Question about Trust 17966 Tytan 2.1 Speaker Set
On off switch problems - Trust 17966 Tytan 2.1 Speaker Set
2001 Plymouth neon reverse lights not working
You seem to have a sticky problem. Usually, lights have three problem areas, fuses, bulbs and switches, in that order. If you've changed the switch, make sure the switch is set correctly. Do this by putting the car in reverse, then measuring the contacts on the switch with an ohm meter. You can get one of those very cheaply from an auto parts store or Radio Shack.
If you have contact across the switch with the car in reverse (and the ignition switched on of course), your problem could be a dirty or blown fuse, but I assume you've checked the most obvious by now. If you have no connection across the switch, you may have to simply adjust the switch by screwing it in a little further (or out, depending on the mechanics of the switch).
If this does not solve it, the final problem area will then be wiring.
First, check (using your new multimeter) for 12 volts on one of the wires at the switch. No voltage? trace the problem from the fuse to the switch. You have votage? - the problem is on the wiring to the reverse lights.
Connect the two wires together at the switch (yes, make a dead short between the two wires) and then check the lights.
You might live in a high corrosion area - lots of acid rain - then the problem could be the earth connection, usually the body of the lamps are corroded and need to be cleaned, or else the contacts need to be cleaned. Just a small piece of 500 to 1000 water paper will do fine.
A final but absolutely most unlikely problem is that the actuator inside the gearbox is either loose or broken. Go there only with utmost caution and lots of chutzpah, a very, very, very last option.
Oct 06, 2014 | Cars & Trucks
Rear brake lights will not turn off even when car is off only way to get them to turn off is mby unplugging the cord from inside the trunk
it sounds like the brake light switch is bad allowing voltage to pass through the switch.its located on the brake pedal and is a 2 wire switch.if you unplug the switch with everything else connected and the lights go out then the switch is the problem.
Aug 10, 2011 | 1990 Toyota Corolla
No turn signal, fuse good. Hazard works. Where is the flasher unit located?
If the hazards work normal,the problem will not be with the flasher unit.Try switching bulbs with the other side.If the problem switches also,it is the bulb.If the problem DOES NOT also switch,there is likely a problem with the wiring.Also,there used to be a contact plate within the steering wheel.If there is an airbag in the steering wheel,it will be very difficult to check.Greg Also,it could be the switch which activates the turn signal if the problem does not switch when the bulbs are switched.
Feb 15, 2011 | 1995 Buick Century
No power at all
Power problem your side due to power fluctuation switch goes damage please check your power connectivity there is some problem with power.
May 07, 2010 | Allied Telesyn (AT-3624TR-19) Networking...
Whyis my break light staying the bike is a 2006
The front brake light switch in located in the throttle switch housing. When you pull the front brake lever, it pivots and allows the switch to make. Sometimes the brake master cylinder and the front switch housings move and cause this problem. Loosen the master cylinder bolts holding it onto the handlebars and make sure it's slid down tight against the throttle switch housing.
If this doesn't solve the problem, you may have an electrical problem that you'll have to trace out and find the problem. You'll need a wiring diagram for this. There are two switches in the system that controls the light. I've already talked about the front switch. The rear brake switch is a pressure switch located somewhere along the metal line that comes out of the rear brake master cylinder. Sometimes these switches go bad but rarely. Having an electical problem on a bike this new is unusual as well. I don't have a wiring diagram for this model. Good Luck.
Apr 12, 2010 | Harley Davidson FLSTC Heritage Softail...
I have a perko battery switch on my boat. The boat has always run flawlessly. Yesterday I developed a problem with my starter and trim/tilt motors. I have verified its not a motor problem.When attempting...
I would bet that this is a ground problem since the Perko switches very rarely fail. You can easily check this by simply jumping out the switch. Temporarily remove one cable from the battery switch and bolt it onto the same stud as the other to eliminate the switch. If the problem remains the same, then it will be something other than the switch (like grounds). If the problem goes away, change that switch for a new one!
Aug 07, 2009 | Perko Main Battery Switch
Problem with connecting two 24 port 3 com switches
If the whole network looses connections when you connect the two switches together, there may be a loop in the network...that is, there could be another path for data to pass between the switches. Typically this is caused if there are two cables connecting the switches, but it can also happen if there is another switch or other network device connected to both switches.
Jan 16, 2008 | 3Com 3C16985B /REF3COM SSII 24-PORT SWITCH...
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
Samsung monitor problem
Dude u knows the repairing part of the monitor or u knows the basic electronics…
You need to do one thing that is open the CRT i.e. Monitor and after that remove the On/OFF switch u can open the switch and clean it ….
Or
Replace the switch by new one….
Dec 04, 2007 | Gateway FPD2275W LCD Monitor
Trust 17966 Tytan 2.1 Speaker Set Logo
105 people viewed this question
Top Trust Televison & Video Experts
Electro Med Services...
Are you a Trust Televison and Video Expert? Answer questions, earn points and help others
