point to an ink cartridge issue have a read of some of the following links
http://www.fixyourownprinter.com/forums/printer/38960
http://www.fixya.com/support/t131154-error_1203
loads more, just search lexmark x4270 error 1203
May 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Problem re Lexmark X4270
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Feb 16, 2009 | Lexmark X4270 All-In-One InkJet Printer
Lexmark x4270 error code#1203 want print
Please visit this below mentioned link to solve your problem:
Error Code 1203
Thank you
Dec 07, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error code 1203 with my lexmark x4270
have you tried cleaning the gold points on the cartridge heads and cartridge slots. Use a proper claning solution and non scented baby wipes or q tips (cotton buds) are good cleaning items. This may restore error 1203. You can also reset it by unpluging it after turning it off. Unplug all cords after waiting a moment replug all an turn on. Try and print now. Post back if no good
Cheers,
lilacgerry
Nov 17, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error 1203 for lexmark x4270
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would request you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again.. I would suggest using a q-tip and some rubbing alchohol.
Sep 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error 1203 What do I do?
Cartridge Error: 1203 Your print cartridge has a short.
  1. Press Power to turn your All-In-One off.
  2. Unplug your All-In-One from the wall outlet.
  3. Plug in your All-In-One.
  4. Reinstall the cartridges.
Aug 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Error 1203
Dear Rica,
These steps are for a Lexmark 4200 Series, but I suspect they will work for your printer as well:
If this does not resolve the problem, see More troubleshooting options, or replace your cartridges.
Source: http://www.lexmark.com/publications/pdfs/4200/eng/trouble.html
Cheerup and Be Happy always
Mar 27, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
223 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
